Old Nov 05, 2011, 03:34 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
If you use HyperTerminal or another terminal program (like Termite) can you type $Q,0,0*FF<carriage return> and see what the result is?
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Nov 05, 2011, 03:50 PM
Tom Harper is offline
Find More Posts by Tom Harper
Lift is cheap - Drag sucks
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
I'm confused - I am using the GSC in my laptop and clicking on the 'Connect' button. Do I need an additional terminal program?
Where is the command line to enter $Q,0,0,*FF?
Tom
Tom Harper is offline Find More Posts by Tom Harper
Old Nov 05, 2011, 04:06 PM
Brunswick, OH
Joined Nov 2005
The additional terminal program is to eliminate the issue with the GCS. If you connect using a regular terminal program and send the command $Q,0,0,*FF you should get a readable response with A1, A2, A3 and A4 commands back from the Atto. If you don't get that back, then you either have the wrong baud rate, the wrong serial port or bad cabling.
Old Nov 05, 2011, 04:50 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
Thanks, good plan. When I go to HyperTerminal and set it for com7, it reports that it is connected but when I try to type in the window nothing happens.
Could we try to trouble shoot the GCS:
Are the connections I described above correct?
What should be the state of Atto when you communicate with it?
If I try to communicate at one baud rate and it fails, do I need to restart Atto before I try another rate?
Tom
Old Nov 05, 2011, 05:51 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
My connections were not correct. It should be:
Vsss-->Ground
/Res-->Open
Tx---->Tx
Rx---->Rx
I corrected the cable connection but I still do not get a response from Atto at any baud rate.
Tom
Old Nov 05, 2011, 06:46 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Ah___it seems to be working.
Tom
Old Nov 05, 2011, 09:52 PM
Brunswick, OH
Joined Nov 2005
Cool. I assume you found that Tx ---> Rx and Rx --> Tx?
Old Nov 05, 2011, 11:06 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
No, I used Res instead of Vss.
Tom
Old Nov 06, 2011, 06:10 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
Communication with the Atto 3.0 seems OK.
I am still not having any success with the v2.0 units. My set up must be OK because it works with the v3.0. I have tried 9600, 19200 and 38400 baud rates.
Any thoughts?
Tom
Old Nov 06, 2011, 07:19 PM
Brunswick, OH
Joined Nov 2005
I can't make any guarentees on v2. I don't own one.
Old Nov 06, 2011, 08:17 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Tom,
Serial communication can be some of the most aggravating of issues with any autopilot. I have been successful with both my V2.0 and V3.0 units - BUT - only with Xbee modems. I have several 9Xtends that I can get talking between computers, no problem. But try to get Atto to talk through them seems to be a lost cause.
My SET files are at the warehouse, but make sure you have the baud rate selected in the SET file the same as the modems.
Gene
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Nov 06, 2011, 08:28 PM
Brunswick, OH
Joined Nov 2005
Actually, maybe I do have a V2 instead of a V3. Not sure what to tell you. What firmware version do you have?
Old Nov 06, 2011, 09:01 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Gene,
Thanks, I'll check it.
Paul,
The firmware may be the problem. I have an email in to Chris for an update.
Tom
Old Nov 22, 2011, 11:12 PM
Bilox is offline
Find More Posts by Bilox
Registered Crasher
Bilox's Avatar
Melbourne, Australia
Joined Jul 2008
Hey!
Happy Birthday Happy!!
Bilox is offline Find More Posts by Bilox
Old Dec 02, 2011, 02:42 PM
Tom Harper's Avatar
Socorro, NM
Joined Jul 2004
Paul,
GCS is working with both Atto V2.0s and V3.0.
Next question:
When I upload a WP file to Atto does the GCS store it in Eprom location 0? As I understand it, Atto can store multiple WP files. Can this be done through the GCS?
My first priority is simply to upload a WP file that will be held by Atto after a power off. I need to hike into the field and fly a WP pattern without dragging the laptop along.
Tom
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4554 Today 06:33 PM
Discussion Ground station wiring harness ziomatrixacs FPV Talk 3 Oct 07, 2010 05:48 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion Aerial Photography request an Autopilot system & Ground Control Station Atflying Aerial Photography 7 Jun 27, 2010 02:13 AM
