Brunswick, OH
Joined Nov 2005
You'll need to use the Digi X-CTU application to make sure the baud rates are set the same as the telemetry parameter in Atto...
Chris is right, the best way to test it is to open some kind of serial terminal window (I use HyperTerminal or Termite for my testing purposes). |
Chris,
No, I haven't tried the Parallax serial terminal, but thanks for directing me. I have set the baud rates etc in the X-CTU app but I'll try and work with a terminal program just as you suggest. The Atto is fine, it definitely is something to do with the Xbees... Thanks! /Bjorn |
XBEEs working!!!
Hi again,
Just managed to setup the modems correctly and now everything works with the downlink too! Chris and HK - thanks for pointing me in the dircetion of the Parallax Terminal application. Much easier to use than Hyperterminal and it helped me to find the problem which was the Maxstream adapter board. I found a small Droids Xbee adapter I had laying around from another project which worked. What do you say about using the switching BEC to power the XBEE modem? Is that too risky considering everything else is powered by this Jeti SPIN switching 5.5v BEC (i e 4xservos, GPS, Atto)... /Bjorn |
congratulations ! By the way what kind of XBees have you in use ? Which frequency ? I'm curious because I've laying around a pair of XBee Pro 868 since a while and have planned to use it together with my FY-21AP and Happys GCS in the future. 2,4 GHz XBees is a nogo for me unfortunately because I need this frequency for the FPV video downlink.Cheers, Erwin |
Moore, Oklahoma
Cheers |
NJ
Joined Dec 2006
Xbee Modems
Has anyone flown with a Spectrum receiver on 2.4 ghz and the xbee modems in the same freq band?? I have been testing this combo out over the last week and they both seem to play nice together. I am using a 7000 receiver in the plane. I do this at work all the time but I wonder in the air.
Thanks CHris! I would like to buy an adapter from you and will send a separate mail.
Erwin - good to see you here! I ahve the 2.4 XBee pro and I intend to use a regualar 35 MHz tx/rx- The 868 MHz XBee has been discussed a lot since it will need to be reset from the autopiot/GCS in order not to stop communicating (see this thread earlier) but otherwise a good frequency if you have 2.4 GHz gear othewise... Let us know more about your project! Cheers, Björn |
I know the problem with the 10% duty cycle on the 868 MHz XBee Pro but 868 MHz is the only legal frequency band I can use in my case. For R/C I use Thomas Scherrer's 433 MHz long range system and for the video downlink a 2,4 MHz system, respectively a 5,8 MHz system for the mikrokopter. At the moment I'm very busy due to my dayjob but later then I'll post about my experiences with the 868 MHz XBees. Good luck further on all your activities Bjorn, I'm always very interested in your projects . By the way what's about your mikrokopter activities ?Cheers, Erwin |
Thanks Erwin and good luck to you too with the Xbees - I have been looking at them so I would like to hear how it plays out! The MK is flying well but I have found that I prefer fixed wing for AP but it's really nice to fly the MK both autonomously and manually.
The Viking UAV is now completely ready with the Atto installed and now only awaiting test flight... See attached pic. Cheers, Björn |
Thanks Bjorn,
very nice plane your Viking ! Can't wait for your future projects !Cheers, Erwin Quote:
| Thread Tools | |
| Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) | JettPilot | Video Piloting (FPV/RPV) | 3086 | Yesterday 07:34 AM |
| Discussion Ground station wiring harness | ziomatrixacs | Video Piloting (FPV/RPV) | 3 | Oct 07, 2010 05:48 PM |
| Discussion DIY Continuous Rotating FPV Ground Station | Moosthegoose | Video Piloting (FPV/RPV) | 37 | Sep 29, 2010 04:27 AM |
| Discussion Aerial Photography request an Autopilot system & Ground Control Station | Atflying | Aerial Photography | 7 | Jun 27, 2010 02:13 AM |
