Old Dec 13, 2010, 10:38 PM
witespy is offline
Find More Posts by witespy
Clearwater, FLorida !
Joined Sep 2009
Originally Posted by Buffythesaint View Post
Any progress on your YJ? I wish I could go outside flying, snow day. All the roads are closed here on the lake. I was told to stay at home and not come to work, I even get paid. The only problem is no flying
I am loading up the firmware now. I got my pins. It looks like the links are dead for v2.1
I have 2.0 I going to load up, and give it a go. Still have to ssh into the drone. ekkkkkk
witespy is offline Find More Posts by witespy
Old Dec 13, 2010, 10:45 PM
voxelman is offline
Find More Posts by voxelman
Iowa USA
Joined Jul 2009
Originally Posted by mcrotor View Post
Nothing I can find that is click and fly yet.
Is everything compiled and I just need to put the bits in the right places or do I need to set up a development system?
voxelman is offline Find More Posts by voxelman
Old Dec 13, 2010, 10:56 PM
mcrotor is offline
Find More Posts by mcrotor
New Berlin, WI
Joined Oct 2006
I pretty much followed the instruction on this site:
http://parrotsonjava.com/
but still have not got the whole thing working yet. The drone will launch, land and change between cameras but that is all when using my Realflight controller.
Have not had time to look into it further yet.
mcrotor is offline Find More Posts by mcrotor
Old Dec 14, 2010, 02:45 AM
palomo is offline
Find More Posts by palomo
romantist
palomo's Avatar
Chicago
Joined Jul 2004
Anyone here looking to obtain an extra Drone? Shoot me a pm, as I'm getting rid of a nice one. Thanks
palomo is offline Find More Posts by palomo
Old Dec 14, 2010, 04:53 AM
kikourof is offline
Find More Posts by kikourof
Joined Jul 2009
Mheeli,
Does it have to be Arduino software version 0020, cause when I try to upload the YJ sketch in Arduino 0021 then I get a compile error.
Arnaud
kikourof is offline Find More Posts by kikourof
Old Dec 14, 2010, 10:03 AM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
Originally Posted by kikourof View Post
Mheeli,
Arnaud
I'm using version 21 with no problems. The V2.1 sketch was removed. It has some bugs in it to be worked out.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Dec 14, 2010, 02:17 PM
witespy is offline
Joined Sep 2009
getting closer......
Now to the scary part..
after flashing the green light does not come on anymore? everything seemed to update okay
Old Dec 14, 2010, 05:41 PM
Mheeli is offline
Find More Posts by Mheeli
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
By default, the user_config.h is configured so that WiFi is disabled. After radio setup, we will enable it in step 9 and reload the sketch.
Mheeli is offline Find More Posts by Mheeli
Old Dec 14, 2010, 05:42 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Mheeli,
Arnaud
What's the error message?
Old Dec 15, 2010, 11:11 AM
kikourof is offline
Joined Jul 2009
Here is the message I'm getting:
'RC_AR_Drone_V2.c:4:17: error: uip.h: No such file or directory
RC_AR_Drone_V2.c:6:20: error: udpapp.h: No such file or directory
RC_AR_Drone_V2.c:7:20: error: config.h: No such file or directory
RC_AR_Drone_V2.c: In function 'udpapp_init':
RC_AR_Drone_V2.c:23: error: 'uip_ipaddr_t' undeclared (first use in this function)
RC_AR_Drone_V2.c:23: error: (Each undeclared identifier is reported only once
RC_AR_Drone_V2.c:23: error: for each function it appears in.)
RC_AR_Drone_V2.c:23: error: expected ';' before 'addr'
RC_AR_Drone_V2.c:27: error: 'addr' undeclared (first use in this function)
RC_AR_Drone_V2.c:36: error: invalid use of undefined type 'struct udpapp_state'
RC_AR_Drone_V2.c:37: error: invalid use of undefined type 'struct udpapp_state'
RC_AR_Drone_V2.c: At top level:
RC_AR_Drone_V2.c:40: error: expected ')' before '(' token'
Old Dec 15, 2010, 04:16 PM
kikourof is offline
Joined Jul 2009
Actually, could it be that I have a bad Yellow Jacket?
How can I verify that the card is working properly before uploading the sketch?
Thanks for your help,
Old Dec 15, 2010, 05:10 PM
Joined Feb 2005
Do you have the right chipset selected? Com port? Did you unzip them into the same folder?
Old Dec 15, 2010, 05:27 PM
kikourof is offline
Joined Jul 2009
Correct chipset and com port selected.
The sketches are in the library folder inside the arduino folder, but I exported them under their zip name folder inside library, should I put directly the sketch files at the root of the library folder without being in the 'RC_AR_Drone_V2_YJ' folder name?
Old Dec 15, 2010, 07:34 PM
Joined Feb 2005
I have a folder called Arduino on my c drive. Inside I have two folders, one called Aduino-21 and the other called Drone. Inside the Drone folder I have the sketch folder, V2 sketch, with the 3 files inside of that. When a new sketch comes out, I'll make another folder called V2.???? My sketches are not in the Arduino folder. The only thing I added to the Aduino folder was the wifi file.
Old Dec 15, 2010, 07:37 PM
Z06 Tony is offline
Find More Posts by Z06 Tony
Z06 Tony's Avatar
United States, NY, Rochester
Joined Sep 2008
My YJ has an external ant. Do I need that for a Spektrum conversion or do I cut that off?
Z06 Tony is offline Find More Posts by Z06 Tony
Site Sponsor
Discussion Parrot AR.Drone range extension, need help from antenna gurus. g00bd0g FPV Talk 4 Jan 21, 2011 02:29 PM
Wanted Parrot ar drone ROCKY2 Aircraft - Electric - Helis (FS/W) 23 Nov 07, 2010 10:08 AM
Discussion Who’ s the Russian model in AR.DRONE vid? Naev Electric Heli Talk 8 Oct 12, 2010 03:32 PM
Discussion AR.Drone to carry camera gunnar-rc Aerial Photography 2 Sep 07, 2010 10:52 AM
Discussion Unboxing and First Impressions With the Parrot AR.Drone nikotttin Multirotor Talk 0 Aug 31, 2010 05:50 AM
