Canada, ON
Joined Jan 2009
should be possible. Go to his site, click the search arrow down and change to all downloads. It should be there.
http://code.google.com/p/happykillmo...+DownloadCount |
Wichita, Kansas, USA
Joined Jul 2003
Anyone found a suitable substitute?
Jimmy |
Latest blog entry: Ultrabatic BD-5J
Joined Jul 2003
Anyone having problems with the Google Earth Plug-in? I can get GE 5.2.1.1588 to load once in a while but normally it won't load and tells me to reload the plug-in. Typically can't get it to run even after installing the plug-in. Any thoughts?
Thanks! Jimmy |
Joined Jul 2003
Thanks, Gene.
I found that if I restart the program a couple of times it starts working. I also found that I can load the area that I'll be flying in at the shop and then turn off my wifi and set my computer to hibernate. When I get to the flying site I wake the computer up and have the maps preloaded. Works well and I don't need a wifi connection at the field. Setting up an Atto V3 in a Froo now and will be testing the antenna tracker on the next flights. Fun!!! |
Near Austin
Joined Dec 2001
Yeah, you need to weigh the benefits vs. the risks on that one. It is very difficult to justify putting a lot of work into a system that you know is "buggy" and has the record of support that it does. There is absolutely NO WAY you can build a commercial model off any open source software - BTDT - got the tattered T-shirt.
| Thread Tools | |
| Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) | JettPilot | Video Piloting (FPV/RPV) | 3099 | Today 10:21 AM |
| Discussion Ground station wiring harness | ziomatrixacs | Video Piloting (FPV/RPV) | 3 | Oct 07, 2010 05:48 PM |
| Discussion DIY Continuous Rotating FPV Ground Station | Moosthegoose | Video Piloting (FPV/RPV) | 37 | Sep 29, 2010 04:27 AM |
| Discussion Aerial Photography request an Autopilot system & Ground Control Station | Atflying | Aerial Photography | 7 | Jun 27, 2010 02:13 AM |
