Mar 14, 2011, 07:38 PM
Joined Feb 2004
Hi Mines all finished I went with Wemo 90's running 6 cells each with ARC 3665-1 motors, set s/c to pull abou 85A eack can tweak it up a bit more if needed.
With the two fans at wot it will just pull vertical out of my hand, however the airframe now weighs 6.5Kg 14lbs'ish.. I will have to re think the batteries because two 6 cell 5800mah is far to much weight.
I think if I had the time and the inclination I would have fixed up the fans to run of the Fuz somehow similar to a lear jet style. A lot less hassel when rigging it in the workshop. May well maiden at that weight when the weather comes..
