Old Nov 15, 2010, 02:36 PM
carguy1994ca is offline
Find More Posts by carguy1994ca
I tell her RC is cheap !
carguy1994ca's Avatar
Quebec, Canada
Joined Sep 2006
CA hinges are a laminated plastic and fabric piece that is inserted in slots in the control surfaces. When you put CA on it, the thin CA wicks into the wood and the fabric. It remains flexible but glued tot he wood. I don't like these hinges very much on larger models because they are kind of hard to move when lots of deflection is needed. But on a small model like this where the control surfaces are thin, they are easily installed and can be made narrow so it is not that hard to flex.
carguy1994ca is offline Find More Posts by carguy1994ca
Old Nov 20, 2010, 12:14 AM
Quebec, Canada
Joined Sep 2006
Left wing built
Made the left wing tonigh. Added 1/16 holes in the ribs for reinforcement at the root as specified for flying models in manual . Also added a hole in all the ribs tom pass lights wiring.
Old Nov 20, 2010, 10:33 AM
Quebec, Canada
Joined Sep 2006
Made the other wing this morning. The first one I trimmed the ends of the stringers, leading edge and spar. Will be back Sunday to continue the build. Now it is going to be finishing job. Should go well, the plane is small .
Played with the finished parts I had and layed them together to look at what the finished plane will look. I do this with every build, trying toi visualise the finished bird. Never tire of it
Old Nov 21, 2010, 10:53 PM
Quebec, Canada
Joined Sep 2006
All major parts built
Hi all ! I finished all the frame components except the wing struts. Weight is 2.4 oz or 68 grams with battery, servos and receiver. I am now sure that with the struts, motor, esc and covering I will be below 5 oz and maybe between 4 and 4.5 oz.
I made an metal elevator joiner to add strenght to the wood between both elevators and rounded the leading edge of all flying surfaces. I didn't bevel the leading edge of the control surfaces yet as I want to make the slots for the hinges first. I will add some sheeting to the hood in front of the cabin and to the firewall as it needs correction beeing a little crooked. Wings are not yet sanded but all else is.
Could anyone give me somme clue about down and right thrust for this plane ? Nothing is stated in the manual or on the plan (or I didn't see it...)
Please feel free to comment on the build and thanks for reading and watching the pics !
Old Nov 21, 2010, 11:12 PM
StevenatorLTFO is offline
Find More Posts by StevenatorLTFO
AKA - The "Flywheel"
StevenatorLTFO's Avatar
SOAR Chicago!!!
Joined Jan 2005
A couple degrees of right, and a couple degrees of down should be plenty.
StevenatorLTFO is offline Find More Posts by StevenatorLTFO
Old Nov 22, 2010, 10:12 AM
Quebec, Canada
Joined Sep 2006
thanks !
Old Nov 24, 2010, 12:14 AM
Quebec, Canada
Joined Sep 2006
Sanded the wings tonight, leading edge came out great. With the small size of the plane, at least there is not a lot of balsa dust to vacuum
Old Nov 24, 2010, 11:40 PM
Quebec, Canada
Joined Sep 2006
Had some nice shop time tonight. Built the wing struts (forgot the waxed paper, glued the struts to the plan don't do that if you want to see your drawings again...).
Also made some small CA hinges from a regular size one. Cut the corners so they would be easier to put in the slits I made in the elevator and rudder. Was afraid of making the slits since the wood parts are so delicate and small but all went well with a fresh blade. Also put a hinge in the bottom of the rudder where it meets the fuselage so the rudder is stronger (push rod will be on bottom of rudder and I don't want it to flex side ways with servo push or pull). I also beveled the leading edge of the rudder and elevator to ease deflection. Nothing is glued yet, I will glue the hinges after covering
(you didn't tought I had glued them yet did you ? )
Old Nov 28, 2010, 11:14 PM
Quebec, Canada
Joined Sep 2006
Hood, cowl ring and firewall
Got time for a little work tonight: I installed a cowl ring made with balsa to help attach and solidify the cowl. I used 1/16 and 1/32 balsa laminated cross grain to each other. I glued it with medium CA from the front of the cowl, letting the CA drip by the holes. I added magnets and added some thin CA to the wood to glue the magnets and solidify the balsa.
I didn't like the look of the model's front end on some pics where you can see all the stringers on the hood (between fiwall and windshield) through the covering. I find it also make the covering sag and dosn't give a nice shape. I added 1/32 balsa to remedy this. I damped it with alcool to help the wood bend over the curve without breaking.
My firewall was a little crooked and didn't look to robust, so I laminated a new1/16 balsa firewall shimmed with some 1/32 balsa. After sanding, the firewall front end is now perpendicular to the fuselage. It will also help to retain the motor without breaking.
Hope you like the build so far. Feel free to comment or point out mistakes if you see some.
Old Nov 29, 2010, 09:20 AM
monboy10 is offline
Find More Posts by monboy10
Enough Power? -NEVER ENOUGH!
monboy10's Avatar
North-Eastern Saskatchewan, Canada -Eh?!
Joined Apr 2008
looks great, can't wiat to see it fly
monboy10 is offline Find More Posts by monboy10
Old Nov 29, 2010, 12:10 PM
Quebec, Canada
Joined Sep 2006
Hey fellow Canadian ! Me too, can't wait to try it ! I'll make you a video hey ?
Looked at your micro champ's new paint: Wow ! Looks nice ! but aren't you afraid of scaring todlers at the gym ?
Thnaks for posting
Carguy
Old Nov 29, 2010, 04:58 PM
monboy10 is offline
monboy10's Avatar
Joined Apr 2008
i wish i could fly in a gym, i am freezing my a$$ off flying out in -25
Old Nov 29, 2010, 08:11 PM
Quebec, Canada
Joined Sep 2006
No need for a gym ! Here is what i do in the winter
The MCX Challenge (2 min 3 sec)
Old Nov 29, 2010, 11:37 PM
monboy10 is offline
monboy10's Avatar
Joined Apr 2008
i have a Mcx too and i love it! but i haven't beene able to get it to bind to the Tx
Old Nov 30, 2010, 09:13 AM
Quebec, Canada
Joined Sep 2006
I bought mine BNF and didn't have problem binding it to my DX7, but sometimes it takes several seconds to bind.
Guillows 24" Aeronca Champ looks like it was made by a CHIMP! nhorianopoulos Scale Kit/Scratch Built 19 Mar 21, 2015 04:46 AM
Discussion Flew my Guillows, Aeronca, and others...Oh My scigs30 Free Flight 21 Oct 22, 2010 10:42 PM
Discussion Guillows Aeronca Champ and Hellcat.. Vyceroy Scale Kit/Scratch Built 45 Nov 06, 2008 05:59 AM
Woohoo! Guillows Aeronca Champ Flies! ZRX Doug Parkflyers 18 Sep 24, 2003 08:31 PM
guillows 24" aeronca champ rubber to electric conversion davidbogart Scale Kit/Scratch Built 9 May 28, 2002 08:52 AM
