Old Apr 01, 2011, 05:20 PM
HappyKillmore is offline
Find More Posts by HappyKillmore
Brunswick, OH
Joined Nov 2005
Have you tried that code on your ArduPilot Mega with the IMU connected? I haven't seen that code, it might work just fine.
HappyKillmore is offline Find More Posts by HappyKillmore
Reply With Quote  (Disabled)
Old Apr 01, 2011, 05:37 PM
alz3abi is offline
Find More Posts by alz3abi
Joined Oct 2010
i ordered it Arduinopilot ready, i didnt try to re install the code. do i need to use this code in arduino or U-center?
alz3abi is offline Find More Posts by alz3abi
Old Apr 01, 2011, 05:42 PM
Brunswick, OH
Joined Nov 2005
You need to plug your IMU into your ArduPilot Mega. Then open a new sketch in Arduino and copy and paste the code from the link above. Then compile and upload using your UDB cable connected to your ArduPilot Mega IMU board (just like how you program the ArduPilot Mega normally). Then connect using uCenter with your GPS connected to the ArduPilot Mega.
Old Apr 01, 2011, 06:01 PM
alz3abi is offline
Joined Oct 2010
this part not clear for me
and connect u-Center to the USB serial port at 38400 baud. The GPS should work. Once the configuration is uploaded for the first time, you need to change the baud rate in the sketch and upload it again. Restart u-center, and proceed.
after i uploaded the code and i opened the U-center and connected to my com port at 38k i got red light blinking in the u-center not sure what to do to upload the configuration?
Old Apr 01, 2011, 06:18 PM
cass3825 is offline
Find More Posts by cass3825
Joined Feb 2005
Sorry Billy, that was my fault 1.2.48 is uploading now. Melih's servo driver works great....got one here on my desk... I see what you mean. I had an extra CrLf that was messing things up.
That did the trick!
Thanks for the quick response!!!
cass3825 is offline Find More Posts by cass3825
Old Apr 02, 2011, 12:21 PM
alz3abi is offline
Joined Oct 2010
what Message should i get from GPS MSG and how much is the percentage?
Old Apr 02, 2011, 12:48 PM
Brunswick, OH
Joined Nov 2005
alz3abi, we're about as far off topic as we can get. I think you need to ask these questions at DIYDrones.com or start another thread asking how to test which messages your uBlox is sending. I'm afraid I've gone as far as I can.
Old Apr 02, 2011, 01:28 PM
alz3abi is offline
Joined Oct 2010
im actually looking for sat's fix @_@
Old Apr 02, 2011, 02:41 PM
Brunswick, OH
Joined Nov 2005
I just did a test and your uBlox is not sending NAV-STATUS and NAV-VELNED because your heading is not changing and you don't get any values for satellites. It is sending NAV-POSLLH because lat and long are updating and it's sending NAV-SOL because GPS lock is getting sent.
Your uBlox needs to send NAV-POSLLH, NAV-STATUS, NAV-VELNED and NAV-SOL to work correctly. This is not a GCS problem. It's a GPS problem.
Old Apr 03, 2011, 02:42 PM
alz3abi is offline
Joined Oct 2010
Dear HK,
i would like to know how to enable these things in my GPS or my GPS is broken?
the problem im not expert but i try to follow steps or guides. thanks in advance.
Old Apr 03, 2011, 03:37 PM
Brunswick, OH
Joined Nov 2005
Alz, your GPS is not broken. I'm investigating how to set your GPS correctly....
Old Apr 03, 2011, 04:01 PM
alz3abi is offline
Joined Oct 2010
thank you waiting your solution.
while im checking U-center software i came across this COnfig page it showing that that baud rate is 57k, im not sure if i have to change this baud rate to 38k or keep it as it is?
Old Apr 03, 2011, 08:46 PM
Brunswick, OH
Joined Nov 2005
No, there's a bug in that source code. Try using this:
Code:
void setup()
pinMode(19, INPUT);    //RX1
pinMode(18,OUTPUT); //TX1
pinMode(0,INPUT);      //RX0
pinMode(1,OUTPUT);  //TX0
void loop()
digitalWrite(18,digitalRead(0)); // RX0 --> TX1
//digitalWrite(1,digitalRead(19)); // TX0 <-- RX1
And you should be able to see the uBlox messages, but you can't send any messages to change settings using that code.
Old Apr 03, 2011, 10:02 PM
Brunswick, OH
Joined Nov 2005
So far, I have no solution. The code posted to use the APM as a pass-through makes use of both digitalRead and digitalWrite which take something like 16 cycles each. So that's 64 cycles to act as the pass-through. Apparently, that's not fast enough because as soon as the second line in the loop is added, it doesn't work anymore. So at this point, without an FTDI cable or a USB to serial converter, I don't have any way to set your GPS to the right settings. Again, I'd suggest posting your issue on DIYDrones or buying a cable....
Old Apr 04, 2011, 02:22 AM
alz3abi is offline
Joined Oct 2010
i already post but no solution. i will try to work with the FTDI cable .
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4517 Jul 12, 2016 01:32 PM
Discussion Ground station wiring harness ziomatrixacs FPV Talk 3 Oct 07, 2010 05:48 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion Aerial Photography request an Autopilot system & Ground Control Station Atflying Aerial Photography 7 Jun 27, 2010 02:13 AM
