Old Jan 14, 2011, 03:52 PM
carguy1994ca is online now
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
aero2k4
Nice work on your champ ! I didn't work on mine lately. I received an FPV plane and assembled it. also sold some helis and had to repair and check them so didn't have time for the champ. Hopefully I will be able to work on it a bit. but it is fun to see you guys going on with your build. maybe you will fly yours before I fly mine
Anyway keep posting. thanks for the weight figures on your plane.
Carguy
carguy1994ca is online now Find More Posts by carguy1994ca
Old Jan 14, 2011, 09:40 PM
aero2k4 is offline
Find More Posts by aero2k4
Joined Jun 2010
Originally Posted by carguy1994ca View Post
aero2k4
Carguy
Thanks, Carguy1994ca! Yah! These our little machines really makes us spend hours and hours, especially in finishing, adjustments and covering! And yet it seems that nothing is good, specially about finishing, adjustments and covering! But at the finish job it gives us a great satisfaction, right?!
Cool!!! Talk about your FPV plane... what´s is FPV plane? About heli? It´s little craft like that can I fly into the house?
I did buy a ready-to-fly HK EPO QuickSilver GT-700 Ultralight R/C because I could not stand to stay without flying! I receive the QuickSilver last week and it weighs 300 grams!!!
As can we see at Dan´s video Aeronca Champ... the Aeronca flies much more stable, great stall speed and slow like an "real" aircraft! I flow HK QuickSilver without winds and the landings was horribles! The HK QuickSilver is nice look but it flies much "heavy" and the stall speed is high! Even though the HK QuickSilver motor has plenty of power!
>>>HK QuickSilver: 710mm span x 600mm lengh, full 300gr (~3 more times weighs than Guillow´s Aeronca Champ), 9.2sq.dm, 32.6gr/sq.dm, brushless 26gr 2700kv 58Watts, 7x4 tree blade prop;
>>>Guillow´s Aeronca Champ: 605mm span x 429mm lengh, full 100gr, 5.5sq.dm, 18.2gr/sq.dm, brushless 5gr 2000kv 10Watts, 4x2.5 prop;
I´ll on change the HXT 5gr 1400~2000kv (90gr thrust) motor for another HXT 10gr 2000kv (130gr thrust).
As soon try to takeoff withe the little 5gr brushless...
Let´s fly anyway!!!
Let´s finish our Guillow´s Aeronca!!!
Cheers
Glauco D. P. Lopes (aero2k4)
aero2k4 is offline Find More Posts by aero2k4
Old Feb 12, 2012, 09:39 PM
Quebec, Canada
Joined Sep 2006
Hi ! Been a while since I had started this project. I just resume working on the aeronca and started the covering, added the motor (switched to ultra micro system to save weight) and added some wood to the right side of the cabin so the wing wont be crooked. I'm using the UM 4site power system and receiver, the system and servos I had chosen felt too heavy one installed. I was at well over 3 ounces before covering, light system and wheels.
Here are some pictures, will post more this week as I work on the build. next is to start covering the frame, install the stab and fin so I can see where to exit the pushrods. Then cover the wings and add the second covering color. Plane will be same colors as on the box, cream and dark green. Hope there will still be someone reading this...
Old Feb 13, 2012, 10:14 PM
Quebec, Canada
Joined Sep 2006
Started covering on fuselage
Coverlite works well. I covered the bottom and top of fuselage, and began on bottom of one side. Top of side will be dark green. I made sure that the cream on the side was well attached to wood so it wouldn't sag when I put the green over it. Should look nice. I'm having a lot of trouble to remove the inked markings on the wood, so it shows under the covering. I'll try to mask it later.
Old Feb 15, 2012, 09:44 PM
Quebec, Canada
Joined Sep 2006
Tonight I covered the other side of the bttom cream trim and the landing legs. Also brushed the balsarite on one wing so will start covering it tommorrow.
