Old Nov 23, 2010, 08:44 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Originally Posted by Mheeli View Post
The initial sketch was removed as it contains position hold bug. I will upload the new sketch soon.
Mheeli, do you have a wiring setup for the yellowjacket? I have a yellowjacket coming today and would like to get it wired up. I have the breakout board already, use it with my Dragon OSD. Would the driver be the same? I'm able to update and make changes to my OSD with my breakout board.
Brian.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Nov 23, 2010, 01:06 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Yes .
please. Some pictures on how you connected everything up, and maybe some wire diagrams will help some people, and It will go like wild fire.
I really want to try this. But I am unsure how to load up and configure the yellow jacket to work correctly. ect
Thank you for all the hard work. and please share once everything is irons out.
witespy is offline Find More Posts by witespy
Old Nov 23, 2010, 02:07 PM
Joined Feb 2005
The yellowjacket arrived safe and sound. Does the breakout board plug straight in? When it says txo, on the yellowjacket, does it go to rxi on the breakout board? Can the antenna be removed or is it needed? Could you please post a wire layout so I can get started.
Cheers, Brian.
Old Nov 23, 2010, 02:42 PM
witespy is offline
Joined Sep 2009
Cheers, Brian.
Going to place an order now. What program board is that?
Old Nov 23, 2010, 04:45 PM
Joined Feb 2005
I ordered the yellowjacket from Async. If you look at the bottom of the yellowjacket page, you will see the breakout board. I had mine already for my OSD.
Old Nov 24, 2010, 06:08 AM
CrocEnd is offline
Find More Posts by CrocEnd
CrocEnd's Avatar
Darwin
Joined Aug 2002
Mine are payed for TO
Any one tell me more of RC TX flying yet.
GOOD or not
CrocEnd is offline Find More Posts by CrocEnd
Old Nov 24, 2010, 06:10 AM
CrocEnd is offline
CrocEnd's Avatar
Darwin
Joined Aug 2002
Hey Buffy what OSD are you useing
Cheer's Croc
Old Nov 24, 2010, 06:51 AM
Joined Feb 2005
Cheer's Croc
Croc. I have a Dragon OSD but it's not for the drone. The breakout board that I used to program the OSD will work with the yellowjacket.
Brian.
Old Nov 24, 2010, 08:02 AM
Mheeli is offline
Find More Posts by Mheeli
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Cheers, Brian.
I fly with the antenna disconnected. Should be OK as the WiFi chip has a copper antenna line on the PCB.
Mheeli is offline Find More Posts by Mheeli
Old Nov 24, 2010, 08:04 AM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
I have updated the initial post with the writeup and all the files required for this project.
This should keep you busy for a day or 2.
I will continue the writeup when I got some sleep
Old Nov 24, 2010, 06:13 PM
Joined Feb 2005
Ready to roll. Very easy to solder up, thanks to Mheeli. You da man!! I was able to program the YJ and recieved "move sticks" commands. Just need to wait for the start up procedure. Need to know the channel designations(norm/rev), that sort of thing. Hope to have a test flight indoors this Friday.
Cheers, Brian.
Old Nov 24, 2010, 07:49 PM
witespy is offline
Joined Sep 2009
wow. very nice
I can not wait to get my yellowjacket.
Old Nov 24, 2010, 07:50 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Wow, that's quick and very neat wiring. What Rx are u using? I'm glad the Sketch worked as designed , so far.
I just finished flying around in my garden using my iPod as video downlink. This thing is soooooo relaxing to fly, not like my other toy
I will update the radio setup procedure later today.
Old Nov 24, 2010, 08:19 PM
Joined Feb 2005
I just finished flying around in my garden using my iPod as video downlink. This thing is soooooo relaxing to fly, not like my ore toy
Thats one sweet looking heli The YJ was easy to do. I have a MK quad to put together. Alot more soldering then the YJ. I'm using an AR6200, without the sat rx.
Brian.
Old Nov 25, 2010, 03:49 AM
CrocEnd is offline
CrocEnd's Avatar
Darwin
Joined Aug 2002
Buffy thanx
I have full Eagle tree stuff and imersion I think thats it
Discussion Parrot AR.Drone range extension, need help from antenna gurus. g00bd0g FPV Talk 4 Jan 21, 2011 01:29 PM
Wanted Parrot ar drone ROCKY2 Aircraft - Electric - Helis (FS/W) 23 Nov 07, 2010 09:08 AM
Discussion Who’ s the Russian model in AR.DRONE vid? Naev Electric Heli Talk 8 Oct 12, 2010 02:32 PM
Discussion AR.Drone to carry camera gunnar-rc Aerial Photography 2 Sep 07, 2010 09:52 AM
Discussion Unboxing and First Impressions With the Parrot AR.Drone nikotttin Multirotor Talk 0 Aug 31, 2010 04:50 AM
