This thread is privately moderated by Heli Hacker, who may elect to delete unwanted replies.
Old Nov 05, 2010, 06:15 PM
Heli Hacker is offline
Find More Posts by Heli Hacker
Hang on, turbulence ahead
Heli Hacker's Avatar
St. Louis
Joined Dec 2007
Mechanical Gain on Tail
I want to document one of the differences between the FireFox 200 and the CopterX 250 that makes different gain settings necessary when using the PhuBar3 unit on these two helicopters. The CopterX 250 needs a much lower tail rate gain than the FireFox, mostly because of the difference in the tail rotor control arms (aka bell crank).
In the photos below, you see the FireFox control arm has a leverage ratio of about 1/2.6, where the CopterX ( and I believe the Trex 250 it is cloned from is similar) is 1/1.25. This makes for higher mechanical gain on the CopterX, which necessitates a lower electronic gain setting on the Phubar, or any other tail gyro for that matter. This is discussed in several threads on the Copter-X 250, Trex 250, HK250Gt, etc. Many people have problems with the tail wagging before they realize how different the 250 clone control arms are.
The tail servo link ball typically needs to be set further in on the horn than most people are used to, in order to compensate for the higher gain of the tail control arm.
On the CopterX, I have the tail servo ball link about 7mm out from the horn retainer screw, and tail rate gain of 17 on the Phubar3 seems to give good performance
On the FireFox, the link ball is 11mm out and the tail rate gain needs to be about 45 for good performance.
I believe tail rotor speed plays a role here too, since higher speed creates more force per degree of blade pitch. Plus the CopterX tail boom is about an inch longer, giving the tail rotor more leverage in counteracting main rotor torque.
Heli Hacker is offline Find More Posts by Heli Hacker
Discussion Another Newbie on the Block: Thank you all (or why not using high gain antennas VTx?) sircana FPV Talk 22 Nov 04, 2010 05:57 AM
Discussion tail mechanical center..... thermlin' Mini Helis 26 Jan 09, 2007 10:00 AM
telebee gyro gain on remote vs gain on gyro on trex djdaveq Mini Helis 2 Jul 10, 2005 11:29 PM
Fix tail wag with mix or gain? SkyCaptian Micro Helis 6 Apr 15, 2005 10:17 AM
Question How do i gain more tail rotor trim?(drgnfly) chopperusa Micro Helis 10 Nov 22, 2004 09:35 PM
