Old Nov 05, 2010, 11:27 PM
Aerogance is offline
Find More Posts by Aerogance
Foam is your friend!
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
Contrails, vortex and pressure "clouds"
There has been a bit of discussion recently behind the scenes about contrails and other condensation effects. We are trying to figure out why we do not see such effects with our large and fast DS planes. Why do we not see such effects? Is it theoretically possible to generate such effects with a high-speed model glider?
(To clarify, a contrail is the result of jet engine gasses at altitude. I couldn't find a better term so I am using it loosely to indicate any type of condensation effect)
Aerogance is offline Find More Posts by Aerogance
Old Nov 06, 2010, 01:07 AM
prodjx is offline
Find More Posts by prodjx
prodjx's Avatar
Joined Jan 2007
That B-2 is going very fast, that 's caled vaping what happening is the surrounding air is compressing so much and it's compressing any h2o as well. It's not a contrail as it's only around the A/C.Now on the airliner photo the O/B flap's are creating a vortex. Contrail's are caused by a couple thing's like any moisture in the fuel tank's and various temperature's at different. Ever notice how they stop sometime's.
prodjx is offline Find More Posts by prodjx
Old Nov 06, 2010, 05:38 PM
Antonsoarer is offline
Find More Posts by Antonsoarer
Long to be flyin'
Antonsoarer's Avatar
Wirral, (UK)
Joined Dec 2003
Interesting, this thread has some good links and contributions on the subject:
http://www.rcgroups.com/forums/showthread.php?t=362140
Antonsoarer is offline Find More Posts by Antonsoarer
Old Nov 14, 2010, 10:47 AM
M Scherrer is offline
Find More Posts by M Scherrer
M Scherrer's Avatar
Toulouse
Joined Dec 2005
Even more cool with propellers
http://www.airliners.net/photo/Airbu...4d7cdb6d0c0f44
Mat
M Scherrer is offline Find More Posts by M Scherrer
Old Nov 15, 2010, 02:34 AM
skaffen is offline
Find More Posts by skaffen
Ook!
skaffen's Avatar
New Zealand
Joined Aug 2007
You don't have to be going that fast, as long as it's humid and the pressure differential is high enough
QANTAS A380 Amazing Wet LANDING 27L | LHR (0 min 57 sec)
skaffen is offline Find More Posts by skaffen
Old Nov 17, 2010, 10:16 PM
Steve Graham is online now
Find More Posts by Steve Graham
AMA L897187
Steve Graham's Avatar
NE Denver, CO
Joined Sep 2007
An engineer could tell you but I believe there is something about a large aircraft close to max L/D and the pressure differentials that leads to these kinds of vapor events. Watch airplanes around SEATAC and you will see it a lot. From what I remember seeing your more likely to view it during approach and landing when the wing is in a slow and steady configuration with maximum flap deployment and therefore close to L/D max. You do see it on takeoff right at rotation where occasionally the entire wing will break out into mist. After that I think that because the aircraft is generally continuously accelerating, moving to a smaller AOA, the phenomena is generally not seen as much. I've also seen this quite frequently during air shows when fighters do their high g demonstrations. I also think that the vortices created at the wingtips and sometimes around areas like the edge of the flaps further reduce pressures so that frequently you only get the vapor in these areas.
Steve Graham is online now Find More Posts by Steve Graham
Discussion Steam pressure control valve. Hye's Steam Boats 13 Oct 25, 2010 04:08 PM
Discussion Not without a fight...Tea Party group plans to keep pressure on... MtnGoat Life, The Universe, and Politics 13 Oct 25, 2010 10:13 AM
Gallery Above the clouds HD Aerial Footage stonekap Aerial Photography 48 Oct 15, 2010 09:00 PM
Question pressure pot hawaiianspork226 Composites Fabrication 17 Sep 21, 2010 06:17 PM
Discussion Contrails behind DS planes Psionic001 Dynamic Soaring 14 Dec 28, 2009 12:43 AM
