Old Dec 11, 2010, 11:44 AM
JHawk19 is offline
Find More Posts by JHawk19
Buy, Mod, Fly, Sell, Repeat
JHawk19's Avatar
United States, SC
Joined Apr 2008
Cool. Found these:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
They are sealed and should work @ 2x5x2.5mm.
JHawk19 is offline Find More Posts by JHawk19
Old Dec 11, 2010, 12:27 PM
Buffythesaint is offline
Find More Posts by Buffythesaint
Joined Feb 2005
If you want the best bearings, Bocca are the way to go. Expensive but top quality.
http://www.bocabearings.com/search.a...thOperator=%3d
Buffythesaint is offline Find More Posts by Buffythesaint
Old Dec 11, 2010, 12:30 PM
JHawk19 is offline
JHawk19's Avatar
United States, SC
Joined Apr 2008
More questions. My Drone is in route.
I want to place vinyl carbon fiber over the outdoor hull. Will a 12"x12" sheet be enough?
Also, does anyone know where I can get a string of flexible white LEDs in the US?
And finally, can I use these batteries for my Drone? :?:
http://hobbyking.com/hobbyking/store...idProduct=9163
http://hobbyking.com/hobbyking/store...idProduct=9272
http://hobbyking.com/hobbyking/store...idProduct=7309
Of course I'll need to change the connector, but will they work? :?:
Old Dec 11, 2010, 04:17 PM
voxelman is offline
Find More Posts by voxelman
Iowa USA
Joined Jul 2009
I sure hope so because i just bought 4 of the 1300ma and 3 of the 2200ma. I got the Mini Tamiya connectors on eBay.
voxelman is offline Find More Posts by voxelman
Old Dec 11, 2010, 06:38 PM
Mheeli is offline
Find More Posts by Mheeli
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Originally Posted by Aerhead View Post
Mheeli
Thank you for reply. Are you still going to try larger motors for the AR Drone. Would you be able to change PID settings to fine tune the flight controller for different motors?
Do you know how the AR Drone motors are controlled PWM, i2c or serial? I just bought an AR Drone off of ebay and I will convert it to RC. I would not have been interested in it without your conversion.
Thank you
Larry
I want to put in bigger direct drive motors. But it could be difficult. We need to know the protocol used between the main CPU and the motor CPU. My logic analyzer from Seedstudio arrived. So I will try to sniff.
More info on the serial http://www.kapejod.org/2010/10/lets-...rial/#comments
Mheeli is offline Find More Posts by Mheeli
Old Dec 11, 2010, 06:45 PM
Mheeli is offline
Mheeli's Avatar
Bangkok, Thailand
Joined Jul 2002
Why gear?
I was thinking of replacing the motor with a direct drive out runner. But I kept asking myself why Parrot choose to use gear instead of direct drive? Some of the advantages I can think of:-
- Lighter? The lighter the better as any weight gain will be multiplied by 4
- Finer and faster RPM control? This might be the secret to the Drone's stability
- Efficiency?
- Safety? The gear tooth will be stripped before your fingers are cut off?
Old Dec 12, 2010, 02:24 AM
SebastianJ is offline
Find More Posts by SebastianJ
Droner
SebastianJ's Avatar
Denmark, Capital Region of Denmark, CPH
Joined Mar 2006
This motor http://www.hobbycity.com/hobbycity/s...idproduct=2069 and this ESC http://www.hobbycity.com/hobbycity/s...idProduct=4204 will do the job, the motors KV are spot on for the AR prop.
The prop might need to be drilled though.
SebastianJ is offline Find More Posts by SebastianJ
Old Dec 12, 2010, 08:00 AM
Joined Feb 2005
I changed the throttle dead zone from 40(default) to 50 and went outside for a test flight. It was little windy and when your off centre, the wind will blow the Drone away. The dead zone was a little too big so I'll change it to 45 and try again. The video is pretty boring but you can see the wind carry it. It did hold a hover though, in the wind. The Drone is definately a calm wind flyer. I kept the flying over the road, not sure what would happen over the snow. I don't want to mess up my Drone with snow on the electrics. The video was recorded in 1080 mode with my gopro.
RC AR Drone Outdoor Flight (4 min 32 sec)
Old Dec 12, 2010, 09:50 AM
mcrotor is offline
Find More Posts by mcrotor
New Berlin, WI
Joined Oct 2006
There has been a new release of the PCdrone control to work with Windows XP. Been playing with it trying to get my Realflight controller to work. So far I can get the controller to launch, land and change camera views but no movement in the x,y,c and z axis.
Originally Posted by Mheeli View Post
Version 2.1 with video downlink support uploaded to the first post. See [09Dec10] update.
As mentioned in post, there's no performance improvement over the V2.0 sketch. Only download the new sketch if you want the video downlink support.
Hopefully there are not too much bugs in this version
I am unable to test with a PC version of Freeflight as I'm still on windows XP.
If any of you have Vista or Windows 7. Can you download this PC drone control and test whether the video downlink also on PC. Thanks
Here's the direct download link
mcrotor is offline Find More Posts by mcrotor
Old Dec 12, 2010, 04:57 PM
luigo is offline
Find More Posts by luigo
Joined Dec 2010
http://www.youtube.com/watch?v=D9rDx23DZ3o
Nice video! But it appears that left axle is isolating or out-of-balance and you might be losing power and control there.
luigo is offline Find More Posts by luigo
Old Dec 12, 2010, 07:09 PM
voxelman is offline
Iowa USA
Joined Jul 2009
Is there an executable version of PCdrone?
Old Dec 13, 2010, 09:50 AM
Joined Feb 2005
Originally Posted by witespy View Post
Mheeli. I want to thank you again for all your hard work on this mod. I have a y/j but really wanted to wait for the headers I ordered.
I will be joining you soon. Thank you for all the details .
crazy this is possible, this is going to be awesome !
Any progress on your YJ? I wish I could go outside flying, snow day. All the roads are closed here on the lake. I was told to stay at home and not come to work, I even get paid. The only problem is no flying
Old Dec 13, 2010, 03:38 PM
mcrotor is offline
New Berlin, WI
Joined Oct 2006
Nothing I can find that is click and fly yet.
Old Dec 13, 2010, 03:39 PM
Impulze is offline
Find More Posts by Impulze
Impulze's Avatar
Sweden
Joined Jul 2004
Very Cold here in northern Sweden now, still no YJ in sight but the -30 degrees celsius (-22F i think) will keep the drone grounded
//Matte
Impulze is offline Find More Posts by Impulze
Old Dec 13, 2010, 08:40 PM
voxelman is offline
Iowa USA
Joined Jul 2009
//Matte
Well we could all compare how cold it is. It's 3 F (-16.11C) here in Fairfield, Iowa USA. Wind chill takes that down to -9 F (-22.78C). We have a couple of inches of snow on the ground with an under layer of ice from freezing rain. Don't you just love winter. ;^)
Discussion Parrot AR.Drone range extension, need help from antenna gurus. g00bd0g FPV Talk 4 Jan 21, 2011 01:29 PM
Wanted Parrot ar drone ROCKY2 Aircraft - Electric - Helis (FS/W) 23 Nov 07, 2010 09:08 AM
Discussion Who s the Russian model in AR.DRONE vid? Naev Electric Heli Talk 8 Oct 12, 2010 02:32 PM
Discussion AR.Drone to carry camera gunnar-rc Aerial Photography 2 Sep 07, 2010 09:52 AM
Discussion Unboxing and First Impressions With the Parrot AR.Drone nikotttin Multirotor Talk 0 Aug 31, 2010 04:50 AM
