Old Nov 04, 2010, 03:43 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Mini-HowTo
DIY Ground Plane omni directional RX antenna
One of the largest problems I have had with FPV is finding a good omni directional receiver solution. Dipoles work ok, but almost half of the radiation pattern is into the ground and there is a huge hole above it. One solution to this is the ground plane antenna.
The ground plane antenna has multiple grounded elements that effectively drive the propagation pattern back upward. This actually increases the effective gain of the antenna. Range will increase slightly, but the real advantage is signal strength improvement at altitude.
While I find it more useful on the RX side (preferring the Vee on the TX), some may find this an excellent antenna for ground vehicles. Thomas Scherrer flies this antenna on his FPV plane mounted upside down. This is a great solution so long as you don’t need to bank hard.
The construction is similar to a Dipole. It has a single ¼ wave driven element and a counterpoise. However the counterpoise is very different this time. It can have anywhere from 3 to 8 ¼ wave elements. For this tutorial, I will use 4. Thomas Scherrer’s has 3. For this, I am using 14AWG wire to make an antenna for 910 MHz. You can use just about any gauge wire you like. I prefer 12 and 14 AWG because it is stiff.
With that, I will begin the tutorial.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 04, 2010, 03:45 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
The calculations: Your 1/4 wavelength
All you need is one calculation:
Length in inches = 2808/f in MHz
Or for you metric folks:
Length in mm = 71323/f in MHz
So for 910 MHz, this is 3.086” or 78.3mm
For 1280MHz – 2.19” or 55.7mm
Easy as that!
Now we move on to the construction.
-Alex
Old Nov 04, 2010, 03:51 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Construction: Substrate type design
There are two methods to building this. One uses a protoboard as a substrate, the other simply uses the coaxial cable. I will make both types.
Substrate type:
I find this a little less time consuming and a little easier to get the geometry correct.
Start by cutting 5 pieces of wire to your calculated ¼ wavelength and strip and tin the ends.
Now strip about 1” of the jacket from the coaxial cable and fold back the shield.
Solder 4 of your ¼ wave wires in an “X” pattern to your protoboard. I actually made one element by measuring it to twice the ¼ wavelength and removed the insulation in the middle of the wire.
Drill a hole in the substrate as close to the “X” center as possible just barely large enough to pass the coaxial line’s center conductor through. Now solder the shield to the “X”
Strip the insulation off of the center conductor as close to the boards as possible. Solder the last ¼ wavelength element to the side of the protruding coaxial line so the wire rests directly over top of the center of the grounded “X”
Finally, measure all of the elements to be sure they are exactly your ¼ wave measurement from the center of the antenna and trim if necessary.
-Alex
Old Nov 04, 2010, 03:55 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Construction: Coaxial cable type
Coaxial type:
For this type you need to cut 3 or 4 pieces (depending on how many grounded elements you want) of wire to your ¼ wavelength. Thomas uses 3. I will use 4.
Strip ¼ wavelength of the jacket from your coaxial cable and fold back the shield. You should have exactly ¼ wavelength worth of center conductor exposed.
Trim your folded over shield to about 1” (25mm) or so and twist it up into 3 or 4 strands 90 degrees (or 120 degrees for 3 conductors) apart. Tin those strands with solder to keep them stiff.
Now solder your ¼ wavelength wires to these strands so that the base of the wire butts into the coaxial cable.
Measure all of your elements being sure each is exactly ¼ wavelength from the center of the antenna. Trim if necessary.
-Alex
Old Nov 04, 2010, 03:56 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Setting up the antenna
Adjusting the antenna:
While many of these usually have the radiator 90 degrees from the ground plane, in many cases a slightly greater angle is desirable. As the angle opens up, the gain drops and directs the pattern more outward. I find that 100-120 degrees is most desirable. This allows me to have the antenna mounted on a not flat surface as well as gives me a bit better low altitude resolution.
If you have a Quadcopter, this antenna will do very well if mounted upsidedown with a 120 degree angle on the elements.
