Old Nov 05, 2010, 06:20 AM
TheNiceGuy is offline
Find More Posts by TheNiceGuy
Expat
Japan
Joined Apr 2010
Kite RC conversion
Hi all
I have a couple of high quality nylon kites. I was thinking of designing some kind of motor pod to hang below to turn it into an RC kite. Anyone done something like this? Any pointers?
Thanks!
TheNiceGuy is offline Find More Posts by TheNiceGuy
Old Nov 05, 2010, 11:07 AM
jrbackus is offline
Find More Posts by jrbackus
3...2...1...See'Ya!!!!
jrbackus's Avatar
Minneapolis
Joined Jan 2006
Originally Posted by TheNiceGuy View Post
Hi all
Thanks!
I heard of someone doing this a while back. As long as you get the CG correct, it should work fine. They just added weight to the nose until it would glide from a hand throw, then measured where the CG was from there. The only real difference between a kite and a glider is the angle of attack. I would suggest using weight shifting to turn, just like a real hang glider.
--Jeremy
jrbackus is offline Find More Posts by jrbackus
Old Nov 06, 2010, 09:31 AM
43851E is offline
Find More Posts by 43851E
43851E's Avatar
College Station, TX
Joined Jul 2009
The "Vrooom Hilda" was a witch wth a cape that flew well. Can't remember who produced the kit, but it was mass produced & flew well. It was a "delta style kite". With LEDs, a sure draw from the masses! He, he!
Good fly'in,
Doug
43851E is offline Find More Posts by 43851E
Old Nov 06, 2010, 03:09 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
Also have a look in the 'Similar Threads' list at the bottom of this page, there may be a useful thread there.
An Advanced Search on 'kite' also brought up quite a few threads.
eflightray is online now Find More Posts by eflightray
Old Nov 06, 2010, 04:00 PM
43851E is offline
43851E's Avatar
College Station, TX
Joined Jul 2009
Niceguy, you may get a kick out of this:
http://www.rcgroups.com/forums/showthread.php?t=987191
Old Nov 10, 2010, 10:22 PM
flattermann is offline
Find More Posts by flattermann
check the crazyplanes ...
flattermann's Avatar
Germany
Joined Dec 2006
Hi Niceguy,
As all Your Nylon Kites are rudderless fying objects, a conversion with an interchangeable vector power unit does make sense. Buy one vector unit, and use it for different kites.
try this:
http://www.crazyplanes.de/specials (he did a lot of rc-kite conversions)
or this:
http://www.horizonhobby.com/Products...rodID=PMR10292
They offer interchangeable vector propulsion power units for vector kites, useful as well for any kind of kite-conversion.
flattermann
flattermann is offline Find More Posts by flattermann
Old Nov 11, 2010, 05:12 AM
Expat
Japan
Joined Apr 2010
That's a good idea. Is that basically a pan and tilt system? Is there some kind of buffer to save servos from stripping?
If you were to make one, I guess you could use strong servos, and give them leverage by long sticks as control "horns"?
Old Nov 11, 2010, 08:22 AM
Germany
Joined Dec 2006
... watch this:
Premier RC - Vector Kite Gimbal.mpg (1 min 30 sec)
Here You can see, how the system works.
If You want to learn more, google for ' vector kites ' - there are 50 videos showing different Nylon covered Vector Kites.
flattermann
Old Nov 11, 2010, 08:37 AM
Expat
Japan
Joined Apr 2010
Thanks for teh interest Flatterman.
Ya, that's just a heavy-duty pan and tilt system. I could definitely make that.
What limitations does this method of controlling a kite have?
Old Nov 11, 2010, 10:37 AM
Germany
Joined Dec 2006
... as the vectorized kite is rudderless, You should look carefully at Your LiPo capacity during flight - You only can steer the kite with the running motor.
A Vector Kite's glide is steerable only with motor action. When I go outside for Vector Kiting, I always have some freshly charged Lipos with me.
Old Nov 11, 2010, 11:45 AM
Expat
Japan
Joined Apr 2010
How about adding a rudder to be used on the rudder channel? Motor can be used as a supplement during glide.
Actually, what's the reason for the complexity? What happens if a traditional rudder/elevator are used?
BTW, this guy has got some kind of wacky CoG shift mechanism. Looks difficult/complicated to make, not sure how it works.
http://www.rcgroups.com/forums/showthread.php?t=1063158
Old Nov 11, 2010, 03:40 PM
Germany
Joined Dec 2006
... rudders belong to airplanes.
Vector kites don't need rudders.
Piloting a vector kite is RC-experience like no other.
Old Nov 12, 2010, 05:18 AM
Expat
Japan
Joined Apr 2010
Can you give me some specific reasons for that? Or are you not sure yourself?
Old Nov 13, 2010, 02:00 AM
Germany
Joined Dec 2006
Hi Niceguy,
Do You remember the theme of Your thread?
As I understood, You wanted to converse Your '..couple of Nylon Kites' to RC-Kites.
Of course, there are several ways to do that.
Converting Your kites with a Vector Unit is one possibility - and new technology.
The only advantage to combine a Vector Kite with rudders could be, that Your converted kite is able to have a controlled glide, when the BL-motor once stopped.
One of the most fascinating experiences You can make with a Vector Kite, is:
The slower You fly, the higher the maneuverability of a Vector Kite is. By that reason, You will love it to fly especially Big Vector Kites quite close to You, indoors as well as outdoors.
Flattermann
Old Nov 13, 2010, 06:49 AM
Expat
Japan
Joined Apr 2010
Thanks for the interest.
Obviously I doen't have any knowledge of this topic. So I want to get educated.
I still don't know the fundamentals of RC kite dynamics.
For example, What are the pros/cons of a fixed motor with traditional rudder/elevator? CoG shift device?
Stunt kite conversion Neil McGrath Electric Plane Talk 6 Mar 20, 2011 09:17 AM
Build Log Static model RC conversion dwil018 Scale Sailboats 10 Oct 27, 2010 09:56 PM
Question Bird Kite conversion to RC jp.electrik Foamies (Scratchbuilt) 6 Feb 26, 2010 12:20 PM
Kite to IFO conversion? Bilbobaker Parkflyers 1 Apr 23, 2005 01:48 AM
R/C Kite conversion? Can it be done? Ward Scratchbuilt Indoor and Micro Models 17 Apr 11, 2005 09:44 AM
