Old Nov 11, 2010, 02:22 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
For an R/C truck, you would be best suited with 3/2 wave dipoles on both the truck and RX. A ground plane antenna on the truck would work fairly well, but the 3/2 wave dipole would likely work better.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 23, 2010, 06:29 AM
sfakias is offline
Find More Posts by sfakias
ScratchCrasher
sfakias's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jun 2008
Hi Alex,
Thank you for the effort you make to educate and inspire us all. Your home build solutions are great!
Can you please clarify, when you say to mount the antenna 1-2 meters high, do you mean with only air (or non-metallic materials) between it and the ground? I usually place mt VRx on the roof of my car with antenna pointing upwards, but I am getting only 1200m range from my 800mW 1.2GHz system on stock antennas. I have build your dipole and a GPP, but before I test the range with the custom made antennas, I want to know if my VRx placement is fundamentally wrong.
sfakias is offline Find More Posts by sfakias
Old Nov 23, 2010, 07:28 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by sfakias View Post
Hi Alex,
Yes. Ideally you would place it a few meters in the air with only non condictive materials in between when possible. I actually mount my ground plane antenna on a wooden stick attached to my video goggles and tet it rest a few inches over my head. The reason is to mitigate multipath interference. The ground plane antenna will work fine on the roof of the car, but could cause some multipath disturbance.
Mounting the patch on the roof is ok. Personally, I prefer it to be on the ground where possible, but have had good results with one on the roof or trunk of the car.
-Alex
Old Nov 26, 2010, 07:23 AM
aSa2 is offline
Find More Posts by aSa2
Joined May 2010
Can I use RG-174/U for coaxial type?
aSa2 is offline Find More Posts by aSa2
Old Nov 26, 2010, 07:35 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Yes, that will work fine.
Old Dec 23, 2010, 09:47 AM
techslave is offline
Find More Posts by techslave
techslave's Avatar
Joined Nov 2007
Hello, thank's for this "how to do".
I would like to know if 1/2 or full wave lenth will give more gain. Plan to make this antenna for 1280mhz.
Thank's
techslave is offline Find More Posts by techslave
Old Dec 23, 2010, 05:28 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Full wavelengths are bad due to high impedance, but odd multiples of 1/2 are fine. 3/2 or 5/2 wave would do well to increase gain.
-Alex
Old Dec 26, 2010, 10:59 AM
Coil is offline
Find More Posts by Coil
Coil's Avatar
Slovenia
Joined Mar 2008
Originally Posted by IBCrazy View Post
Adjusting the antenna:
While many of these usually have the radiator 90 degrees from the ground plane, in many cases a slightly greater angle is desirable. As the angle opens up, the gain drops and directs the pattern more outward. I find that 100-120 degrees is most desirable. This allows me to have the antenna mounted on a not flat surface as well as gives me a bit better low altitude resolution.
If you have a Quadcopter, this antenna will do very well if mounted upsidedown with a 120 degree angle on the elements.
-Alex
Hi Alex im making this antenna for my Mikrocopter. Do you mean 120 degrees between central element and legs...
Coil is offline Find More Posts by Coil
Old Dec 27, 2010, 08:49 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
That picture is correct, yes.
Old Jan 06, 2011, 02:34 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Sick at home today, so I built one. My stock BOB 1.280 omni sucks, and my rcam dipole was worse so I must have messed up. So heres another go!
Derek_S is offline Find More Posts by Derek_S
Old Jan 17, 2011, 04:23 PM
tuppertn is offline
Find More Posts by tuppertn
Postcards From The Purple Edge
tuppertn's Avatar
United States, OK, Sand Springs
Joined May 2007
Spending more quality time with the soldering iron.
Alex, you said that full wave is no good due to impedence, but odd half-wave mulitiples are okay. Does that include 1/2, or just 3/2, 5/2, 7/2, etc?
kendall
tuppertn is offline Find More Posts by tuppertn
Old Jan 17, 2011, 09:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
All work well up to 9/2 wave. Beyond 9/2 wave the antenna efficiency is degraded significantly.
Old Jan 18, 2011, 06:02 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Is there any advantage to increasing the number of ground elements? More uniform radiation pattern maybe?
kendall
Old Jan 18, 2011, 07:48 PM
vulpina is offline
Find More Posts by vulpina
France
Joined May 2006
Can this antenna be used as a TX one too ?
Is it better than the dipole for a glider if so ?
vulpina is offline Find More Posts by vulpina
Old Jan 18, 2011, 09:03 PM
tuppertn is offline
tuppertn's Avatar
Joined May 2007
Here's mine--half-wave, 910MHz, 120-degrees, RG-58. I did a slight mod of the coax type by first soldering the ground elements to a short length of brass tubing. Then I stripped the cable, folded the shield back over the jacket, slipped the brass tubing over until the point where the shield folded over was even with where the ground elements were soldered and crimped the brass tubing. The nylon cone is there to reinforce the solder joint between the active element and the core of the cable.
See any problems?
Need flying/field trial weather.
kendall
For Sale ReadyMadeRC Antenna Tracker Ground Station w/ Sidecar $90 cbcalhoun Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2010 10:04 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