Old Feb 16, 2012, 10:27 PM
Quebec, Canada
Joined Sep 2006
Covered the left wing. Went well, no warp. The cream and green look good together. Found that what I tought was "cream" on the box was in fact white (says so on the instructions) Oh well, I like the cream, looks old fashion.
Old Feb 26, 2012, 09:08 PM
Quebec, Canada
Joined Sep 2006
Stab glued
After a big week at work, I finally got time to work on the plane. Today I covered the other wing, I added the green to the rudder and I glued the horizontal stabilizer. I attached the elevator to it with 3M blenderm tape (small strips). I also installed the pushrod for the elevator and tested it: Works fine. I don't know why, but I kept postponing the pushrods installation. It went well though. I also used some small horns from Hobby King.
Old Mar 04, 2012, 07:10 PM
Quebec, Canada
Joined Sep 2006
Installing the fin and rudder
This week I had very little time to work on the champ, but managed to install the fin and rudder and its linkage. Linkages work well and should have enough throw to fly the plane. I'm quite happy with the trim, looks nice.
Old Mar 04, 2012, 09:25 PM
Quebec, Canada
Joined Sep 2006
Covering the sides and hood
Today I covered both sides of the plane as well as the hood.
Edit: pics added
Old Mar 05, 2012, 10:37 PM
Quebec, Canada
Joined Sep 2006
Adding the wings
Wings are glued !
Old Mar 06, 2012, 07:10 AM
JSS4 is offline
Find More Posts by JSS4
I'm BIG on micros
Canada, ON, Brampton
Joined Mar 2011
Nice build! I'll be watching for updates.
Where did you get the light kit?
JSS4 is offline Find More Posts by JSS4
Old Mar 07, 2012, 03:05 AM
UAVPilot is offline
Find More Posts by UAVPilot
Foam Floats Better
UAVPilot's Avatar
The Big Country of TX.
Is their no wire support designed in to mount the wheels on?
Or did I miss something in the thread?
UAVPilot is offline Find More Posts by UAVPilot
Old Mar 07, 2012, 08:04 AM
Quebec, Canada
Joined Sep 2006
Thanks ! I need to cover and install the wing struts, the wheels and paint the cowl and it'll be ready to fly ! Just have to wait for summer because I want to fly it over tall grass to maiden it and see how it flies. Should be good in about a month.
Got the lights kit here. Unfortunately, the receiver I am using has only 4 channels, dunno if I'll be able to connect them so i can use the flap switch to make them work. Also the plug that came for the kit is a reg servo plug, and I'd need a micro plug for the receiver (esay to change).
Old Mar 07, 2012, 08:05 AM
Quebec, Canada
Joined Sep 2006
There is a wire support that you glue to the bottom of fuselage and wheel struts. Its just not installed yet, as I didn't want the plane to roll away and I'm not sure if the wire is the good size for the wheels I'll use. Will look at this tonight if I have time.
Old Mar 14, 2012, 02:29 AM
UAVPilot is offline
Foam Floats Better
UAVPilot's Avatar
Ah, I see.
I was just wondering because most of the small scale balsa planes I have ever built has the wire gear sandwiched or stitched with thread into the lower bulkhead before it's covered.
Sometimes they are built with a slot in between two bulkheads and the wire can be installed after it's covered, I didn't notice that type of arrangment on your plane so was just wondering how it would be attached.
Guillows 24" Aeronca Champ looks like it was made by a CHIMP! nhorianopoulos Scale Kit/Scratch Built 19 Mar 21, 2015 03:46 AM
Discussion Flew my Guillows, Aeronca, and others...Oh My scigs30 Free Flight 21 Oct 22, 2010 09:42 PM
Discussion Guillows Aeronca Champ and Hellcat.. Vyceroy Scale Kit/Scratch Built 45 Nov 06, 2008 04:59 AM
Woohoo! Guillows Aeronca Champ Flies! ZRX Doug Parkflyers 18 Sep 24, 2003 07:31 PM
guillows 24" aeronca champ rubber to electric conversion davidbogart Scale Kit/Scratch Built 9 May 28, 2002 07:52 AM
