Old Nov 06, 2010, 06:04 AM
WBFAir is online now
Find More Posts by WBFAir
United States, CT, Stamford
Joined Jan 2007
Feedback and a few questions on my first WattsUp meter readings.
Hello all
After three years of flying a TRex 450, I decided to take a stab at the planes so I bought a Hobbico Cessna 182 and am pretty much done with the build.
Via a thread on this board, it was recommended to me that a good motor upgrade was the TowerPro here:
http://www.hobbyking.com/hobbyking/s...idProduct=2046
combined with a MasterScrew G/F 9x5 prop here:
http://www.hobbyking.com/hobbyking/s...idProduct=8020
I am feeding this with a Turnigy 2200mAh 25C pack via a Castle Creation 40amp Phoenix ESC. (I know 40amps is high, but I had it for three years an figured why not use it.)
So to check things over myself, I just bought a WattsUp meter and hooked it up and ran it.
So to test it, one person recommended that I just runup the plane to full throttle for about 5 sec while holding it on the ground and when I did this I got the following peak readings:
465.8 Wp
40.4 Ap
To say that I was surprised and very concerned was an understatement as just to state this motor is rated at 200W and 25Amps.
So then I took the plane out on the tall grass with the meter attached and taxied it around doing several, from a dead stop applying a good amount of power to get it roll things, and got readings of like:
172.8 Wp
14.6 Ap
So is this kinda a normal thing, are most power setups for a plane that are as powerful as need to be for good flying always going to run high watts & amps if held like this and that to really see what the proper Motor/Prop combo is, you need to test it in flight?
As well if this is the case, should I and for how long, should I run it at full throttle while in the air?
If I did happen to get a result of over 200 at full throttle, should I really be worried about this?
If I did, should I do something like test it at 70-80% throttle, or what ever my normal throttle use is, and see what that is and then consider that over 200 at FT acceptable as I rarely and only for a few seconds will ever use that?
Another question I have is, I have gotten several sizes of Props, but would say going with a 9x4 or 8x6 really bring that 465.8W down to below 200 for the static test?
I'm guessing it wouldn't.
So if anyone has any feed back on any of this, I would appreciate it.
WBFAir is online now Find More Posts by WBFAir
Old Nov 07, 2010, 12:20 AM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
A 9x5 prop on that little motor with it's 1600Kv is WAY too much prop in my opinion. It would be much happier (and live longer) on an 8x4 prop (non-sloflyer type).
Have fun!
Sammy70 is offline Find More Posts by Sammy70
Old Nov 07, 2010, 04:33 AM
Joined Jan 2007
Yeah after doing some more research, it seems the by the manufacturer, they recommend a APC 8x4 or 8x5.
Think I'll give a MasterScrew 8x5 a shot.
Old Nov 07, 2010, 06:58 AM
bartricky is offline
Find More Posts by bartricky
Shelter Kitty "Orange Death"
bartricky's Avatar
United States, FL, Monroe
Now that you have a great new tool you can make many observations and adjustments. You will find you can use a larger prop with a 2S batt. than a 3S and sometimes it's necessary to get the plane to fly on 2S.
Now the fun begins..
bartricky is offline Find More Posts by bartricky
Old Nov 07, 2010, 08:11 AM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
I simply cannot believe that 40A/465W reading... there is no way that motor could draw that with a 9x5! Despite that, as others have said 9x5 is too big.... read the reviews in your HK link and you'll see that guys are using 7"-8" props.
GWS9050HD 2-blade 17A,7V,123W,25oz,203oz/Kw
GWS9050HD 2-blade 18.35A,7.5V,139w,26.8oz,193oz/kw
GWS8040 3-blade 14.57A,7.48V,105W,21.1oz,201oz/kw
GWS8040 3-blade 15.24A,10.5v,160w,163oz/kw
GWS8040 3-blade 14.57A,7.48V,105W,21.1oz, 201oz/kw
GWS8040HD 2-blade 11.67A,7.41V,84w,18.3oz,218oz/kw
I use a BM2409 motor, 7x6 APC prop, 35Amp speed control and United hobbies 3S1P 2200mah 20C Lipoly battery. 190 watts in a 20oz plane.
Gives 30oz thrust with 7x5 APC drawing 20A/220W on a 3S2100 15C.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Discussion My first lipo failure - and some questions rotagen Foamies (Scratchbuilt) 4 Oct 25, 2010 01:47 PM
Discussion First nitro in a long time a few questions Hance Fuel Plane Talk 20 Sep 22, 2010 10:48 AM
Help! Just bought my RC Car - Few questions Html33 Nitro and Glow Power Cars 5 Sep 14, 2010 11:20 AM
Discussion My first flight on new 450se v2 - a few quick questions Sl0flyer Mini Helis 2 Apr 15, 2010 06:48 PM
Question About WattsUp readings skesseks Mini Helis 2 Oct 01, 2005 04:25 PM
