Old Nov 06, 2010, 02:02 PM
garyji is offline
Find More Posts by garyji
AMA #937780
garyji's Avatar
Forrest City, NC
Joined Feb 2009
T-34 won't fly
Just took out my stock Eflite T-34 mentor for the first time. Calm evening on a grass field. Stock, fully charged batteries (3S 3200mah 15/20C eflite.) The plane doesn't have enough power to take off. It taxis well at full throttle but can't fly. The field is mowed quite low, but it was wet. My Nexstar Mini will fly off this field. I'm new at this, so am using the droops and "beginner" flaps. The batteries are about a year old and haven't been flown but have been "exercised" and stored properly. They came up to full voltage in about a hour at 1 C. Seems normal. Most of the You-Tube videos show the plane on pavement but a few show great take-off's from grass. Using a DX6i and all checks out there with throws etc. Have not done any "tinkering" with the ESC.
Any ideas?? Thanks,
Gary
garyji is offline Find More Posts by garyji
Old Nov 06, 2010, 03:16 PM
ZackJones is offline
Find More Posts by ZackJones
It's just a plane.
ZackJones's Avatar
USA, SC, Goose Creek
Joined Aug 2010
How about hand launching it?
ZackJones is offline Find More Posts by ZackJones
radialarm is offline
Find More Posts by radialarm
Stinger!
radialarm's Avatar
USA, TX, Boyd
Joined Sep 2009
Did you set your throttle range for your Tx in your ESC?
radialarm is offline Find More Posts by radialarm
Old Nov 06, 2010, 04:12 PM
garyji is offline
AMA #937780
garyji's Avatar
Forrest City, NC
Joined Feb 2009
Have thought about the hand launch, but was by myself. I'm pretty sure the Tx and Esc are set for full throttle.
G.
Old Nov 06, 2010, 05:08 PM
Ken Myers is online now
Find More Posts by Ken Myers
Ken Myers's Avatar
Commerce Township, MI
Joined Aug 2001
I've flown my students T-34 off the grass many times at our flying field. No problem. Don't use flaps!
Hand launching would be awkward and ill advised. The plane is extremely fragile in the front end.
Ken Myers is online now Find More Posts by Ken Myers
Old Nov 06, 2010, 05:32 PM
Art Schmitz is offline
Find More Posts by Art Schmitz
Crossville, TN
Joined Dec 2004
Are the numbers/letters on your prop facing forward ?
Sounds like the prop may be on backwards......
Art Schmitz is offline Find More Posts by Art Schmitz
Old Nov 07, 2010, 02:32 AM
miksta115 is offline
Find More Posts by miksta115
**RC MANIAC**
miksta115's Avatar
USA, CA, Rohnert Park
Joined Jul 2010
The prop isn't backwards... if it was backwards it wouldn't taxi at all, if anything it would go backwards
miksta115 is offline Find More Posts by miksta115
Old Nov 07, 2010, 04:10 AM
Mattvr1ck is offline
Find More Posts by Mattvr1ck
Australia, QLD, Brisbane
Joined Oct 2008
It wouldn't fly backwards, it will still fly normally. I know from experience, my noob brother built his pz messerschidt with the prop backwards and it was a pig to fly. Sounded awful and had no power. Turned it around and it flew great!
Mattvr1ck is offline Find More Posts by Mattvr1ck
Old Nov 07, 2010, 04:22 AM
Pinecone is offline
Find More Posts by Pinecone
Will fly for food
Maryland
Joined Sep 2004
Take a prop and look at it. Turning it over does NOT reverse the pitch of the blade. But it does make the airfoil backwards.
In the old days, we used to turn theprop backwards to reduce thrust for first flights to slow the plane down.
Pinecone is offline Find More Posts by Pinecone
Old Nov 07, 2010, 05:52 AM
venquessa is offline
Find More Posts by venquessa
UK, North Down, Bangor
Joined Nov 2009
It should be easy enough to check it.
Need to check your ESC manual, but *usually* the process is simply:
With the model off, battery disconnected.
Move the throttle to full.
Connect the battery.
Wait for a set of beeps (should be different that the normal ready beeps)
Move the throttle to idle.
Wait for the normal "ready beeps"
Go fly.
If you don't get the ready beeps, pull the battery out before you move the throttle again or you could be inadvertently reprogramming the ESC.
venquessa is offline Find More Posts by venquessa
Old Nov 07, 2010, 07:31 AM
Lberry.88 is offline
Find More Posts by Lberry.88
If in doubt, add accelerant
Lberry.88's Avatar
United Kingdom, England, Stansted Mountfitchet
Joined May 2007
Hell i still do that now
Lberry.88 is offline Find More Posts by Lberry.88
Old Nov 07, 2010, 08:58 AM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
Some observations and comments:
If the plane taxi's but won't take off, DON'T try a hand launch - certain crash!!
I know we all like to post helpful tips (well most of us), but if you think reversing a prop will make the plane go backwards........well, I'm not sure what to say next.
When setting the throttle range, prior to putting power to the rx, run your throttle trim all the way down. It rarely makes a difference, but it will with some esc's.
I know there are some out there who will cringe at this, but before I take a new plane out, I always do a static run-up holding the plane to confirm the power setup.
If everything is healthy, I would agree that most likely you have the wrong prop or it is on backwards. What prop are you using? And, a good suggestion above - the printing on the prop faces out.
Let us know what you find out.
Steve
sgomes is offline Find More Posts by sgomes
Old Nov 07, 2010, 09:52 AM
It's just a plane.
ZackJones's Avatar
Joined Aug 2010
Go fly.
If/When you do this please take the prop off first.
Old Nov 07, 2010, 09:59 AM
mrittinger is offline
Find More Posts by mrittinger
Gravity sucks.
mrittinger's Avatar
United States, MI, Roseville
Joined Dec 2000
Put a watt-meter on it and see what it's doing. Everything else is just guessing ....
mrittinger is offline Find More Posts by mrittinger
Old Nov 07, 2010, 12:52 PM
V2rider is offline
Find More Posts by V2rider
V2rider's Avatar
USA, MD, Hagerstown
Joined Jun 2009
+1.
I have had mine strapped to my Ultra stand with a fresh pack and it will pull itself and the stand across the garage floor NO PROBLEM. Something is off and a watt meter will point you in the right direction pretty quick.
V2rider is offline Find More Posts by V2rider
Alert Another Ultimate Hobbies Gem: $29.95 - 34" T-34 Mentor! hongrn Foamies (Kits) 75 Nov 04, 2011 11:46 PM
Discussion Slow Stick won't fly mbodradio Beginner Training Area (Aircraft-Electric) 15 Nov 11, 2010 05:13 PM
Discussion U.S. Won’t Recover Lost Jobs Until March 2020 At Current Pace FireryPhoenix Life, The Universe, and Politics 14 Oct 12, 2010 08:35 AM
Discussion OS .12 won't start abarickman Nitro and Glow Power Cars 6 Oct 11, 2010 08:19 AM
My Axi 2212/34 won't go full speed!!! joffacn Power Systems 5 Jun 15, 2004 09:53 PM
