Old Jan 29, 2013, 11:15 AM
xmech2k is online now
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
Originally Posted by rcflyinff View Post
Sure wish they had a Batteries for Dummies book Thanks.....
Ta-daaa!!!
Everything You Wanted to Know About Electric Powered Flight
Go to post 10.
xmech2k is online now Find More Posts by xmech2k
Old Jan 29, 2013, 11:17 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
[QUOTE=rcflyinff;23966596]
Originally Posted by Herman Munster View Post
3300/40C in mine also
You defiantly want a higher C rating than 20 for a ducted fan.[/QUOTE
I thought I'd stick with the 2200mAH but raise the C rating to a 40. Does the higher C rating mean it will discharger at a slower rate, resulting in maybe a little more run time? I'm getting mixed suggestions from other guys I fly with. They say to stick with the 2200 so I can run in my other planes and just up the C. Sure wish they had a Batteries for Dummies book Thanks.....
What dbc said. If you want a longer flight time with your Turbo jet, a 3000mAh battery is a good choice, you'll just need to place the battery a little further back in the fuselage for correct balance. Always use a higher C rating with ducted fans, 30c at a minimum. You can use the lower C rated batteries but the will die an early death. You can still use your high C rated batteries in your prop planes.
Herman Munster is offline Find More Posts by Herman Munster
Old Feb 03, 2013, 06:45 PM
Eric Henderson is offline
Find More Posts by Eric Henderson
Eric Henderson's Avatar
United States, NV, Las Vegas
Joined Dec 2005
Originally Posted by jetmodeler View Post
Last night went down and added some CF to the tail to try to avoid all that flex. The stab and fin now have 1/16" x 1/8" CF spars. The stab spars extend about 1" in to the other side, then epoxy fill to bind together, the fin extends thru the fuselage and out the bottom. All CF is held in with superglue. This stiffened up the tails quite a bit, but if I did it again I would use a taller CF spar, maybe 1/16" x 3/16" or more. Overall, the next area of flex is the fuselage itself as it tapers down in the back. With the cold in NE Ohio right now it will be a while before it flies again to see if this helps.
Jim
I added some carbon fiber spars to my turbo twin. I used a 3/16 of an inch carbon fiber tube down the length of the fin right through to the bottom of the fuselage. I also added two short carbon fiber rods from underneath. This seems to stiffen things up rather nicely.
When it came to the stabilizer I used thinner rods and put one on the top and one on the bottom. I've done this several times on different foam wings using spars as thin as 1/16 of an inch. If you position them directly above each other you get a very strong result. I would have done the same on the fin, but I had already painted it and applied the decal.
Everything feels very strong and stiff. I will report back once I have flown the airplane. I was trying to fix a mild bouncing of the stab from the static thrust of my Dons wicked turbo units! I had not thought of trying to do a knife-edge with this airplane--but we shall see!!!!
Regards Eric.
PS. I just "typed" this with Dragon software that my daughter gave me for Christmas. If there are any errors you can blame my accent...
Eric Henderson is offline Find More Posts by Eric Henderson
Old Feb 16, 2013, 05:54 PM
Donnyd21 is offline
Find More Posts by Donnyd21
United States, OK, Oklahoma City
Joined May 2012
Did 3 flights on mine today, on the 3rd flight I noticed it was turning slower but didnt think much of it, on landing I saw that my right aileron's rod was missing! So it was flying on the left aileron only!
Donnyd21 is offline Find More Posts by Donnyd21
Old Feb 16, 2013, 06:13 PM
Cocg is online now
Find More Posts by Cocg
Fly and let Fly!
Cocg's Avatar
United States, CO, Grand Junction
Joined May 2010
If I was a passenger, I would have freaked..!!!
