Old Jun 03, 2011, 04:35 PM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
Is there a CP omni thats compatible with the 1.2Ghz Lawmate RX yet? I have diversity for those close "thu the park, exploring" flights.
The Flying Farmer is offline Find More Posts by The Flying Farmer
Old Jun 03, 2011, 11:34 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes. All are compatible. My problem was my OSD, not the Lawmate RX.
IBCrazy is offline Find More Posts by IBCrazy
Old Jun 04, 2011, 02:48 PM
Joined Nov 2007
So I CAN use a clover leaf circularly polarized rx antenna on a Lawmate 1.2Ghz Rx?
I thought they shorted lawmate 1.2Ghz receivers.
Old Jun 04, 2011, 03:34 PM
NDw is offline
NDw
Find More Posts by NDw
NDw
Ireland, Limerick, Kilmallock
Joined Aug 2010
Just to let you know IB it still says "These work with ALL TX/RX sets except the Lawmate 1.2GHz receiver." on your site.
NDw is offline Find More Posts by NDw
Old Jun 06, 2011, 07:27 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That was a guess from Sander. It turns out it was a problem in my OSD. The problem is that my video feed with the CP antennas was so strong that the video got saturated and lost synchronization. I added a resistor to the video line and the problem was fixed.
-Alex
Old Jun 07, 2011, 09:52 AM
ozzimadman is offline
Find More Posts by ozzimadman
Australia, WA, Bunbury
Joined May 2011
hi would this work on 5.8ghz systems
if so could you please help out on wire lengths thanks (math sux lol)
thanks
ozzimadman is offline Find More Posts by ozzimadman
Old Jun 07, 2011, 10:53 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Sure it would work, but I wouldn't know how to build it accurately. Try a skew-planar wheel or a helical. Those can be built much more accurately for 5.8GHz than a ground plane antenna.
-Alex
Old Sep 16, 2011, 11:39 PM
KKUSA is offline
Find More Posts by KKUSA
United States, IN, Indianapolis
Joined Oct 2010
I may be wrong, but isnt this essentially a Vee, with 3 (or 2 if three elements used) more "directional" patterns. If you remove all but one ground element , its a Vee, angled slightly upward (or downward)
So, you say a Vee is better in the air. How different, and what are the differences in radiation pattern of this antenna as opposed to a regular Vee?
It seems, that maybe this antenna would be a bit more omni , and just as effective in the air as a Vee. However, as I said, I may be wrong. Just curious!!
KKUSA is offline Find More Posts by KKUSA
Old Sep 19, 2011, 07:44 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Not really a Vee. The ground elements act like a reflector rather than a counterpoise as they would in the Vee. The grounded elements tend to drive the signal upward toward the driven element.
On the other hand Thomas Scherrer uses a ground plane antenna on his aircraft.
Old Dec 19, 2011, 11:57 AM
icah is online now
Find More Posts by icah
Hungary, Pest County, Tököl
Joined Oct 2010
I do not have a clue how to mount this antenna on a quadcopter upside down
If it is on the top of the quad, radiating downwards, it will most possibly mess the GPS. And there is no such space below the quad to mount it there. Anybody having a pic how it should be mounted on a quad?
icah is online now Find More Posts by icah
Old Dec 19, 2011, 07:44 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
It is supposed to be an RX antenna. If used on a quad it would need to be upside down.
-Alex
Old Dec 20, 2011, 12:30 AM
icah is online now
Joined Oct 2010
Ahh. okay.
However, I intend to use it for my video TX on my quad.
I understand that you intend to use it for ground station. But what is TS using it for on his quad, if not video TX? If it is for video TX I am a bit confused about how to mount it to avoid jamming the gps.
Old Dec 20, 2011, 09:12 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Thomas uses his as a TX antennas. He just mounts it upside down.
-Alex
Old Dec 20, 2011, 11:18 AM
icah is online now
Joined Oct 2010
THX. Will try and optionally report back.
Old Nov 18, 2012, 09:42 PM
nige838 is offline
Find More Posts by nige838
United States, TX
Joined Oct 2009
TX antenna for boosted 2.4?
I'm using a 1w boosted 2.4 FrSky. I would like to know if I might see any improvement using this antenna over a stock dipole?
nige838 is offline Find More Posts by nige838
For Sale ReadyMadeRC Antenna Tracker Ground Station w/ Sidecar $90 cbcalhoun Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2010 10:04 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
