Old Mar 14, 2012, 09:34 AM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
Hum...the stich trick is a nice one, nevr heard of that. Nothing was shown as to how the wire should be attached. I figure that if it is glued on the bottom of the fusega and the 2 gear legs, it should hold itself OK ?
I don't have any time to work on the little plane right now. Not much left to do: Glue landing gear wire and install wheels, attach the struts and cover them, paint the cowl and glue the windows. Will post here as soon as I work on it, should be next week as I will be out of town this week end
carguy1994ca is offline Find More Posts by carguy1994ca
Old Mar 26, 2012, 09:10 PM
Quebec, Canada
Joined Sep 2006
Wing struts
Had some time to work on the plane today after a rough week and week end. I already had the struts covered a week and a half ago (all I could do on the plane that week) and to day I installed them, as well as the landing gear and tail wheel.
Noting much said on strut installation in the manual or plan. Here is how I did it:
Old Mar 26, 2012, 09:17 PM
Quebec, Canada
Joined Sep 2006
Landing gear
Main landing gear was easy to install because I had some foam wheels (a bit too big for the model but will make it easier to take off and land). The hole in the wheels where bigger than the landing gear wire, but I had some CF rod that I cut and slipped over the wire. I was lucky the CF rod was hollow. I glued the CF rod on the wire and used little washers to retain the wheels on the axles.
The wire is glued to the legs and bottom of fuselage with medium CA.
Old Mar 26, 2012, 09:28 PM
Quebec, Canada
Joined Sep 2006
Almost finished
I installed the tail wheel and tried the little Champ in the house Not flying mind you, but just taxxing on the wood floor and driving it around. Would have liked to have more space to lift the tail, but it will have to wait for a calm evening. I still have to install the windows and paint the cowl, but it looks quite nice and I had to show it off to you.
Old Mar 28, 2012, 06:28 AM
JSS4 is offline
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Nice job! What's the AUW and wing loading?
JSS4 is offline Find More Posts by JSS4
Old Mar 28, 2012, 08:12 AM
Quebec, Canada
Joined Sep 2006
Thanks ! So far the weight is a little over 2 ounces. Did not calculate wing loadind.
Guillows 24" Aeronca Champ looks like it was made by a CHIMP! nhorianopoulos Scale Kit/Scratch Built 19 Mar 21, 2015 03:46 AM
Discussion Flew my Guillows, Aeronca, and others...Oh My scigs30 Free Flight 21 Oct 22, 2010 09:42 PM
Discussion Guillows Aeronca Champ and Hellcat.. Vyceroy Scale Kit/Scratch Built 45 Nov 06, 2008 04:59 AM
Woohoo! Guillows Aeronca Champ Flies! ZRX Doug Parkflyers 18 Sep 24, 2003 07:31 PM
guillows 24" aeronca champ rubber to electric conversion davidbogart Scale Kit/Scratch Built 9 May 28, 2002 07:52 AM
