This thread is privately moderated by cleansurf2, who may elect to delete unwanted replies.
Old Nov 06, 2010, 06:40 PM
cleansurf2 is offline
Find More Posts by cleansurf2
cleansurf2's Avatar
Australia (Newcastle)
Joined Mar 2009
Data
Laminate film covering for RC wings info, AKA "New Stuff", "NS", "Lam film"
You may have heard about heat activated laminate film wing covering materials (aka. New Stuff or NS).
However getting specific details about this stuff, especially working out thickness is sparce and scattered. Different countries also use different measurement definitions which is confusing.
For all my info (what it is, how to apply it, conversion factors, material info and links).
Details Here
cleansurf2 is offline Find More Posts by cleansurf2
Old Nov 06, 2010, 08:04 PM
cleansurf2's Avatar
Joined Mar 2009
Laminate film covering for RC wings info, AKA "New Stuff" "NS"
Laminate film covering for RC wings info, AKA "New Stuff", "NS", "Lam Film"
What is it
Laminate comes in different types. What we are talking about here, has heat activated adhesive with a melting point of 210-250 farenheit. It is translucent and becomes almost transparent once applied, rigidy is also considerably increased once the glue is activated. Application is with an iron or heat gun. It can be applied directly to foam or other surfaces.
It is the same stuff used to cover posters, menues, etc..
The most familiar laminate most people will know, would be the pouch type used for printer paper. 80 Micron per sheet is the standard thickness of an A4 laminate pouch (standard printer size paper). Separating the 2 sheets from one of these standard laminating pouches is the easiest way for most people to access laminate for testing on a scrap piece of foam.
It does not SHRINK when applied. Care has to be taken not to deform the foam from excessive heat during application. Be careful not to induce wing twist or bend to the wing while applying the laminate.
Laminate comes in many different types with different properties, some work better than others for foam RC wings.
Why use it:
For foam wings, especially "Flying wings", laminate allows you to simplify a build and replace strapping tape and other coverings with an iron on covering that adds considerable support, rigidity, and a smooth/sleek finish all in one. Of course you can still complicate it with colouring, additional strength, foam surface finishers prior to application, etc...
Always apply top side of wing first, to avoid adding any ahedrial to the wing.
Beware of differing Measurements.
Defining a Mil A mil may not be a millimeter!
I'm Australian, a Mil (Millimeter) = 1000/Meter. (Metric)
In the USA, sometimes a Mil is expressed as 1000/Inch. (Imperial)
So big difference in what each Country expresses as a Mil.
Micron is standardised (I believe). So:
Metric: 1 micron = 0.001 millimeters (so: 80 Micron = 0.08 mil)
Imperial: 1 microns = 0.0393700787mils (so: 80 Micron = 3.1 mil)
Most info out there is expressed in either Micron or Imperial Mil.
Useful conversion data: (Imperial Mil to Micron), common sizes.
Note: This is total thickness plastic laminate plus glue.
9.824mils = 250micron
4.912mils = 125micron
2.952mils = 75micron
Some suppliers may express guage like this:
80 Micron (50/30). This is 50 micron plastic with 30 micron of glue = 80 micron laminate. Ratios of plastic to glue vary and often are not shown.
My experience with Laminate covering.
I have so far managed to get a hold of 3 different pieces of 80 Micron laminate. 2 out of 3 were good, one had poor adhesion and keeps lifting (I can re-activate the glue by ironing it again.
Used it on my last build of one of my light weight 40" wings (300 gram AUW), it's on my Blog. Very nice finish, easy, fairly robust. Way more rigid than my previous packing tape covered versions.
I have also bought 125 and 250 micron rolls from the "laminator warehouse" (USA) and both work great. The 250 gives a nice solid finish but a little heavy and application can cause wing distortion unless your very precise. I have only done scrap testing of the 125 micron so far, this will probably be what I mainly use for the bulk of my wings with 250 micron on the Leading Edge (LE). I will use the 80 micron on the smaller lighter wings.
I also recovered my Starfire 48" wing with it, over the top of monocoate. Stronger, smoother finish and a more rigid wing (it did add some additional weight though).
Best colouring Techniques:
After considerable experimentation with adding paint to the foam or glue side of the laminate, I wouldn't advise it, it reduces adhesion to much and gives fairly poor colour results. First laminate to the raw EPP wing, then on top of the laminate, the best colouring options are:
1. Iron on coloured covering film "monocoat's" http://www.hobbyking.com/hobbyking/s...idProduct=6702
2. Coloured packing tape
3. Spray Paint (may requires a base, 3M 77 Spray adhesive, primer, etc..)
Best colours for a flying wing (for easy orientation) are bright on top (orange, pink, yellow) and dark underneath, I find black with a couple of white stripes gives great contrast in most conditions.
Suppliers:
Most reference to using this stuff for RC builds is primarily sourced from:
http://www.laminatorwarehouse.com/la...aminating-film
Cheap to, but incrediably expensive shipping if your not in the USA.
Adhesive and rgidity properties may differ with other suppliers.
