Espritmodel.com Heli Air
This thread is privately moderated by ToxicToast, who may elect to delete unwanted replies.
Old Nov 07, 2010, 09:47 AM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Skyburners Micro Yak R2
OK, this has been a very rewarding project and it flies great. I recently started a revision of the first prototype with a few goals, primarily weight savings related and tweaks to make it more survivable in a crowded indoor gym.
  • Pull Pull setup, eliminating the carbon control rods.
  • AR6300 with micro connectors & 3.7g servos
  • Drag Plates
  • EPP on the nose to improve survivability
  • Complete rework of the vertical milling
  • Gentle tweaks to the profiles
  • Tighten the slots for snug fitting.
  • Little color this time now that I know it will fly good
The primary goal of making a micro/near-micro indoor plane that still felt like a larger plane without the squirrelly-ness of the ultra micros out there currently. Capturing a hybrid of pattern and 3D was another of the major goals.
SPECS:
  • 23.2"/588mm WS
  • 25"/640mm
  • AUW: 80g
  • Dry weight: 66g
  • Hyperion 25c 2S 180: 13,6g
  • Alternate is the TP Pro Lite v3 250 2s (17g)
  • 3 3.7g servos (unmarked-same as RCTimer ones)
  • AR6300 used with DX6i
  • Pentium 6A ESC
  • HobbyCity 18-11 2000kv Micro Brushless Outrunner (10g)
  • GWS 5030 prop
  • 3mm EPP doubler CNC cut
  • 3mm Depron milled CNC cut
  • Radical RC biased control horn
  • UHU-POR and Mercury Foam Safe assembly.
  • Gorilla White on the doubler and epoxy to mount the lite-ply motor mount
Skyburners Micro Yak (4 min 53 sec)
Please forgive me if it seems like I am showing off, this plane is awesome for its size!
ToxicToast is offline Find More Posts by ToxicToast
Old Nov 12, 2010, 08:53 PM
Caster Of Pods
crash-man's Avatar
Waco, Texas USA
Joined Feb 2005
That is one SWEET little plane, Toast!!
crash-man is offline Find More Posts by crash-man
Latest blog entry: TheCrashCast.com - Episode 214
Old Nov 13, 2010, 09:14 AM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Thanks Crash!
Old Nov 21, 2010, 10:37 PM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Managed to shove the sticks to a FB so I could video!
Old Nov 21, 2010, 11:02 PM
Phlathead
ToxicToast's Avatar
Roseville, CA
Joined Aug 2006
Swapped the 18-11 2000kv with the GWS5030 out and put the 1306N 2200kv 9gr on it. Made quite a difference in performance. The 2000kv showed its inefficiency shortly into flight and had to use 90% throttle to break hover. The 2200kv on a 6030 did a great job at maintaining thrust and have head room left over for punch out, even after 5 minutes of flight time! Definitely recommend the 1306N for this weight class.
https://www.hobbycity.com/UNITEDHOBB...idProduct=8295
Discussion Micro Yak 55 v1 Nooflyer Indoor and Micro Models 23 Oct 13, 2010 04:18 PM
Discussion Skyburners Micro-mini Yak Design ToxicToast Foamies (Scratchbuilt) 0 May 29, 2010 12:33 AM
Discussion Hyperion Yak 54 40e R2? MikeVictor Scale Electric Planes 8 Aug 06, 2009 10:27 AM
Wanted Looking for Hyperion yak 54 40e, R2 color scheme MikeVictor Aircraft - Electric - Airplanes (FS/W) 4 Aug 06, 2009 09:53 AM
