Old Sep 25, 2012, 10:13 AM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Very true! I'm actively looking for better GCS but will probably wait for the new APs to come out since they will likely be able to be used with a number of different GCS packages. I realize the the GCS developer has moved on to bigger and better things in life and won't knock him for doing so. HK works OK for my current uses but without further development or support it's pretty much a dead horse that's not worth beating......
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Oct 11, 2012, 05:44 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Help!
The manual says I can store WP files in the Missions folder then upload them to Atto.
I don't find a screen that recognizes the .txt files or lets me load them.
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Oct 11, 2012, 09:33 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
I think what it refers to is being able to make fligh plans within the GCS and save them. I've done it successfully that way.
Jimmy
Old Oct 11, 2012, 10:18 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Jimmy,
Thanks - I think that's it. I found the files in Program Files/HK/... They are a different format than standard Atto files.
I'll try the GCS tomorrow.
Thanks again,
Tom
Old Nov 03, 2012, 11:40 PM
Sethbourne is offline
Find More Posts by Sethbourne
Joined Nov 2012
HK GCS mavlink 1.0
Does HK GCS support for mavlink 1.0 ?
Sethbourne is offline Find More Posts by Sethbourne
Old Nov 04, 2012, 08:39 AM
wartoy is offline
Find More Posts by wartoy
wartoy's Avatar
United States, AR, Jacksonville
Joined Dec 2005
I would just be happy for a life size poster of Martin Y's avitar!
wartoy is offline Find More Posts by wartoy
Old Nov 04, 2012, 10:41 PM
Martin Y is online now
Find More Posts by Martin Y
400' ..... NOT
Martin Y's Avatar
Canada
Joined Jan 2009
Originally Posted by wartoy View Post
i would just be happy for a life size poster of martin y's avitar!
Same
Martin Y is online now Find More Posts by Martin Y
Old Nov 09, 2012, 09:21 AM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Has anyone tried the control buttons on the "Control" tab for RTL, Loiter etc with an AttoPilot? How about manual control via a joystick?
Thanks!
Jimmy
Old Nov 13, 2012, 01:47 PM
philthyy is online now
Find More Posts by philthyy
UAV Integrations
United States, WA, Battle Ground
Joined Nov 2005
I suspect its not so much that HK moved on to bigger and better things....its that RCG "moderated" him to the point of leaving RCG and never coming back. Just like many, many other serious, valuable content providing RCG members in the last couple of years.
philthyy is online now Find More Posts by philthyy
Old Nov 13, 2012, 01:58 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
I can't see them "moderating" people that provide content out. Content is what keeps people coming back.
Old Nov 13, 2012, 11:28 PM
UAV Integrations
Joined Nov 2005
Yep. I agree. But HK left because of the pathetic "points" system here and a total failure on RCG part to give him a valid effort at looking why or how he accrued points. Do you know who Timecop is? Or Ssassen? Even Trappy? They all left RCG because of the moderators. Or, should I say lack of moderators. And those are just the ones I know of offhand. And they were SERIOUS providers of valuable content.
Old Nov 26, 2012, 09:21 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Hey, Guys.
Anyone setup the antenna tracker using the Maestro controller and a 360 degree pan servo? I can control the tilt servo with no problem but can only get the pan servo to spin in one direction or the other. Any suggestions? Do I need to go back to a normal servo?
Thanks!
Jimmy
Old Dec 15, 2012, 05:24 PM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
Anyone been able to get the antenna tracker working with the Pololu Maestro and Atto? I can calibrate the servos but it won't track....
Jimmy
Old Dec 15, 2013, 10:05 AM
laciaty is offline
Find More Posts by laciaty
Poland, Masovian Voivodeship, Warsaw
Joined Dec 2013
Hi,
I'm trying to use HK with eLeReS connected to GPS,
but i don't recive right position on google maps.
laciaty is offline Find More Posts by laciaty
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4519 Aug 10, 2016 02:49 AM
Discussion Ground station wiring harness ziomatrixacs FPV Talk 3 Oct 07, 2010 05:48 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion Aerial Photography request an Autopilot system & Ground Control Station Atflying Aerial Photography 7 Jun 27, 2010 02:13 AM
