Old Apr 03, 2012, 12:43 AM
Westwood is offline
Find More Posts by Westwood
Canada, BC, Burnaby
Joined Oct 2010
Originally Posted by Sammy70 View Post
Kind of quiet in this thread...
Is that because everyone is out enjoying their TurboJet?
Wondering how many of you are running 4s with the stock escs and how they are holding up?
mike's trubo jet fan need some balance holding up good with 4s battery
Mike flying new DYNAM Turbo jet (6 min 19 sec)
sound of nice balanced edf with 3s battery
EDF run up (2 min 29 sec)
i fly my with 2600mah 4s all the time with stock esc & fan no issue at all
Dynam turbo jet (4 min 21 sec)
like my video here is link to my channel ---- www.youtube.com/user/9westwood9
Westwood is offline Find More Posts by Westwood
Old Apr 03, 2012, 07:14 AM
Sammy70 is offline
Find More Posts by Sammy70
JOHN 3:16 STILL APPLIES
Sammy70's Avatar
Central Ohio
Joined Feb 2008
Cool, thanks for the info Westwood...
Sammy70 is offline Find More Posts by Sammy70
Old Apr 04, 2012, 06:07 PM
sj3cub is offline
Find More Posts by sj3cub
North Carolina
Joined Sep 2003
If that guy in the first video would just learn how to slow that baby down, he would be fine. That jet in the third video sounds sweet.
sj3cub is offline Find More Posts by sj3cub
Old Apr 07, 2012, 12:03 AM
bamaguy is offline
Find More Posts by bamaguy
Don't Move I've Dropped My Nut
bamaguy's Avatar
United States, AL, Huntsville
Joined Feb 2009
Got it!
Ordered on Apr 1 and received Cessna 500 today...No damage, no missing parts..and the retracts work! The EDF's/ESC's even function. Both need a bit of balancing, though. A lot of plane for $118 bucks.
bamaguy is offline Find More Posts by bamaguy
Old Apr 07, 2012, 12:20 AM
Herman Munster is offline
Find More Posts by Herman Munster
Herman Munster's Avatar
United States, Mt, Libby
Joined Nov 2007
You won't regret buying it. It's a fun easy flying plane.
Herman Munster is offline Find More Posts by Herman Munster
Old Apr 07, 2012, 12:46 AM
xmech2k is offline
Find More Posts by xmech2k
xmech2k's Avatar
United States, CA, San Diego
Joined Jun 2007
The secret's out!
xmech2k is offline Find More Posts by xmech2k
Old Apr 07, 2012, 08:13 AM
dbc is online now
dbc
Find More Posts by dbc
dbc
United States, FL, Brooksville
Joined Apr 2008
I've just completed assembly of my second Turbojet. My first one was the fixed gear version and balanced nicely. It occurred to me while looking at this retract version that it could be nose heavy because of the added 30g nose wheel retract.
Sure enough, it's way nose heavy without adding about 3/4 oz to the tail. Other option would be to modify the battery compartment to move the battery further back into the fuse.
Retracts were added without making provisions for this - the rest of the plane is identical to the fixed gear version. They didn't even update the manual which still has pictures and assembly instructions for the fixed gear.
I'm a little disappointed in this. The fans could have been moved back just a little in the nacelles to rebalance the plane.
Anyone else noticed this? How did you get the CG back to 55-60mm?
dbc is online now Find More Posts by dbc
Old Apr 07, 2012, 08:49 AM
Sammy70 is offline
Sammy70's Avatar
Central Ohio
Joined Feb 2008
What battery were you using?
Old Apr 07, 2012, 11:47 AM
dbc is online now
dbc
dbc
Joined Apr 2008
3s 2200mah 30c turnigy. 190g. Same one that balanced fine in fixed gear plane. Looks like any 4s would require lots more tail weight.
Old Apr 07, 2012, 11:53 AM
dbc is online now
dbc
dbc
Joined Apr 2008
I'll probably maiden it with about 1/2 oz tail weight, still slightly nose heavy.
My previous experience with this plane was that it tends to land a little fast w/o flaps. Forward CG is probably going to make this even more pronounced.
Old Apr 07, 2012, 11:56 AM
robusp is offline
Find More Posts by robusp
Takeoff=Option Landing=Must
robusp's Avatar
USA, NY, Depew
Joined Jan 2009
I am flying mine on 2x3s. I modified harness to accept 2 packs. Put paper towel cardboard core as a new battery compartment. Front pack is just about even with canopy opening.
I am also getting 8 min flying time.
Rob
robusp is offline Find More Posts by robusp
Old Apr 07, 2012, 02:44 PM
dbc is online now
dbc
dbc
Joined Apr 2008
Yeah, I'm going to have to get that battery further back in the fuse. Im ok with the shorter flight times of a single pack. With the slightly fragile retracts, I prefer to keep this plane as light as possible. Looks like one 2200 would need to be moved back a little over an inch. I'll probably remove the rear ledge and make a light ply extension for the compartment.
I just wish Dynam would have done a more careful job when they added the retracts. Still a sweet little plane. I really missed my first one and I'm sure I'll enjoy this one, too.
Old Apr 07, 2012, 08:07 PM
Doug W is offline
Find More Posts by Doug W
Doug W's Avatar
United States, WA, Seattle
Joined Jul 2010
http://www.youtube.com/watch?v=uLNJKWTQSdo
http://www.youtube.com/watch?v=GP-V8dE-v2s
http://www.youtube.com/watch?v=R7-_KL8LqHU
How much C rating on 4S 2600?? I've probably 150 landings on my Turbojet and am all but bored with the 3S 25C power. I just tried a 4S 5000M, 45-90C on the bench (no chance it'd lift a 5000 pack), but am curious how much C rating the ESCs can handle.
Doug W is offline Find More Posts by Doug W
Old Apr 08, 2012, 12:05 PM
Westwood is offline
Canada, BC, Burnaby
Joined Oct 2010
that was 4s 2600mah 25c battery from my fms T-28,
as far as cg go, if you move back 3/4 inch you be fine
Old Apr 09, 2012, 12:02 AM
Doug W is offline
Doug W's Avatar
Joined Jul 2010
Thanks Westwood, and I assume no burnout on stock ESCs? (I have not set up a separate UBEC on this plane as cost just isn't worth it to me.)
Lifelike Turbo Jet 2000 conversion budgetfly Foamies (Kits) 22 Feb 25, 2006 08:02 PM
TJ3D... (Wal-Mart Turbo Jet 2000 conversion) ScottChase Foamies (Kits) 10 Sep 11, 2003 03:27 AM
Turbo Jet 2000 EDF thelocust Foamies (Kits) 1 Mar 05, 2002 10:28 PM
Twin Jet and Permax turbo 450 setup geoff.sim Foamies (Kits) 3 Jun 08, 2001 01:25 AM
