Espritmodel.com Heli Air
Old Dec 22, 2011, 08:34 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
Originally Posted by robusp View Post
I've flown my jet yesterday and today.
Yesterday was little scary with 25mph winds.
Only issue I had was with the retracts.
They didn't retract on last flight and had to be belly land.
I tried them later and they work sometimes.
Does anybody knows how to make them work every time?
Are they better running on 6V instead of 5?
Rob
Check and make sure your wheels are not rubbing or pressing down against the foam in the wheel well. These electric retracts have a fail safe cut off if they can not fully close without resistance. If the wheel is pressing hard against the foam when wheels are up, you may have to remove the two screws closest to the fuselage and lift the plate up and insert washers so when the wheels are up they are not pressing against the foam wing. Lube your worm gear with Marvel Mystery oil.... only one small drop should do it. Hope this helps.
d_toolman is offline Find More Posts by d_toolman
Old Dec 24, 2011, 12:01 AM
Tape n' glue, Good as New!
Chilliwack, B.C. Canada
Joined Aug 2009
Well, I cut out the flaps tonight n' fired her up to make sure the major electronic components worked before I glue it together. Yep, all systems a' go. Boy those are some noisy retracts though! Yikes! EDF's seemed fine @ half throttle, Baby sleeping in other room so that's as far as I got w/ that. Well, have to wait till after Christmas to put her together what w/ all the family do's we got planned.
To those posting top speeds ( I read "tops out at 70 something mph" and "got 65 mph" ) with what are you measuring and more importantly, is that flat level flight? Or in a steep dive?!! Cheers!
jussyjonny is offline Find More Posts by jussyjonny
Old Dec 24, 2011, 07:30 PM
d_toolman's Avatar
Florida,USA
Joined Feb 2011
To those posting top speeds ( I read "tops out at 70 something mph" and "got 65 mph" ) with what are you measuring and more importantly, is that flat level flight? Or in a steep dive?!! Cheers! Mine topped out at 79 mph with a 3 mph tail wind and flat approach towards radar gun. Here is my Turbo Jet greasing in.
Old Dec 24, 2011, 10:31 PM
Just gotta mod. it
canadianufo's Avatar
Northern British Columbia
Joined Dec 2006
Too much winter to fly so I'll drive it on the snow instead.
canadianufo is offline Find More Posts by canadianufo
Latest blog entry: flight delay
Old Dec 24, 2011, 10:52 PM
"LiPo-Blaster"
RugFlyer's Avatar
Duluth, GA
Joined Apr 2009
Now that's a great alternative when you can't take her up!
RugFlyer is offline Find More Posts by RugFlyer
Old Dec 26, 2011, 12:03 AM
Joined Aug 2009
Mine topped out at 79 mph with a 3 mph tail wind and flat approach towards radar gun. Here is my Turbo Jet greasing in.[/QUOTE]
WOW! I never would have thought it poss. w/ a $139 PNP foamie jet! Now I'm really looking forward to getting mine in the air. I spooled her up again today for some interested family members this time @ WOT and she def. has some power. I'd read only 300-400 watts total, (and she weighs in @ over 1 kg!) so hearing she does over 70 mph is a pleasent surprise.
And MERRY CHRISTMAS everyone!
Old Dec 27, 2011, 04:21 PM
North Carolina
Joined Sep 2003
Is everyone balancing their fans? I "re-worked" my fan housings and balanced the fans, and it made a huge difference. They are smooth as silk now. I think this is necessary with these low cost fan units. My fans were way out of balance, they not only sounded horrible, they were robbing tons of power. Has everyone else found this to be true?
sj3cub is offline Find More Posts by sj3cub
Old Dec 29, 2011, 11:38 AM
Canada, BC, Chilliwack
Joined Aug 2011
I have one on order and would love to know how to balance fans. Please explain. Thanks
jhblock2002 is offline Find More Posts by jhblock2002
Old Dec 29, 2011, 11:49 AM
Joined Aug 2011
Has anyone hand launched the Turbojet? Just wondering if that is a possibility.
Old Jan 02, 2012, 12:16 PM
Just gotta mod. it
Joined Dec 2006
short vid on a windy day.
windy day snowjet test (1 min 0 sec)
Old Jan 02, 2012, 01:48 PM
Just gotta mod. it
Joined Dec 2006
a couple touches yet to do. Broke the canopy so untill a new one gets here this will do.
Old Jan 02, 2012, 02:01 PM
Just gotta mod. it
Joined Dec 2006
Comes in many colors and seems to be very foam safe...for dynam products anyway. I used a flat black but a gloss would look great too.
Old Jan 02, 2012, 06:59 PM
simplefly
United States, IL, Glen Ellyn
Joined Sep 2010
Here is mine. I just finished it 2 days ago.
simplefly is offline Find More Posts by simplefly
Old Jan 02, 2012, 10:01 PM
Just gotta mod. it
Joined Dec 2006
Nice, I like the colors. I WILL maiden this thing this month...
Old Jan 03, 2012, 12:31 PM
AMA 125691
wmcneal's Avatar
Jacksonville Florida
Joined Jul 2002
power question
A friend of mine has one of these turbo jets, but can only get a 2 minute flight even with a 4s 2650mah 40c battery and flying mostly at half power. He says it is drawing 62 amps statically with both motors running full power.
By my calculations he should ideally be getting 2.5 minutes at full power and ~ 4.5 minutes running about half power.
Do these numbers look about right to you all?
What are typically some running times you are getting with 3s-4s batteries?
Could the esc's timing be adjusted to give more flight time?
Thanks.
Bill
wmcneal is offline Find More Posts by wmcneal
Latest blog entry: A beautiful morning 05-08-2013
Lifelike Turbo Jet 2000 conversion budgetfly Foamies (Kits) 22 Feb 25, 2006 07:02 PM
TJ3D... (Wal-Mart Turbo Jet 2000 conversion) ScottChase Foamies (Kits) 10 Sep 11, 2003 02:27 AM
Turbo Jet 2000 EDF thelocust Foamies (Kits) 1 Mar 05, 2002 09:28 PM
Twin Jet and Permax turbo 450 setup geoff.sim Foamies (Kits) 3 Jun 08, 2001 12:25 AM
