Old Apr 22, 2011, 01:21 PM
CenTexFlyer is offline
Find More Posts by CenTexFlyer
Near Austin
Joined Dec 2001
Happy,
Was going over the trigger parameters and was wondering how you were going to implement them as a user definable value. In particular, I was looking at:
$87,Trigger time interval (2) = 5 ' Specify value between parenthesis for Trigger field 3 (4th from right)
$88,Trigger time interval (3) = 10 ' 0 is no trigger for that waypoint
$89,Trigger time interval (4) = 20 ' 1 is trigger at waypoint only
$90,Trigger time interval (5) = 60 ' 2-5 are time interval triggers, in seconds
$91,Trigger Distance interval (6) = 100 ' 6-9 are ground distance interval triggers, in meters
$92,Trigger Distance interval (7) = 150 ' Time interval allowed from 0 to 32767 seconds
$93,Trigger Distance interval (8) = 200 ' Distance interval allowed from 0 to 32767 meters
$94,Trigger Distance interval (9) = 500 '
These are listed under "Control" on the WAYPOINT tab, but only list the line numbers. Most of the mapping that we do and the cameras we use require us to put in a distance of 55 meters. Will there be a way to input a number like this in your interface? If that is the case, it would seem to make lines 88-90 and 92-94 unneeded.
Gene
CenTexFlyer is offline Find More Posts by CenTexFlyer
Old Apr 22, 2011, 01:54 PM
billh117 is offline
Find More Posts by billh117
arizona
Joined May 2008
Mapping completed ATTO missions in HKGCS
Morning Happy,
I was wondering what is the process for loading a recorded ATTO mission (off the ATTO's SD card) into the GCS.
The Data file tab area doesn't show me any file listings, it lets me change directories but shows no files to open.
Running V1.2.49
Maybe I am missing something?
Bill
billh117 is offline Find More Posts by billh117
Old Apr 24, 2011, 12:32 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
On my way home from Sparkfun. I'll respond tonight
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Apr 24, 2011, 12:34 PM
billh117 is offline
arizona
Joined May 2008
Great,
SparkFun is like an amusement park for guys like us :-)
Bill
Old Apr 24, 2011, 01:47 PM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
Originally Posted by CenTexFlyer View Post
Happy,
Gene
Gene,
Do the update and your wish will be our command!
airmcn_3 is offline Find More Posts by airmcn_3
Old Apr 24, 2011, 05:15 PM
alz3abi is offline
Find More Posts by alz3abi
Joined Oct 2010
Hk there is any problem with the new version of GCS ?
because when i connect i got 0.20% ~0.40% GPS MSG while in the previous version 1.2.49 i got 20~30% which is perfect.
any issue?
alz3abi is offline Find More Posts by alz3abi
Old Apr 25, 2011, 08:34 AM
Brunswick, OH
Joined Nov 2005
alz3abi, there have been 25 updates since 1.2.49.... tough to say.
Old Apr 25, 2011, 01:26 PM
alz3abi is offline
Joined Oct 2010
so what is the solution for 0.40% msg? with latest HK?
Old Apr 25, 2011, 01:59 PM
billh117 is offline
arizona
Joined May 2008
What ever I was missing in 1.2.49 I am missing in 1.2.75 also
Same thing I can open a directory but it shows no files
What am I doing wrong?
Bill
Old Apr 25, 2011, 04:26 PM
billh117 is offline
arizona
Joined May 2008
Well I copied the log file from the SD card to the desktop. Now the GCS sees the files but once loaded doesn't play, any ideas ?
Old Apr 25, 2011, 04:28 PM
alz3abi is offline
Joined Oct 2010
any have issue with new HK version " not responding" when your GPS try to lock and the software not responding ?
Old Apr 26, 2011, 02:40 AM
airmcn_3 is offline
Moore, Oklahoma
Atto Users
All Atto users,
Please be patient with Paul. He is working very hard to get the GCS as smooth and flawless as possible. It will not be long at all and we will have our own version of HKGCS. All "bugs" and functions will be fixed and or implemented very soon. We will need to test and test and do more testing to make sure it does not cause any issues. The current GCS works and well. There are a few known bugs that are being addressed and should be patched soon but nothing that should keep you from flying and enjoying your system.
Thank you for your patients and keep flying!
Chris McNair
Old Apr 26, 2011, 06:23 AM
billh117 is offline
arizona
Joined May 2008
Take your time Happy, I already have gotten much more use out of it than I have paid for.
I am just trying to make sure I am not doing something Stupid (Simple) wrong.
Chris do you have a log file you can send me that opens ? Maybe I can see what I am doing wrong?
Bill
Old Apr 26, 2011, 02:45 PM
Brunswick, OH
Joined Nov 2005
Atto log files currently do not open. Logs recorded with my GCS are .hko files and they will open.
Old Apr 26, 2011, 03:05 PM
billh117 is offline
arizona
Joined May 2008
OH ! did not know that.
OK thanks.
Bill
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4463 Yesterday 03:30 PM
Discussion Ground station wiring harness ziomatrixacs FPV Talk 3 Oct 07, 2010 06:48 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 05:27 AM
Discussion Aerial Photography request an Autopilot system & Ground Control Station Atflying Aerial Photography 7 Jun 27, 2010 03:13 AM
