Old Oct 17, 2012, 10:47 PM
Looooeeee! is offline
Find More Posts by Looooeeee!
Heli Bouncer
Looooeeee!'s Avatar
At the Discount Clambake
Joined Feb 2001
Originally Posted by kdahlhaus View Post
Nice! I am having a hard time with the Caudron but I think that is because my controller didn't calibrate correctly. They are both sharp looking planes.
I've flown my Eastbourne model (Tritle). My model flies very much slower and has much less loading than the model here. Some day I'll tweak the params here and see if I can get the simulator closer to my experience.
Well you have to remember that these are closer to giant scale models, both the Eastbourne and the Caudron are nearly 2 meters in wingspan. so they are larger than the 36" Trittle parkflyer kit. Careful opening these and my other models in Aircraft Editor because of their big wing areas, they're much more likely to crash the editor.
The Caudron is set up with low roll response because it is in particular a fairly high weight to area wing loading, (for it's time..) wing warping plane. They didn't have a lot of roll authority, so coordinate your turns with mostly rudder, if you do adjust something I'd increase the dihedral authority some. Keep it's speed up, don't get into a highly banked turn while climbing.
Looooeeee! is offline Find More Posts by Looooeeee!
Old Oct 20, 2012, 12:44 PM
XtalHunt is offline
Find More Posts by XtalHunt
United States, TX, Austin
Joined Sep 2012
Is there a decent autogyro for this that's reasonably accurate in behavior? Cuz I'm building this thing and want the feel for it before I drag it out to a paved lot.
XtalHunt is offline Find More Posts by XtalHunt
Reply With Quote  (Disabled)
Old Dec 10, 2012, 02:37 AM
JD-Slow-Thumbs is offline
Find More Posts by JD-Slow-Thumbs
Requires Further Research :)
Joined Feb 2010
Request MP EasyGlider
The Multiplex EasyGlider is on of my favorite simulator planes, one of the few that fly for a long time before I crash, can somebody please point me to a download if it already exists, or can somebody convert one from another sim over to RCDeskPilot format, please.
JD-Slow-Thumbs is offline Find More Posts by JD-Slow-Thumbs
Old Dec 10, 2012, 01:21 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Do not have files for RC Dekpilot, but for those wishing to convert any or all of the Multiplex model files, refer:
. FMS Program and Multiplex Models for FMS
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old Jan 18, 2013, 10:40 AM
ggunners is offline
Find More Posts by ggunners
Bit-Twiddler and Flyer
USA, VA, Chantilly
Joined Apr 2002
New FMS PT-17 Stearman
Hello Desk Flyers,
Here's a new PT-17 Stearman which looks great with the
baby blue fuse and yellow wings. Hope you like it.
FMS PT-17 Stearman
Material: Durable EPO
- Wing Span: 1,050mm ( 41.3in )
- Length: 850mm ( 33.5in )
- Flying Weight: 1,060g ( 37.39 oz. )
- Servo: 9g Servo x 4
- Motor: 3536-KV850 Powerful Out runner Brushless Motor
- ESC: 35A Brushless ESC
- Propeller: 11X7 2 Blade Propeller With Spinner
- Battery: Li-Po 11.1V
Good Flying! -- ggunners
ggunners is offline Find More Posts by ggunners
Old Jan 24, 2013, 03:28 AM
02DropTopM3 is offline
Find More Posts by 02DropTopM3
United States, UT, American Fork
Joined Jan 2013
New Parrot AR Drone 2.0
Hello Everyone,
I'm new to the forums but wanted to share a model I've been working on. I have a Parrot AR Drone that has been modified using the "Macgyver" mod to allow it to be controlled with a standard Spektrum transmitter. I've been wishing there was some sort of simulator for this thing and when I started playing around with the outstanding RC Desk Pilot I discovered that the Tiger (coax) heli feels almost identical to the AR Drone 2.0. Nice, but I wanted the look of the drone with the quad-props, so I went to work finding a AR Drone 3D model that I could modify to stick on top of the Tiger (coax) flight model, turning it into a nice quad-prop.
So here you have it:
Parrot AR Drone 2
Please take a look and send me any feedback (especially you AR Drone pilots out there that have modded your drones to use a standard RC controller).
02DropTopM3 is offline Find More Posts by 02DropTopM3
Old Jan 24, 2013, 02:55 PM
hifinsword is offline
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
I'm hoping this is the right forum to ask a question about getting the RC Desk Pilot to work. I had it installed for a month or so and it was working well. Then I started getting errors about the DirectX. I reinstalled DirectX version 9 or tried to but not sure where it goes (directory). It worked 1 day and not since. Still get the error message and have uninstalled RCDP and reinstalled it. I don't see DirectX as a program to uninstall but I do have the file to install it downloaded. I need help! Thanks in advance for any advice.