-Alex
Old Nov 04, 2010, 03:57 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Q&a
How High should I mount it? - 1 to 2 meters off the ground is perfect.
Old Nov 04, 2010, 04:02 PM
badlands is offline
Find More Posts by badlands
When in doubt, throttle out...
badlands's Avatar
Joined Mar 2010
Wow - something else to build - im liking the strength improvement at altitude bit.
n1 again Alex.
badlands is offline Find More Posts by badlands
Old Nov 04, 2010, 04:12 PM
Alcyon13 is offline
Find More Posts by Alcyon13
Alcyon13's Avatar
France
Joined May 2010
Thanks Alex, your tutorials are great !
Alcyon13 is offline Find More Posts by Alcyon13
Old Nov 04, 2010, 05:45 PM
IL76MD is offline
Find More Posts by IL76MD
fly it high as possible
Falls Church, VA
Joined Jun 2009
Easy as that!
-Alex
Hi Alex,
just a couple of questions:
- How high you gonna lift this antenna?
- What kind of coaxsial cable do you use - 50 or 75?
Thanks.
IL76MD is offline Find More Posts by IL76MD
Old Nov 04, 2010, 05:51 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I use RG58/U 50 Ohm coaxial cable. Any microwave rated cable will do. 50 Ohm is a little better than 75 Ohm.
Put this antenna up in the air about 1-2 meters. I mount it right on my head
-Alex
Old Nov 04, 2010, 06:10 PM
Coyote64 is offline
Find More Posts by Coyote64
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Nice work again Alex top man
Coyote64 is offline Find More Posts by Coyote64
Old Nov 11, 2010, 11:09 AM
Tommygunn is offline
Find More Posts by Tommygunn
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
Alex,
When you say the antenna would be ideal for a Quad when turned on it's head, you mean exactly as is, no change to the construction, but with the coax uppermost?
How does flipping it benefit a Quad exactly?
Tom.
Tommygunn is offline Find More Posts by Tommygunn
Old Nov 11, 2010, 11:26 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by Tommygunn View Post
Alex,
Tom.
Having the grounded elements up in the air directs the radiation pattern downward. This sends more of the signal where you need it, on the ground. The construction would be identical.
-Alex
Old Nov 11, 2010, 11:47 AM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
When you say that more of the signal is directed to the ground your simply assuming that I won't be flying anywhere near as high as you fixed wings fellas, which I won't be? Not that your thinking that I might only be flying a few metres off the ground
Tom.
Old Nov 11, 2010, 01:12 PM
Slo-V Flyer is offline
Find More Posts by Slo-V Flyer
From trucks to planes
Slo-V Flyer's Avatar
Joined Sep 2005
Very interesting. I will definitely experiment at home with this for my 1.2Ghz receiver. I use my FPV for now with my ground R/C (Summit). I didn't get as good results with stock rubber duck antenna as I expected combined with the 800 mw Vtx. I am assuming that this can be used to receive ground level transmissions if pointed toward or slightly angled toward the R/C truck?
Would it be possible to get a visual representation of the radiation pattern like in your other examples? That would be great, if just to ad to my knowledge and others.
Slo-V Flyer is offline Find More Posts by Slo-V Flyer
For Sale ReadyMadeRC Antenna Tracker Ground Station w/ Sidecar $90 cbcalhoun Aircraft - General - Miscellaneous (FS/W) 0 Oct 30, 2010 10:04 PM
Discussion DIY Continuous Rotating FPV Ground Station Moosthegoose FPV Talk 37 Sep 29, 2010 04:27 AM
Discussion need the best omni directional antenna for receiver WBFlyer FPV Talk 10 Jul 07, 2007 10:24 AM
Discussion I need the best omni-directional antenna WBFlyer FPV Talk 2 Apr 11, 2007 11:59 PM
Omni-directional antenna for bit-tx? Angry_Monk Scratchbuilt Indoor and Micro Models 4 Aug 12, 2005 04:05 PM
