Old Nov 03, 2010, 06:04 PM
planefun is offline
Find More Posts by planefun
Goog-a-moog-a
planefun's Avatar
South Central PA
Joined Oct 2003
Question
LiFeP04 receiver pack and servos
Hi everyone,
Iím using the LiFeP04 1450 6.6 volt receiver battery in my plane. I switched from 5 cell 2/3 batteries about 5 months ago. My plane has JR 368 servos all the way around. In the last 3 months 3 servos have stopped working on me. One stab servo, rudder and flap. Could the voltage of the LiFe batteries be causing the servos to stop working? The 5 cell NiMH batteries were about the same voltage fully charged. Should I change my servos in order to accommodate the new battery pack? Any suggestions?
Thanks for reading.
PF
planefun is offline Find More Posts by planefun
Old Nov 03, 2010, 06:33 PM
tewatson is offline
Find More Posts by tewatson
Riddle me this...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
FWIW, I have not noticed any abnormal servo behavior with either LiFe or A123 packs over the past year. Might be a coincidence.
Tom
tewatson is offline Find More Posts by tewatson
Old Nov 03, 2010, 06:36 PM
codezilla is offline
Find More Posts by codezilla
codezilla's Avatar
Chino Hills, CA
Joined Feb 2003
I've been using 2cell LiFe cells (A123) with JR 368 servos on two planes without any issues. Check to see if any of the surfaces are binding which could pull more current and burning up the servos.
Adrian
codezilla is offline Find More Posts by codezilla
Old Nov 03, 2010, 06:47 PM
Silent-AV8R is offline
Find More Posts by Silent-AV8R
Team Futaba
Silent-AV8R's Avatar
United States, CA, Ladera Ranch
Joined Aug 2004
Same here. LiFePO4 in everything I fly for ove a year now without any issues, and I am running Futaba 3150 servos that are noted by FUtaba as 4.8 volt only. No problems.
As noted above, these packs make it critical to have no binding, etc. They do work at a slightly higher voltage than a Nimh, but more importantly they will deliver a higher voltage under a significant load way better than a NiMH. So if you are binding or stalling the servos at all they will die sooner. And as Tom said, it may be nothing more than coincidence, either that or the servos were close to EOL anyhow and the stronger packs nudged them over the edge a tiny bit sooner.
Silent-AV8R is offline Find More Posts by Silent-AV8R
Old Nov 03, 2010, 07:08 PM
liukku is offline
Find More Posts by liukku
mostly gliders
liukku's Avatar
SkellefteŚ, Sweden
Joined Sep 2003
Very possible!
Originally Posted by planefun View Post
Hi everyone,
I’m using the LiFeP04 1450 6.6 volt receiver battery in my plane. I switched from 5 cell 2/3 batteries about 5 months ago. My plane has JR 368 servos all the way around. In the last 3 months 3 servos have stopped working on me. One stab servo, rudder and flap. Could the voltage of the LiFe batteries be causing the servos to stop working? The 5 cell NiMH batteries were about the same voltage fully charged. Should I change my servos in order to accommodate the new battery pack? Any suggestions?
Thanks for reading.
PF
Hello planefun
To answer your question, "Could the voltage of the LiFe batteries be causing the servos to stop working?"
Very possible, perhaps too early to draw any conclusions yet, but it is known that many manufacturers specify their servos for only 4.8V-6V.
LiFe batteries are fairly new to be used to power our old types of servos. I have started using LiFe batteries but I use them together with a regulator. I am about to complete a 2 m Sprite Thermal. In it, I will only use Hyperion high volt servos. That way I will not have to use a regulator.
Read this post in the thread, "Using Lipo's in sailplanes" http://www.rcgroups.com/forums/showp...3&postcount=32 and you need not feel alone anyway.
/Ville
liukku is offline Find More Posts by liukku
Old Nov 03, 2010, 07:22 PM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
It is far more likely you have some binding in the linkages and the servo is burning up the amplifier because it's trying to center all the time.
I have had no issues with 368s and 2 cell LiFePO4 packs.
tk
tkallev is offline Find More Posts by tkallev
Old Nov 03, 2010, 07:27 PM
PDX Slope Pilot is offline
Find More Posts by PDX Slope Pilot
Eagle Butte User
PDX Slope Pilot's Avatar
Portland, Oregon
Joined May 2002
No issues here with 761z and DS3421 servos on unregulated LiFe packs.
PDX Slope Pilot is offline Find More Posts by PDX Slope Pilot
Old Nov 04, 2010, 12:52 AM
Tuomo is offline
Find More Posts by Tuomo
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
Originally Posted by liukku View Post
Hello planefun
5 cell nimh rx batts have been used for years. The big confusion over 3150s rose because DS368/3068 was known to be ok with the higher voltage but 3150 was specsed more like servo for 4 cell rx packs.
2s Life pack has lower voltage than 5s nimh pack. I would use them unregulated without doubts. Regulators have also some problems, so better avoid them if possible.
Tuomo is offline Find More Posts by Tuomo
Old Nov 04, 2010, 04:10 AM
satinet is offline
Find More Posts by satinet
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
true, but I suspect LiFePo4 has a higher voltage under load (nimh drops voltage quite easily). I dare say most servos can take a high voltage under no load.
I am not sceptical about Life, I am just thinking about the difference under load.
