My ArDrone arrived today, read this thread and going for the YJ board.
)Im thinking about to use my Thomas Scherrer UHF receiver 430-440 Mhz, do u think it will be any interferance on such freq? Iphone 4 and older Iphones can use a cable set to fly Fpv with goggles: http://cgi.ebay.com/TV-OUT-COMPOSITE...item230a541ad8 Tv-out might only work with jailbreaked iphones. U need an application from Cydia to run this feature. Great job publishing this modification!! Very appreciated! //Matte |
Southampton, Ontario CA
Joined Feb 2005
The video feed from the Drone would still be limited to the range of the Drone wifi, FPV won't work this way. If you kept it close, the video will work but that would negate the FPV. I'll try to do a better indoor FPV test flight at the next indoor session. We are in the middle of a nice snow storm , no more outdoor flying for me.
Features include:... - Television out with supported device and accessory cable. (not supported on older devices such as iPhone 3GS, iPod Touch 3G) superevan |
Ok! For those that have older iphones a jailbrake is necessary to activate tv-out. //Matte |
Joined Feb 2005
Mheeli, is your new sketch ready to try? |
Joined Feb 2005
New Berlin, WI
Joined Oct 2006
Yippi !!!!!!
Gentlemen, I have lift-off via YJ and Spektrum DX8.
Just had to tweek the expo (30% aileron, elevator) (20% rudder). Very smooth and natural (if you have been flying rc that is). Very happy. Now to get a video downlink for my GoPro hero and my Headplay glasses and FPV here I come. Marty P.S. I looked further into the extra solder that had bridged the two chip legs on the YJ and I figure it came from when I snipped the extra wire protruding from the back of the board after soldering. Figure I must have laid the board on my work bench on top of a loose piece of solder and there you go. Instant bridge. Thanks Brian for shedding some light on that deal. |
Joined Feb 2005
. You won't go back to your i device, except to make a setting change . Are you able to try an outdoor range check? Lots of snow here now, won't be able to check my range until spring
. Would you mind sharing your details?Rx model, Ar.Drone firmware version. And what you use to supply the power to your Rx. Thanks. |
| Thread Tools | |
| Discussion Parrot AR.Drone range extension, need help from antenna gurus. | g00bd0g | Video Piloting (FPV/RPV) | 4 | Jan 21, 2011 01:29 PM |
| Wanted Parrot ar drone | ROCKY2 | Aircraft - Electric - Helis (FS/W) | 23 | Nov 07, 2010 09:08 AM |
| Discussion Who’ s the Russian model in AR.DRONE vid? | Naev | Electric Heli Talk | 8 | Oct 12, 2010 02:32 PM |
| Discussion AR.Drone to carry camera | gunnar-rc | Aerial Photography | 2 | Sep 07, 2010 09:52 AM |
| Discussion Unboxing and First Impressions With the Parrot AR.Drone | nikotttin | Multirotor Talk | 0 | Aug 31, 2010 04:50 AM |
