Old Nov 08, 2010, 06:42 PM
Sid3ways is offline
Find More Posts by Sid3ways
DJI Supporter
Sid3ways's Avatar
Swanton, OH
Joined Jul 2007
Originally Posted by jesolins View Post
Nice work! That certainly makes the ARDrone a bit more interesting to me...
Cheers,
Jim
Quadrocopter and Tricopter Mega Link Index
+1 I'm very interested to see how this pans out. Especially in UAV form.
Sid3ways is offline Find More Posts by Sid3ways
Old Nov 08, 2010, 07:00 PM
ARDroneFlyers is offline
Find More Posts by ARDroneFlyers
Joined Nov 2010
Hi,
Symon here from www.ardrone-flyers.com this is a great modification.
Will the Sketch be released for carrying out such mod.
I would also love to know if your sending the setup and flat trim instructions to the Drone before take off.
We on ARDF's are watching you on this one.
Symon.
ARDroneFlyers is offline Find More Posts by ARDroneFlyers
Old Nov 08, 2010, 07:04 PM
Mheeli is offline
Find More Posts by Mheeli
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Originally Posted by Mheeli View Post
The weight of the Assan Rx, Arduino Uno and Wishield totals to 68g. The Arduino can be powered by the existing onboard battery.
We can save more weight if we could use an Arduino with Wi-Fi shield like http://asynclabs.com/store?page=shop...category_id=11
Unfortunately it's out of stock , so I could not try.
The YellowJacket is back in stock.
It's an Arduino with Wifi built in on board. This is perfect to put on the drone. It should save us a lot of weight and space. If it works, we will only need to spend $55 to make Ar.Drone RC enabled
Mheeli is offline Find More Posts by Mheeli
Old Nov 08, 2010, 07:16 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Originally Posted by ARDroneFlyers View Post
Hi,
Symon.
Most definiatly, I will post everything. After all, I got most of the ideas and bits of code from various sources like
- diydrones.com. Really like this site, so very open and helpful
- "MAPGPS" over the Ardrone API forum
- The Air Drone forum at http://www.air-drone.de/
- Ar Drone Flyers at www.ardrone-flyers.com
- And of course, the one and only, RC Groups
However, I'm too embarassed to post the code right now. It's very ugly
Let me clean it up a bit.
Old Nov 08, 2010, 07:25 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Originally Posted by Buffythesaint View Post
Yes, that's the Arduino I'm using.
But, the YellowJack is now back in stock. http://asynclabs.com/store?page=shop...id=11&vmcchk=1
If it works, this will be better. I'm putting in an order for one.
Old Nov 08, 2010, 07:50 PM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
I see that they will shipping the yellowjacket out to the retailers also. The Robot Shop here in Canada stocks them. I'll put an order in when they get them back in stock. Do you use 5 channels on the assan or just 4?
Buffythesaint is offline Find More Posts by Buffythesaint
Old Nov 08, 2010, 07:56 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
We need 5 channels. 4 for the normal movement and 1 for take off and landing. I checked the specification of the YellowJacket. It has enough digital inputs.
But it's possible to use only 4ch RX, just need some creative stick movement combination to take off and land.
Old Nov 08, 2010, 08:00 PM
RCvertt is offline
Find More Posts by RCvertt
RCvertt's Avatar
Joined Aug 2007
What is the position hold altitude limit on the ARDrone? About 10ft?? Will it hold over all surfaces?
Cheers,
Jim
Great mod.
I would also like to know the height limit of this thing. Does it get all shaky 100 ft up or will it stay stable? If it needs that camera for stability I'm guessing there is a limit?
RCvertt is offline Find More Posts by RCvertt
Old Nov 08, 2010, 08:02 PM
Joined Feb 2005
A 4 ch rx would be even smaller and lighter. Will a 2.4 rx work or will a conflict arise?
Old Nov 08, 2010, 08:05 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
I'm using the Assan 2.4GHz module from HobbyCity
http://www.hobbycity.com/hobbyking/s...idProduct=8286
I did not see any radio interference.
I also have Spektrum Radio. Will try it out when I have a chance.
Old Nov 08, 2010, 08:08 PM
Joined Feb 2005
Doh!! Should of realized it was 2.4 I see your 2.4 tx antenna now.
I have 2.4 FPV gear and this will really work out. A small camera(10-20g's) out front, above the stock camera, a 2.4 100mw vtx mounted on the tail. The yellowjacket and rx(72mhz) in the middle, above the battery. You can really have some fun. If you wanted to try a gopro, this may work also. A bit heavier though.
Old Nov 09, 2010, 10:14 AM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Arduino Sketch posted.
Old Nov 09, 2010, 04:16 PM
Joined Nov 2010
Hi Mheeli,
Thank you ever so much for adding more details to your original post and uploading the sketch.
This is absolutely amazing that you have managed this.
Old Nov 09, 2010, 04:35 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
I can not wait until we see the YellowJack working.
This is very cool. I have we have people what will run with it.
witespy is offline Find More Posts by witespy
Old Nov 10, 2010, 03:23 AM
Quad_Addict is offline
Find More Posts by Quad_Addict
United States, IL, Chicago
Joined Dec 2006
was just a matter of time. the extra weight is nothing to me, since one of mine will be reset on a carbon frame anyways to get rid of the hauls. nice work!
Quad_Addict is offline Find More Posts by Quad_Addict
Reply With Quote  (Disabled)
Discussion Parrot AR.Drone range extension, need help from antenna gurus. g00bd0g FPV Talk 4 Jan 21, 2011 02:29 PM
Wanted Parrot ar drone ROCKY2 Aircraft - Electric - Helis (FS/W) 23 Nov 07, 2010 10:08 AM
Discussion Who’ s the Russian model in AR.DRONE vid? Naev Electric Heli Talk 8 Oct 12, 2010 03:32 PM
Discussion AR.Drone to carry camera gunnar-rc Aerial Photography 2 Sep 07, 2010 10:52 AM
Discussion Unboxing and First Impressions With the Parrot AR.Drone nikotttin Multirotor Talk 0 Aug 31, 2010 05:50 AM
