Old Nov 08, 2010, 03:32 AM
LTS49 is offline
Find More Posts by LTS49
Joined Oct 2010
my project t-rex 450 pro FPV
hello to all
I have a new project
I'll ride my t-rex 450 pro in fpv
I have a futaba radio t10cp 35 mhz, I'm going to take a LRS scherrer UHF
for the camera, it will be a gopro HD
for video, it will TX / RX lawmate 1.2 ghz 500mw with 8dBi patch antenna (I'll buy all this at nghobbies, are what he is good?)
for glasses, it will be the base station fatsharks
for registration, it will be Pinnacle Video Transfer with my ipod touch
veiled for the moment ...
(If you find problems, tell me ...)
but here, I have a slight concern, I do not know what I need lipo ....
I know I need one for TX 1.2GHZ 500MW, but I do not know what to take
knowing that I need one as light as possible and sufficient to put it in my trex, I must limit the over-weight in order to have greater autonomy
I must also surely have to feed my lipos fatsharks 1.2GHZ lawmate and receiver, but I do not know what to take? probably forgot something
can you help me
I would like your opinion
thank you very much
LTS49 is offline Find More Posts by LTS49
Old Nov 08, 2010, 07:26 AM
VRflyer is offline
Find More Posts by VRflyer
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Helicopter is the hardest way to do FPV
I would not choose 2.4ghz for video because at the moment someone around you will power on his radio on 2.4ghz, it will scrasmble your video. Also it is not possible to fly close or in town because of wi-fi.
1.2ghz from Lawmate is the best
a 14dbi antenna is for very long range flight. Start with the standard omni antenna that come with your receiver, you will be surprise of the result on 1.2ghz. You will not need Diversity and multiple antennas. The omni will be perfect for an helicopter up to 1km and over.
the antenna is heavy, you should make a mod to the tx if you can to replace the connector and weld a wire directly as antenna.
a very small lipo is enough. 450mah should last one hour with most cam/tx setup. buy severals and replace it oftenly.
your tx antenna should be mount vertically away from metallic part
Don't fly overhouse or road with your chopper, no one want to receive a piece of metal like that on the head, it is very dangerous.
VRflyer is offline Find More Posts by VRflyer
Old Nov 08, 2010, 11:53 AM
LTS49 is offline
Joined Oct 2010
for 2.4Ghz, I thought to AC because Trappy uses and even in town, and the AC seems to work well
I'd fly all alone, there will be nobody next to me with a 2.4GHz radio
Old Nov 08, 2010, 12:10 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
Do what you want. It sounds like a fun project.
Just don't dismiss what VRflyer says. Dennis is a wealth of knowledge and experience. Even more important...he's one of the guys who takes the time to help others achieve success.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Nov 08, 2010, 12:26 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
Just my 2 cents. I totally agree that helis are the hardest to FPV, VRflyer made good points (I respect him very much and he inspired most of us here to start doing this stuff!) but if you are already a really competent heli pilot it isn't too bad. If you are a rank novice... you are much better suited to fly fixed wing. You need to be a very proficient heli pilot to fly FPV helis, I would not want to be around someone trying to learn helis and FPV at the same time!!
aaronredbaron is offline Find More Posts by aaronredbaron
Old Nov 08, 2010, 02:50 PM
LTS49 is offline
Joined Oct 2010
I do not question its competence, on the contrary, if I created this post is for precisely gather as much advice and I thank you
I was thinking that the 2.4Ghz 500mw was the best, but we must believe that no ...
Lawmate 1.3GHz, 1.2GHz is the same as lawmate?
Otherwise, I saw the helicopter practice, I begin the 3D
I train on simulation as well (in RealFlight cockpit)
I suspect that ca not be easy, I know, already, on simulation, it is not clear
but it's like to start directly with a helicopter pitch
Old Nov 10, 2010, 07:07 AM
LTS49 is offline
Joined Oct 2010
I took the combo 1.2GHz 500mw lawmate
good for the lipo tx, I must have 450mha, but which (2S, 3S ???)? would you have a small link
ditto for the rx if you have a link, it would be super
what lipo also for Pinnacle Video Transfer fatshark and glasses?
thank you very much
Old Nov 10, 2010, 07:11 AM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
Get the lawmate 2.4 and fly it on channel 8. There is no wifi interference. Anyone that says otherwise hasn't tried it.
I see I am to late. The lawmate 2.4 was the better choice.
bracky72 is offline Find More Posts by bracky72
Old Nov 10, 2010, 07:37 AM
LTS49 is offline
Joined Oct 2010
too late, I buy the 1.2Ghz 500mw, but what I'm looking hopelessly with the power
Old Nov 10, 2010, 08:01 AM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
There is nothing wrong with what you got. It's very good. Just the 2.4 is better.
Old Nov 10, 2010, 08:38 AM
LTS49 is offline
Joined Oct 2010
we'll see,
What you use as battery for TX 500MW?
Old Nov 10, 2010, 08:46 AM
bracky72 is offline
bracky72's Avatar
Charles Town, WV
I power everything from my main flight battery and use a filter to remove any noise. You will need to regulate the voltage to 5 volts somehow.
Old Nov 10, 2010, 08:55 AM
fpvnick is offline
Find More Posts by fpvnick
My other vehicle is unmanned
fpvnick's Avatar
Joined Jan 2010
I tried flying fpv with my trex 450 it was ok in the back garden where you have things relatively close to judge distance / drift but when I tried in a field with just grass around it was much harder . I went back to planes for the moment as I got a bit scared about chopping my head off if I drifted to close or someone else for that matter could be worth looking at one of these to help keep things stable http://www.heliguy.com/Extras/Helico...mand-Advanced/
fpvnick is offline Find More Posts by fpvnick
Old Nov 10, 2010, 02:35 PM
LTS49 is offline
Joined Oct 2010
If I sets ca: http://www.hobbycity.com/hobbyking/s...idProduct=4319
+ That:
http://www.hobbycity.com/hobbyking/s...idProduct=7303
That will walk(work) with my TX 1.2ghz 500mw
Old Nov 10, 2010, 05:23 PM
VRflyer is offline
Live FPV or Die
VRflyer's Avatar
Montreal,Canada
Joined Feb 2002
Originally Posted by LTS49 View Post
you already have a voltage regulator inside the connector harness if it is a 500mw 1.2ghz from Lawmate. It is a dc-dc regulator. work very well. Just remove it from the connector harness, it is easy to do.
Build Log Official HK 450 PRO GT Thread 3D Belt / TT Drive Helicopter Kit Align T-Rex Pro Clone captaingeek Mini Helis 104 May 08, 2012 01:41 AM
For Sale T-Rex 450 Pro BNF dfrazier Aircraft - Electric - Helis (FS/W) 2 Oct 11, 2010 04:08 PM
Question Do the T-Rex 450 Pro and Sport versions have a different main shaft from the old 450? Sky_Dancer Mini Helis 2 Oct 06, 2010 09:31 PM
Sold T-Rex 450 Pro full rotor head w/extras (not a clone) Whopper Chopper Aircraft - Electric - Helis (FS/W) 5 Oct 02, 2010 07:05 AM
Found WTB -= T-Rex 450 Pro Flybarred RotorHead =- Whopper Chopper Aircraft - Electric - Helis (FS/W) 1 Sep 06, 2010 06:14 AM