I am thinking of trying LiFe in my next model with 2x 761s and 4 x graupner ds3288s, but I am not decided yet.
Tom
satinet is offline Find More Posts by satinet
Old Nov 04, 2010, 06:46 AM
liukku is offline
mostly gliders
liukku's Avatar
SkellefteŚ, Sweden
Joined Sep 2003
Hello
It is "always" just a matter of time before anything breaks. Thats the nature of things. But as many Americans say, "each one becomes blessed in one's faith", no, that is not the saying, what is it? To each his own? nah...
"Like a bolt from the blue.", not sure.
/Ville
Old Nov 04, 2010, 07:29 AM
Tuomo is offline
Tuomo's Avatar
Jyvaskyla, Finland
Joined Aug 2003
That is very true, but then again, things are not much more diferent if you use Life with (say) 6V 5A regulator, Futaba 3150 is still close to its limits.
Servos will allways burn sooner or later... I think there is no other solution to this dilamma than going to much more robust servos that run on higher voltage. Personally I would not mind flying this way, but we have also those guys in this forum who want to use the absolute smallest and lightest possible servo, to save a few grams in wing.
Old Nov 04, 2010, 09:24 AM
Team Futaba
Joined Aug 2004
As I have said numerous times, I am using 3150/3155 Futaba servos on unregulated 2S LiFePO4 with zero problems.
Beyond that, I have friends who have used the same servos on unregulated 5-cell NiMH without any issues. Futaba has a bad habit of being overly conservative on their servo ratings. However, real life results show that these servo are fine on both 5-cell NiMH and 2S LiFePO4 without a regulator.
As far as all servos eventually burning out, in 44 years in this hobby I have yet to burn up a servo. The most common reason for a servo going bad for me has been dirty pots causing a loss of centering and smoothness. The pot gets dirty enough and the servo becomes useless.
Old Nov 04, 2010, 11:26 AM
SmokinJoe101 is offline
Find More Posts by SmokinJoe101
SmokinJoe101's Avatar
Joined Jan 2004
When it comes to batteries I love the speculation and opinion expressed on RCG all based on F.U.D. (Fear, uncertainty, and doubt)
Where is Tuan he knows batteries
sj
SmokinJoe101 is offline Find More Posts by SmokinJoe101
Old Nov 04, 2010, 07:22 PM
SoaringDude is offline
Find More Posts by SoaringDude
Team Hello Kitty
SoaringDude's Avatar
near Sacramento, CA
Joined Aug 2010
On diagnosing bad servos
"Quick" note on the subject of diagnosing dead servos on Lixx cell planes.
I just converted a plane to a Hyperion 1450mAh LiFe pack. Plane has 94761's in the wings and DS368's for rud and elev. Seemed to work fine for a few weeks, then started to notice the right aileron getting jumpy around center but also above and below center too. I thought it might be sensitive to higher voltage from the pack right off the charger so I did tests with inconclusive results. As it got worse I ended up replacing the servo which make the jumpy behavior a bunch better but not 100% gone.
Long story short, after much testing with servo and receiver swapping, looking at servo signals on an oscilloscope, swapping harness wires, etc. the problem turned out to be the servo harness connector at the receiver (ATK 10ch) not being fully plugged in (!). It was close but not all the way in. My point: other issues can cause symptoms that masquerade as a bad servo.
Moral of story for me: always bench test the supposed bad servo with a separate battery pack, wires, and receiver (if you can). When I finally did that, the "bad" servo ran just fine.
My .02 on the original post: three servos going bad so close together points to another problem. My guess: it could be due to a bad battery harness connection causing too much resistance somewhere in the battery wires part of the harness. It could also be defective wiring or connector in the pack itself. Either one could cause voltage to drop at the receiver and all the servos. That in turn could cause the current to rise to the servos esp. when they are moving, possibly causing damage. Just a guess. I'll be happy to suggest a few tests if you like.
Chris B.
SoaringDude is offline Find More Posts by SoaringDude
Old Nov 04, 2010, 07:23 PM
planefun is offline
Goog-a-moog-a
planefun's Avatar
South Central PA
Joined Oct 2003
Liukku, that post is basically what happened to me. I use my Supra hard but I donít think there is any binding. The pushrods move very freely. Iím guessing launching hard could put stress on the elevator servo, since this is the servo that went out in mid flight. I really donít what to use a regulator. Regulators scare me more than battery servo problem. I would change the servos out but Iím not sure what to use for the flaps.
Iím in the process of putting a Pike together and would like to use the LiFe batteries. Any one make a high voltage flap servo that could take the place of a 368?
PF
Question Eneloops for receiver pack Philipp Batteries and Chargers 3 Nov 02, 2010 05:10 PM
Help! Cycling new 6v receiver pack?? KOMET 44 Batteries and Chargers 4 Oct 28, 2010 07:37 AM
Wanted 6v receiver pack (s) & sirrius charger deckert Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 20, 2010 09:59 PM
Sold Moving Sale- Hitec Servos, Eflite Servos, JR Flight Pack, Receiver and Servos!!! jrwilliams27 Aircraft - General - Radio Equipment (FS/W) 6 Dec 11, 2008 01:36 PM
FS new receiver pack and 4 standard servos hnearnest Aircraft - Electric - Airplanes (FS/W) 0 Apr 08, 2002 08:22 PM
