Old Nov 07, 2010, 03:36 AM
WBFAir is offline
Find More Posts by WBFAir
United States, CT, Stamford
Joined Jan 2007
What makes a slow fly prop, a slow fly prop?
Hello all
Novice question I know, but physically what makes a slow fly prop, a slow fly prop?
Does it have like a wider cord and is meant for more torque then speed?
WBFAir is offline Find More Posts by WBFAir
Old Nov 07, 2010, 03:45 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
That's correct. The blade profile tends to be broader, they are also much lighter and therefore nowhere near as strong as a normal propeller, and so should not be used for high revving powerful motors.
leccyflyer is offline Find More Posts by leccyflyer
Old Nov 07, 2010, 04:24 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Some also have an undercambered airfoil to generate more thrust at a lower RPM.
Pinecone is offline Find More Posts by Pinecone
Old Nov 07, 2010, 04:49 AM
WBFAir is offline
Joined Jan 2007
Thanks for the quick 5:30am Sunday morning replys guys.
So on the new plane I built, the stock motor was about a 1400KV on a 1800 3S 20C pack fed via a 18A ESC
Sorry don't know the motors rated Watt specs.
In looking at the prop, it looks like it could be as you described, not to much pitch but kinda wide and light.
I replaced this motor with a Tower Pro, 1600KV 200W 25A and installed a MasterScrew, G/F 3 series, 8x5 prop and am using a 2200 3S 25C pack fed via a Castle Creation, 45amp Phoenix ESC (I know its big but I had it for three years and never used it.)
This "size" prop is what is recommended by the motor manufacturer although if it is that size but a slow prop, I don't know. It just says a APC, 8x4 or 8x5.
Btw the plane is a Hobbico/Flyzone Cessna 182 which is a 37.0 oz/1,050g plane (w/the 1800 pack), 47.5in wing with a 339in wing area.
Also btw that stock prop was 8.5in but I don't know the pitch but in comparing it to the 8x5 MasterScrew, it is easy to see that it is not a 5.
So any comments on any of this and thanks again for the reply's
Old Dec 22, 2010, 08:46 AM
Beachcomber is offline
Find More Posts by Beachcomber
Savannah, Ga, USA
Joined Feb 2009
I'm new at this (just adding planes to my heli hanger), but will offer this observation/suggestion:
Both the 1400 KV and the 1600 KV motors seems too fast (rpm) for a direct drive (prop mounted directly on motor shaft), using 3S Li-Po. It might be more suitable for 2S Li-Po (since the rpm is controlled by voltage). The larger your prop diameter, the lower max rpm it has; for many reasons but mainly because of tip speed. Double check to make sure 8" prop diameter is not too big for that KV/rpm.
Beachcomber is offline Find More Posts by Beachcomber
Old Dec 22, 2010, 11:22 AM
Art Schmitz is offline
Find More Posts by Art Schmitz
Crossville, TN
Joined Dec 2004
You really need to invest in a 'Watts Up' or similar device.
Art Schmitz is offline Find More Posts by Art Schmitz
Old Dec 22, 2010, 04:56 PM
cyclops2 is offline
Find More Posts by cyclops2
United States, NJ, Frenchtown
Joined Mar 2003
A motor / prop calculator will tell you what prop # of cells mahr capacity to get flying time. Plus WOT torque thrust...And top speed.
Try the free www.adamone.rchomepage.com Before you buy anything else. Watch the EFFiciency curve & percent.
Here is my favorite motor / prop combo. It tells all.
cyclops2 is offline Find More Posts by cyclops2
Sold slow fly prop 10*4.5SF/ 10*4.5SFP gemfan Aircraft - General - Miscellaneous (FS/W) 3 Nov 13, 2010 11:36 PM
Discussion What makes a plane a good wind flyer? MiddleMarc Electric Plane Talk 43 Oct 29, 2010 08:12 PM
Discussion What makes a plane Fly Slow?? Lamborghini12345 Scratchbuilt Indoor and Micro Models 15 Jun 26, 2010 10:23 PM
Discussion What makes a plane(gider) fly slow, steady and not sink? (much..) GreenAce92 Sailplane Talk 8 Mar 16, 2009 02:10 AM
who makes slow fly pusher props? mrittinger Electric Plane Talk 4 Jun 09, 2001 08:05 AM