In Australia I have found, but not tried:
http://www.laminatingwholesalers.com...?page_id=29573
http://www.boundtoimpress.com.au/sho...h=64_12_104_20
RC suppliers small quantities:
http://wyowindworks.com/slopemonkeynewstuff.html
Helpfull links: Application, use, etc....
http://www.rcgroups.com/forums/showt...aminate+micron
http://rcglider.ning.com/profiles/bl...logPost%3A1462
http://www.rcgroups.com/forums/showthread.php?t=894604
http://www.rcgroups.com/forums/showt...ight=New+Stuff
http://www.rcgroups.com/forums/showthread.php?t=821598
Thread for the pictured "Phoenix wing" Black/Green Wing.
Back to my blog http://www.rcgroups.com/forums/member.php?u=255565
Old May 02, 2012, 08:16 PM
spaaarky21 is offline
Find More Posts by spaaarky21
Helicopter Baron
spaaarky21's Avatar
United States, CO, Golden
Joined Feb 2012
I've been looking for replacement film for my Assassin and this was helpful. Do you have anything to say about the different finishes - gloss, satin and matte? It seems like gloss might be bad for visibility on bright days.
spaaarky21 is offline Find More Posts by spaaarky21
Old May 12, 2012, 10:42 PM
cleansurf2's Avatar
Joined Mar 2009
CP Laminating Film was recommended by others and thats what I got. The gloss finish is fine for vis even without covering. I cover mine with HK monocote anyway. The satin might be better for painting? However you intend to cover, I would suggest applying colour to the surface as all my testing with colour underneath lead to poor adhession.
To protect monocote on the leading edge, I often apply another 5mil laminate on the leading edge over the monocote, gives extra strength also.
Repair: I have had success using an iron to repair LE dings, to bring it back into shape.
Old Mar 08, 2013, 10:59 PM
cleansurf2's Avatar
Joined Mar 2009
My experience after several builds with lam film, 5 and 10mil versions.
The 5mil is OK on light weight planes, however if you can aford the additional plane weight (performance sloper or DS wing) the 10mil gives a smoother sleeker finish. The 3mil is only for very lightweight low stress wings, it tends to krinkle a little as does the 5mil to a significantly lesser degree.
Rick.
Old Jun 07, 2013, 08:05 PM
cswann821 is online now
Find More Posts by cswann821
United States, MD, Frederick
Joined Jul 2009
In your tips for coloring techniques. Am I understanging correct, that first you add the Laminate, and then the colored heat film on top and or spraypaint on top of the laminate after adding a spray adhesive?
I am planning on getting my son an Assassin from crash testers, and I know he will want some color, so I was planning a black bottom and Red top w/ black strip on the right wing. Just trying to plan, the best way to do this. I've never used laminates on any of mine heli's or wings.
Well the paint really stick to the laminate well?
cswann821 is online now Find More Posts by cswann821
Old Jun 09, 2013, 08:41 AM
roo_ster is offline
Find More Posts by roo_ster
Standing Athwart History
roo_ster's Avatar
United States, TX, Dallas
Joined Mar 2011
Hit the CTH Assassin thread. I had the same questions. They suggest some brand of paint and then laminating while still wet.
Another method is to mix up some Marine Goop and toluene or xylene (50/50) and some testors little bottle paint and paint the EPP. Read a thread on that on RCG. Search for it. I can tell you the laminate goes over Marine Goop+xylene quite well. Use gloves/respirator/eyepro and do it in a well-ventilated area.
Frankly, I am not going to use paint, but colored packing tape & reflective tape over the laminate.
roo_ster is offline Find More Posts by roo_ster
Old Jun 17, 2013, 10:45 AM
cleansurf2's Avatar
Joined Mar 2009
If anyone has any more good info, please share.
*Direct links to relevant post within threads are most helpfull.
*Your experience/recommendations.
I will try to keep my first post consolidated info up to date with edits from recommendations from other builders.
Old Jun 17, 2013, 10:58 AM
cleansurf2's Avatar
Joined Mar 2009
Re colour over or under lam:
I have edited my recommendations to read clearer
I hear good things about marine goop, it can add some weight though, but for a power wing like an assasin, building as light as you can may be best, impact momentum is kept lower a thus less damage. I found paint under lam didn,t give strong colour contrast or adhesion (without goop).
I have pushed lam film hard' over 100mph on EPP DS glider wings, very robust stuff. Beyond that speed' I will be getting into moulding, as building an EPP wing to good DS performance standards is to time consuming, plus crashing at over 100mph, it doesn't really mater what a plane is made of, the results are often not good anyway (such is DSing).
Old Jun 06, 2014, 09:35 AM
82ndRCFLYER is offline
Find More Posts by 82ndRCFLYER
Sky Soldier
82ndRCFLYER's Avatar
United States, TX, Austin
Joined Jun 2013
where can you get small iron
82ndRCFLYER is offline Find More Posts by 82ndRCFLYER
Old Aug 08, 2014, 03:17 AM
cleansurf2's Avatar
Joined Mar 2009
Hobbyking sell small irons, but a standard cloths iron will do the job also.
Discussion Possible "new stuff" covering mistake? adso81 Painting and Finishing Tips 5 Oct 19, 2010 08:16 PM
Cool New Way To Colour New Stuff/laminate 14FELIX2 Slope 41 Aug 14, 2010 11:57 AM
Discussion Confused about this "New Stuff" covering KenP Slope 0 Nov 08, 2008 05:40 PM
Using Laminate Plastic As Covering manx Electric Plane Talk 4 Jul 25, 2002 01:51 PM