Don
P.S. I use a Home Vista machine
hifinsword is offline Find More Posts by hifinsword
Old Jan 24, 2013, 06:25 PM
Joined Jan 2013
Directx errors
Don, I always try googling the exact error messages that I see to get an idea what others have done to solve the same problem. Any luck with that approach?
Old Jan 26, 2013, 09:01 PM
Blue Skies
hifinsword's Avatar
Joined May 2012
error codes with DirectX ver 9
Thanks for the tip. I went in to get the error code and IT WORKS! I've restarted and shut down the computer a few times more than usual this past week. Had to calibrate a few times and it works perfectly. Next time it bombs I'll try the google search.
Don
Old Feb 02, 2013, 09:55 PM
h710railfan is offline
Find More Posts by h710railfan
United States, OH, Woodville
Joined Jan 2013
Anyone have a tricopter for desktop pilot to practice flying with?
h710railfan is offline Find More Posts by h710railfan
Old Feb 05, 2013, 12:42 AM
Maximilionalpha is offline
Find More Posts by Maximilionalpha
Maximilionalpha's Avatar
United States, NJ, Rahway
Joined Mar 2012
Davy,
I've been using r/c desk pilot, now, for a few years. I do, of course, have one gripe...I fly my sailplanes in very adverse weather conditions..ie,... 20+mph winds /rain/ snow/ ice/ clouds and have been waiting for over a year now, for you to add different weather effects to this great simulator. It would be wonderful, if we could have rolling clouds that one could actually fly in and about...altimeter readings...speed sensors...user defined weather conditions, such as how hard/soft, it could rain/snow. This is a vid of what I like to do and how I would like to it on the flight sim of r/c desk pilot.
Parkzone Radian Reaching For The Clouds.wmv (14 min 52 sec)
Maximilionalpha is offline Find More Posts by Maximilionalpha
Old Feb 22, 2013, 03:38 PM
ggunners is offline
USA, VA, Chantilly
Joined Apr 2002
New Grumman F9F-2 Panther
Hello RC Desk flyers,
I just converted my FMS model for RC Desk Pilot and thought
you would like to try it out.
Notes: This version of the F9F had the straight wing unlike the follow
on F9F with the swept wing called the Cougar. Panthers were the
first carrier jets to see action in the Korean war.
RC Groups: http://www.rcgroups.com/forums/showthread.php?t=1309643
Vendor: http://www.valuehobby.com/f9f-panthe...ver-ready.html
HobbyLobby Video:
Hobby-Lobby F9F Panther - Test Flight 1-23-2011 (3 min 52 sec)
Freewing F9F Panther
Span: 685mm (27in)
Length: 730mm (28.7in)
Weight: 552g (19.5oz)
Durable EPO Construction
64mm EDF using 4300Kv outrunner brushless motor
3-cell 11.1V 1500mAh-2200mAh LiPO at least 20C
30A speed control with BEC
3 - 9 gram servos
I hope you enjoy flying this model. Please let me know if
it needs any changes. -- ggunners
Old Feb 22, 2013, 09:30 PM
Joined Jan 2013
I just downloaded it and flew it and I really like it, I dont see nothing bad about it!
Old Feb 23, 2013, 07:52 AM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
We need more jets!
Keenan smith is offline Find More Posts by Keenan smith
Old Apr 22, 2013, 10:48 PM
spitfire1234 is offline
Find More Posts by spitfire1234
spitfire1234's Avatar
Australia, NSW, Orange
Joined May 2012
Model idea/request
Hi all,
If anyone is wanting to make another plane, maybe a P-39? it's my favourite warbird. It would be much appreciated. Thanks.
spitfire1234 is offline Find More Posts by spitfire1234
For Sale Great Planes Evader - ready to fly just add battery garth285 Aircraft - Electric - Jets (FS/W) 16 Sep 14, 2010 09:59 PM
For Sale Great Planes Real Flight Add on vol. 1 sunderll Aircraft - General - Miscellaneous (FS/W) 0 Mar 11, 2010 05:30 PM
For Sale Great Planes G2 w/ Add-On's 1-5 Monstermanhbf Aircraft - General - Radio Equipment (FS/W) 0 Oct 28, 2005 10:14 PM
Sold RealFlight Add-On Vol. 1, $15 shipped, New-in-box rcheliman Aircraft - General - Radio Equipment (FS/W) 4 Aug 20, 2005 01:54 PM
2 Planes down: 1 in the Sea, and 1 on the cliff Patrick Plawner Electric Plane Talk 5 Sep 21, 2002 04:33 PM
