Old Jan 18, 2011, 10:08 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by vulpina View Post
Can this antenna be used as a TX one too ?
Is it better than the dipole for a glider if so ?
There are a few that fly it upside down. Thomas Scherrer is one of them. Personally, I like the Vee far better. Although admittedly, the Vee is soon to become a thing of the past. I have a completely new system of antennas I am developing thanks to a little help from Old Man Mike
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 18, 2011, 10:11 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks good Kendall! Now you need to build two skew planar wheel antennas. You have the skills to do it. Fly one on the TX and on on the RX. I am quickly finding that the dual skew planar wheels is my most flown system especially for virgin flying sites.
-Alex
Old Jan 19, 2011, 01:17 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
That sound very good IB. cant wait to read about your new antenna design .
vulpina is offline Find More Posts by vulpina
Old Mar 02, 2011, 12:19 PM
arnaldo26 is offline
Find More Posts by arnaldo26
Italia, Emilia Romagna, Modena
Joined Mar 2009
can i use this antenna with radiotx 2,4? (assan)
arnaldo26 is offline Find More Posts by arnaldo26
Old Mar 23, 2011, 05:35 PM
maxdefalco is offline
Find More Posts by maxdefalco
Napoli - Italy
Joined Apr 2010
Hello Alex, what is the best antenna system on the tx and rx on the ground for my Traxxas Summit?
maxdefalco is offline Find More Posts by maxdefalco
Old Mar 23, 2011, 08:33 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Rule #1 - there is no such thing as best in FPV.
I have enough information from that post to only guess at what would work for your circumstances. What are your goals? How do you plan to drive?
My best guess, a cloverleaf antenna on both ends.
-Alex
Old Mar 24, 2011, 01:40 AM
jkarnacki is offline
Find More Posts by jkarnacki
USA, CA, San Carlos
Joined Nov 2007
You say this antenna has a very wide radiation pattern, I'm guessing around 2-3 db? I have an inverted vee on my 900 mhz tx so I'm going to try that with the stock whip on my rx, then swap rx antenna to this one and compare.
- Jeff
jkarnacki is offline Find More Posts by jkarnacki
Old Apr 22, 2011, 04:59 AM
hwat rc is offline
Find More Posts by hwat rc
Australia, QLD, Maleny
Joined Jul 2009
Thanks IBcrazy, replaced my stock whip on my fox 800 rx with this and it made a huge difference
hwat rc is offline Find More Posts by hwat rc
Old May 10, 2011, 04:34 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Well I think I made one of your ground plane omni's. I wasn't quite sure on how to attach the ground elements and vertical part to an SMA plug. I soldered the vertical element directly to the center pin of the SMA plug and the ground elements to the outer section for the ground shield. Is this correct?
Blueshy is offline Find More Posts by Blueshy
Old May 11, 2011, 08:32 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Looks good to me. Remember that the center wire does not go active until it leaves the SMA connector. So long as that height is coeerc, it will work well.
-Alex
Old May 11, 2011, 06:55 PM
Blueshy is offline
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
-Alex
Oh, well . Then my center connector is too short. Thanks for the feedback.
Old May 31, 2011, 04:22 AM
FlyingMcCoy is offline
Find More Posts by FlyingMcCoy
Joined Mar 2010
Ground plane antenna
Hi Alex,
Please take a look at my ground plane antenna for 1.2ghz. Haven't tested it yet. Does it look alright?
Thanks very much.
FlyingMcCoy is offline Find More Posts by FlyingMcCoy
Old May 31, 2011, 10:44 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That looks very good to me. Well made!
Old Jun 03, 2011, 01:40 PM
The Flying Farmer is offline
Find More Posts by The Flying Farmer
^Its what I do^ - FPVholic
The Flying Farmer's Avatar
United States, NY, Walker Valley
Joined Nov 2007
how would this antenna work with CP like a cloverleaf on the plane?
Ill have an antenna tracker with a CP helix, but Im also using diversity for close up omni, and found this antenna.
The Flying Farmer is offline Find More Posts by The Flying Farmer
Old Jun 03, 2011, 01:44 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
If you are already flying a CP antenna on the plane you really should fly a CP antenna on the ground. This one will work ok, but any CP antenna on the RX will do far better.
-Alex
For Sale ReadyMadeRC Antenna Tracker Ground Station w/ Sidecar $90 cbcalhoun Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2010 10:04 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