Cocg is online now Find More Posts by Cocg
Old Feb 20, 2013, 09:23 PM
Donnyd21 is offline
Joined May 2012
Haha, still managed to fly pretty good too, I only do scale flying with this plane with some high G turns, no loops or rolls (at least not yet)
Old Feb 26, 2013, 12:49 PM
rcplanes1234 is offline
Find More Posts by rcplanes1234
rcplanes1234's Avatar
United States, IA, West Des Moines
Joined Jan 2010
Hello everyone!!!! I have had my dynam jet for almost a half year now and have loved every second with it. I am wanting to make it a little more scale. I was wanting to hear anyones opinions on getting spoilers onto this thing. Anyone have any designs that have used to put spoilers into this thing! Thanks
rcplanes1234 is offline Find More Posts by rcplanes1234
Old Feb 26, 2013, 09:19 PM
skykingjwc is offline
Find More Posts by skykingjwc
Joined Feb 2013
Recommended flap position
I've had the TurboJet for a few months now, and I cannot seem to find a good balance between flaps, and landing speed. CG is at recommended location. I have flaps mapped to my 3 position switch and have experimented with different flap positions for landing, but can't seem to find the sweet spot. The manual doesn't really specify how much travel the flaps should have. Can anyone out there who has configured flaps for this bird give me a pointer. Thanks.
skykingjwc is offline Find More Posts by skykingjwc
Old Feb 27, 2013, 11:49 AM
captain MoMo is online now
Find More Posts by captain MoMo
Mach One
captain MoMo's Avatar
Joined Apr 2011
It's strange but I have tried flaps at 100% and at 0% and have not noticed any appreciable lift. I think the flap surface area as compared to the whole wing is either too little or the overall plane aerodynamics dictate otherwise. But it's still way too cool to have them work! It's a great little bird and I can't wait for good weather!!
captain MoMo is online now Find More Posts by captain MoMo
Old Feb 27, 2013, 03:29 PM
xmech2k's Avatar
Joined Jun 2007
Yeah, I was gonna say the same thing pretty much. Unless it's really windy, the flaps really don't seem to do much as far as I can tell. When really windy, she wants to float and balloon too much, so I just don't use them in higher winds. I landed once when I thought I had flaps down but they weren't, and I couldn't tell the difference.
Old Feb 27, 2013, 07:06 PM
blueprint is offline
Find More Posts by blueprint
FPV Pilot
blueprint's Avatar
Joined Sep 2007
just got my turbo jet and going to get it ready for FPV use.
not into the scale stuff but the plane interests me enough to give it a shot for FPV usage even though EDF's are horribly inefficient.
blueprint is offline Find More Posts by blueprint
Old Mar 06, 2013, 11:14 PM
FPV Pilot
blueprint's Avatar
Joined Sep 2007
Ready to maiden! FPV style!
Dynam Turbo Jet FPV Test. (2 min 45 sec)
Old Mar 23, 2013, 12:56 AM
Joined Jan 2010
Hey everyone. So I nosed my turbo jet into the ground. I hate looking at the thing all glued up so I went out and bought a new fuselage. Well i have come across an issue that I can not seem to figure out..... The way, as many of you know, the elvecator works is by using to push roads that connect to one servo. Well I cant seem to find a way to make both sides travel the same distance. I put it into the last to holes closes to the servo and one will travel further then the other making one elevator move more then the other. Could some please advise what I am doing wrong! Thanks
Old Mar 23, 2013, 01:22 AM
xmech2k's Avatar
Joined Jun 2007
IIRC, there was a gizmo on the servo arm, similar to the ones out on the control horns, that both pushrods would go through(In the same hole), then you used a set screw to hold them in place. I'd have to see mine to be sure, but that kinda looks like what's getting pictures in the manual.
Old Mar 23, 2013, 07:53 AM
dbc is offline
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
Unequal rod throw is inherent in this design. You can mostly correct it by placing the rod clevises in different holes on the elevator horns. Farther out for the longer travel rod, and one hole closer in on the other side for the rod with less travel.
dbc is offline Find More Posts by dbc
Lifelike Turbo Jet 2000 conversion budgetfly Foamies (Kits) 22 Feb 25, 2006 07:02 PM
TJ3D... (Wal-Mart Turbo Jet 2000 conversion) ScottChase Foamies (Kits) 10 Sep 11, 2003 02:27 AM
Turbo Jet 2000 EDF thelocust Foamies (Kits) 1 Mar 05, 2002 09:28 PM
Twin Jet and Permax turbo 450 setup geoff.sim Foamies (Kits) 3 Jun 08, 2001 12:25 AM
