Old Dec 09, 2010, 03:21 PM
killsdeer4fun is offline
Find More Posts by killsdeer4fun
With great pwer comes great 3D
killsdeer4fun's Avatar
Globe, USA, Clemson, SC
Joined Jun 2010
Look at the cannons if you want something that shoots good video and stills. And be prepared to get a big memory card if you shoot a lot of video.
killsdeer4fun is offline Find More Posts by killsdeer4fun
Old Dec 10, 2010, 11:11 AM
turko is offline
Find More Posts by turko
Canada, BC, New Westminster
Joined Oct 2009
Does anyone know how many teeth are on the stock tail belt for the blade 400?
turko is offline Find More Posts by turko
Old Dec 10, 2010, 11:23 AM
dbennettya is offline
Find More Posts by dbennettya
Joined Apr 2009
Just counted 12 teeth on a spare.
Don
dbennettya is offline Find More Posts by dbennettya
Old Dec 10, 2010, 03:17 PM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Don
Might want to throw that one away then
The belt will have hundreds of teeth - more than 100, less than 200.
jasmine2501 is offline Find More Posts by jasmine2501
Old Dec 10, 2010, 03:30 PM
Joined Apr 2009
OOPs thought he meant tail shaft
Don
Old Dec 10, 2010, 07:18 PM
loopy1 is offline
Find More Posts by loopy1
Dyslexic crash pro!
Westminster, CO
Joined Jun 2008
It really doesn't matter as long as the belt is the correct length, with the correct tooth size and tooth pitch.
loopy1 is offline Find More Posts by loopy1
Old Dec 10, 2010, 08:47 PM
beginner4life is offline
Find More Posts by beginner4life
beginner4life's Avatar
United States, MD, Ellicott City
Joined Mar 2008
My tail was wagging back and forth alot today and it caused an abrupt landing which broke some stuff. Idk whats up with the tail it just seems very unstable and all over the place. Havent adjusted anything in the gyro. Could the belt be stripped?
beginner4life is offline Find More Posts by beginner4life
Old Dec 10, 2010, 08:58 PM
Joined Jun 2010
Possibly, causing it to slip and the gyro sending commands to the tail and throwing it all off every which way when the torque is applied and lost.
Old Dec 10, 2010, 09:06 PM
Joined Mar 2008
Sounds about right
Old Dec 11, 2010, 01:22 PM
Dusty1000 is offline
Find More Posts by Dusty1000
Scotland the Brave
Dusty1000's Avatar
United Kingdom, Scotland, Glasgow
Joined Mar 2008
It's more likely to be one of the belt pulleys. Hold the main rotor firm, and try and turn the tail rotor. Don't use too much force, but if the teeth on either pulley are worn, you will be able to feel the belt skip over them..
Dusty
Dusty1000 is offline Find More Posts by Dusty1000
Old Dec 11, 2010, 04:12 PM
Joined Mar 2008
Dusty
This is exactly what happens. How do i go about fixing this?
Old Dec 11, 2010, 04:46 PM
Scotland the Brave
Dusty1000's Avatar
Joined Mar 2008
Look at the tail pulley as you turn the rotor, and see if the belt is skipping on it. Hopefully it will be as that's the easiest pulley to replace. If it's not skipping over the rear pulley then it must be the front one that has the worn teeth. It could of course be both but IIRC the rear one usually wears first.
This is assuming the belt is at the correct tension and not too loose.
Dusty
Old Dec 11, 2010, 07:19 PM
segroegt is offline
Find More Posts by segroegt
Canada, QC, Montreal
Joined Jan 2009
Dusty
I think his belt is too loose. Best Regards.
segroegt is offline Find More Posts by segroegt
Old Dec 11, 2010, 08:40 PM
Joined Mar 2008
How can i check if the belt is too loose?
Old Dec 12, 2010, 10:13 AM
Scotland the Brave
Dusty1000's Avatar
Joined Mar 2008
Push it with a screwdriver or something, through the inspection hole in the side of the boom. You should only be able to push it in very slightly before you start to feel the tension. There's more on this in the manual.
Dusty
Official Parkzone P-51 Owners Thread - Part 2 monitor Parkflyers 2602 Jun 15, 2014 04:51 PM
Yippee! Official Parkzone P-51 Owner's Thread Part 2 Ferocious Franki Parkflyers 15 Apr 02, 2014 11:22 AM
Cool The Official Blade 400 Thread - Questions - Support - all you need to know! blade strike Mini Helis 20639 Nov 08, 2010 09:41 AM
Discussion another Bible, creation, science thread Part 2) martin richards Life, The Universe, and Politics 131 Nov 07, 2010 01:00 AM
Discussion new AXE 400 official thread. raptorddd Micro Helis 0 Sep 08, 2008 03:29 AM
