Old Jan 11, 2011, 02:33 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Hmm.... In the testing I've done I have not had any problems. If you have "Empty Temporary Internet Files" selected under Control Panel, Internet Options, Advanced, Security.... then it will not load because your cached files have all been deleted.
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Jan 11, 2011, 02:47 PM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
I don't think I have those settings in either browser. (its Win7 but with Firefox) I didn;t really realise that the GE plugin used a browser. How do I know which one?
The PC is installed in a vehicle at my workshop so I can't look now.
BTW - the setup with our Atto V2 data was awesomely simple: COM, Baud and off it goes. Well done. Love the voice calls to.
Lomcevac is offline Find More Posts by Lomcevac
Old Jan 11, 2011, 05:04 PM
Entens is offline
Find More Posts by Entens
Joined Jun 2005
Also food for thought is that GE will only cache about 2GB worth of data to disk and only keep about 512MB in memory by default.
You can change that in GE options:
Important: Last time I checked the API documentation elevation data is not cached, so you may encounter problems where POI not positioned at ground level are not accurately rendered at the correct elevation.
Entens is offline Find More Posts by Entens
Old Jan 11, 2011, 07:27 PM
Brunswick, OH
Joined Nov 2005
Lomcevac, the embedded web browser is IE...so check your IE settings in Control Panel, Internet Options.
Entens, thanks for the heads up. I'm not 100% sure that the API uses those settings, but I didn't know it was user definable. Looks like I'll have to warn users about their system settings on startup and ask if they want me to change it for them.
Old Jan 12, 2011, 01:49 AM
Lomcevac is offline
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Thanks guys.
Will changing the caching settings in the stand-alone GE application have affect on the embedded GE? Obviously there's no menu access in the embedded GE... In fact I didn't download anything but the CGS App. Should I have downloaded the API too?
Old Jan 12, 2011, 08:44 AM
Entens is offline
Joined Jun 2005
Originally Posted by Lomcevac View Post
Thanks guys.
If the GCS is working for you, then you already have the GE plugin and API installed. Google short circuited the need to have both the GE client and plugin as they both use the same cache. By default the values at `HKEY_CURRENT_USER\Software\Google\Google Earth Plus\CachePath` and `HKEY_CURRENT_USER\Software\Google\GoogleEarthPlug in\CachePath` point to `C:\Users\[Username]\AppData\LocalLow\Google\GoogleEarth` (assuming you'r using Windows Vista or Windows 7).
Old Jan 12, 2011, 04:15 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
Happy, Ive been testing your GCS, good work, looking good!!!
A little request however. Do you think you could implement the standard SSC (serial servo controller) protocol for the antenna tracker? This protocol is used on the Seetron MiniSSC and has essentially become the standard for serial servo controllers. Most commercial controllers support this protocol now.
I have developed several controllers based on this protocol. Its simple to implement.
Most of this type control 8 servos, so you could allow a servo number selection for each channel, maybe allow mirroring/cloning to other channels etc.
The protocol consists of 3 bytes...
Byte1 - sync byte/qualifier(255) (can be changed to allow addressing)
Byte2 - servo # (0-7)
Byte3 - position (0-254)
If you would like to do this, I can provide the circuit, pcb files, and source for the controller to go along with it.
KKUSA is offline Find More Posts by KKUSA
Old Jan 12, 2011, 04:18 PM
Brunswick, OH
Joined Nov 2005
I actually added the Pololu protocol this morning... I ordered one for testing. I believe this same hardware will do MiniSSC as well... so yes, I'll add that as well...
I'll have to see how the 0 to 254 position works. I opted for Command #4 on the Pololu protocol because it uses the raw servo ms values instead of the 254 positions. I guess I'll need to edit the calibration routine to handle 254 positions instead of 2000 postitions.
Old Jan 12, 2011, 04:52 PM
KKUSA is offline
Joined Oct 2010
Awesome, but I think the Polulu protocol is quite a bit different,(it does support the SSC protocol however), which is fine. I was just hoping for a standard protocol that anyone could buy an off the shelf controller and it be usable, instead of a specific controller as most support the SSC protocol. Many people probably already have one that does.
The 255 position isnt bad actually, and more than usable for a tracker considering the divergence of reception/transmission patterns. "Ball-Park" seems to be as good as were gonna get anyway using these methods.
I do have a version that has 10bit resolution, but I dont think its necessary.
Old Jan 12, 2011, 06:02 PM
Brunswick, OH
Joined Nov 2005
Yes, I'm hoping to support everything under the sun.... The reason I brought up the Pololu was it supports SSC so I can test with it.... I can take a shot and just try implementing the protocol... but it's always easier with hardware to test. What is the "middle" position in the 254? 127?
Old Jan 12, 2011, 08:30 PM
KKUSA is offline
Joined Oct 2010
Great!!
Yep, mid is 127!!
I have a few ready to test. As soon as you get it done let me know and I will give it a shot.
Old Jan 12, 2011, 09:25 PM
Brunswick, OH
Joined Nov 2005
Version 1.1.36 is ready for you to test.
http://code.google.com/p/happykillmo...downloads/list
For now, I have not given any option to select Servo #. So 0 is Pan, 1 is tilt. Let me know if I need to make this configurable. Make sure you select MiniSSC, click connect and then click Calibrate. I need to know what the end points are...and using this function you can reverse the direction if needed.
I'm just sending 255,Servo#,0-254Output
ie: 255,0,127 (This would be 3 characters binary and would center the pan servo).
Old Jan 12, 2011, 10:44 PM
KKUSA is offline
Joined Oct 2010
It needs to be sent ASCII chars instead of binary, if thats what you are referring to in your example.
I will test in a bit.
Also, the servo # essentially does need to be selectable as the standard SSC protocol uses servos #9-18 for extended range. This can just be a check box for "extended range" and be done behind the scenes however. Choosing servo #9 will move servo 0 with extended end points.
Old Jan 12, 2011, 10:55 PM
Brunswick, OH
Joined Nov 2005
I'm using Chr(255) & Chr(0) & Chr(inputValue)... so yeah, ASCII character set, but it's not going to be human readable.
Old Jan 12, 2011, 10:57 PM
KKUSA is offline
Joined Oct 2010
Separate issue, so separate post.
The chase cam zoom level does not retain when zoomed in, it automatically zooms back out.
Also, can the model scale factor be reduced further, some still appear quite large even at minimum. It just adds a weird feel to it.
Sorry to be a bugger!!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Ground station wiring harness ziomatrixacs FPV Talk 3 Oct 07, 2010 05:48 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion Aerial Photography request an Autopilot system & Ground Control Station Atflying Aerial Photography 7 Jun 27, 2010 02:13 AM
