Turbojet Video
I had both my Turbojet and camera at the field the other day and shot some video while a friend took the jet for a spin. The nose gear didn't make it all the way up on this flight so please overlook the bump under the nose.
Beaverton, Oregon
Joined Jul 2003
![]() May I ask what size battery you're using with yours? I've been using a 3S-3300 with mine for longer flight times (10 min +/- ) but I had a tough time adjusting the battery position to get the right CG. And I've never had such a smooth "greaser" landing like yours in the video. Do you happen to know the exact flying CG you're using now? (BTW, I'd never have noticed the nose gear "bump" if you hadn't mentioned it... )Regards, -- Rod |
RRobbins
I use the CG as listed in the instructions. I'm using a 2650 mAh 3 cell. The larger battery and the gear drove the nose weight up. What I did to get it back was to remove the foam stop at the rear of the battery tray allowing the battery to slide further back into the fuselage. I used a coat hanger wire and bent it to form a squared off "U" with tabs that pushed into the foam and used epoxy to hold it down. This provides a backstop that is further back allowing the battery to move back without flying all the way to the rear. That allowed the CG to come in right where described. |
Beaverton, Oregon
Joined Jul 2003
![]() My TJ is currently retired. I stalled it on landing about a month ago and caved in the nose pretty bad. I had already replaced the fuselage once and it was a tedious job. I think I'm going to wait for Nitroplanes to get the "new, improved" TJ with retracts back in stock and reorder. It'll probably take less time to build the whole ARF than to replace the fuselage on an old one. Anyway, good luck with yours. Flies great! Regards, -- Rod |
United States, GA, Marietta
Joined Oct 2011
I've been flying mine for a couple of weeks now and I really like it. It's my first EDF but it was a very easy transition for me (other planes are PZ T-28, P-47 w Flaps & retracts, FMS 1400mm Zero). I just put flaps in last night and while they definitely aren't required, they sure do make the landings look nice!
I also thought I'd share a tip regarding the differential elevator movement on the stock setup. Rather than solder the push rods (a good idea, but my soldering skills are cr*p), I just attached the outer pushrod to the second hole down on the control horn. The inner rod stayed on the outermost pushrod hole. Voila - symmetrical movement! It's also perfectly balanced with a GensAce 3S 2200 mAH battery. Of course, I have a few complaints about the plane as well. First, both main struts came with the flat spots ground at angles that weren't square, so the mains were at odd angles and the plane crabbed badly when taxiing on the ground. That's lousy QC in my opinion and could have easily been avoided by using a proper jig. As a quick fix, I basically had to take out the gear, loosen the set screw, and push the strut in just enough to be off the flat spot before re-securing. No issues or slippage after 5 flights and the wheels still have clearance in the wells. Also, for some reason one of the mains occasionally refuses to extend. It seems intermittent and I haven't figured it out yet. It's probably related to the cheap Orange RX I'm using. But in the air, she's a beaut and she has gotten lots of positive comments at the field. For the price I highly recommend this plane. Out of curiosity, has anyone tried flying the stock fans and ESCs with a 4S? Also has anyone else had gear issues (deployment and/or bad flatspot grind) on the stock Nitroplanes ARF w/ preinstalled retracts? I'm debating whether it's worth asking for replacements, or if these are just known "undocumented features" of the cheap hardware. |
About the retract intermittently working, I had to put a drop of Marval Mystery oil on the worm gear.... must have been a small piece of dirt not allowing the retract to fully retract the last turn so it would reset. These retracts have small dip switches that the worm gear carrier has to hit in order for them to work in the opposite direction the next time voltage is applied. Just keep them clean is the best info I can give you. My mains were straight but I have had others that were not ground in the right place and had to regrind them. I fly my Turbo Jet with 3 cell 3300mAh sky lipos but a friend of mine just flew his yesterday on 4 cell. He never went above 1/2 throttle though and the battery was hot when he landed. I am waiting for him to fly it the entire flight on 4 cell before I decide if the ESC and motors can actually handle it..... I was waiting to see con trails yesterday.
Chilliwack, B.C. Canada
Joined Aug 2009
Just got my "Turbo Jet" today! Took the family out to SN Hobbies to pick 1 up after comparing it w/ the FMS F-16 + the FMS Mirage 4000. I was going 2 get the Mirage, but after seeing the Quality looking e-tracts in the turbo, I couldn't resist it. Hope they work as great as they look! One of my fan housings has a major groove in it, but I'm hoping I can get the fans centered. Also picked up an LED Nav. light set and I have a couple servo's lying around for the flaps, so looking forward to getting this one together. Glad 2 see some fellow Canucks on this thread as well. Cheers!
I've flown my jet yesterday and today.
Yesterday was little scary with 25mph winds. Only issue I had was with the retracts. They didn't retract on last flight and had to be belly land. I tried them later and they work sometimes. Does anybody knows how to make them work every time? Are they better running on 6V instead of 5? Rob |
| Thread Tools | |
| Lifelike Turbo Jet 2000 conversion | budgetfly | Foamies (Kits) | 22 | Feb 25, 2006 07:02 PM |
| TJ3D... (Wal-Mart Turbo Jet 2000 conversion) | ScottChase | Foamies (Kits) | 10 | Sep 11, 2003 02:27 AM |
| Turbo Jet 2000 EDF | thelocust | Foamies (Kits) | 1 | Mar 05, 2002 09:28 PM |
| Twin Jet and Permax turbo 450 setup | geoff.sim | Foamies (Kits) | 3 | Jun 08, 2001 12:25 AM |
