Old Nov 03, 2010, 09:13 AM
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
F-27C Stryker question
Is it possible, using a DX6I Tx and a 6200 Rx through the radio a prepositioned settings for the elevators for either up elevator or flaperons for hand launching?
Thanks in advance for either the tip I need to get it right or a link to a post that has this information!
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Nov 03, 2010, 10:59 AM
Custom Crasher
Joined Jan 2010
Found the answer in another post
http://www.rcgroups.com/forums/showp...2&postcount=35
Thank you Tim!!!!!
Found a fix for the Elevon problems (fixes them all, I think).
This is slightly complicated, but bear with me. In the end, you get everything working plus a bonus feature at the cost of only one mix.
First, plug your right servo into the aileron plug and your left servo into Aux 1 (the Flap plug). I've only tried this on one plane, so I don't know if those might be reversed in some setups.
Then set your Wing Type to Dual Ailerons. Now check your aileron control -- it should work normally for an elevon plane (elevator is not yet working). If it doesn't, you'll probably end up having to reverse your plugs to make things work right.
Next, go to Mix 1 and set Elev -> Flap with both rates (D & U) at 100%. In my case that was -100%, but you may have to use +100 percent in your setup. Check function; at this point it should look like an Elevon plane with a boatload of travel. Don't fret about that -- the extra travel will "fix" your trim buttons! And don't forget to set "Trim" to ACT in the lower right corner of this screen.
Now, if you want differential it should work perfectly. If it goes in the wrong direction, you'll have to back up and reverse the plugs (move the servo in Ail to Aux and vice-versa) and redo the other settings to reverse them. Ultimately it means you'll have all the function back at the cost of a single mix.
But you get some payback for that mix: your Flap switch will now work! Probably the best use for it on an elevon plane is adjusting the elevons to max glide duration in case you want to do some thermals and don't want to try and see what the little bugger is doing at 400 feet...
Undoubtedly your elevon travel will now be too great. If you go to Dual Rates and reduce your top rate down at least to 80% of full, your trim buttons will now be completely safe to use -- the endpoint travel will not be greater than your allowed travel, so the weird "button effects" go away.
As far as I can tell, this is a complete fix. Would be delighted to hear if anyone hits a snag... also this leaves the option of another mix open (if you're using rudder and want a mix, or wish to do a throttle -> "flap" mix to get the torque roll out, for example).
Old Nov 03, 2010, 06:38 PM
United States, NC, Randleman
Joined Jan 2007
If you are happy with the internal elevon mix. The simple way is to mix flap>elevator at about 20%. The flap switch will now work kick your elevons up during launch. I do this on all my strykers
ssteven1 is offline Find More Posts by ssteven1
Old Dec 24, 2010, 02:07 AM
Southern Darling Downs Qld, Australia
Joined Sep 2010
Hi, can anyone tell me if the Stryker F27c is available in RTF or BNF? Cheers Ken.
Kennyglide is offline Find More Posts by Kennyglide
Discussion Looking for plans for foamy similar to Parkzone F-27c Stryker CX2Mike Foamies (Scratchbuilt) 5 Oct 24, 2010 01:00 PM
Discussion DX6i Setup for Stryker F-27C jakobwolff Flying Wings 1 Oct 18, 2010 11:11 AM
For Sale Parkzone F-27c Stryker PNP or BNF beginner4life Aircraft - Electric - Airplanes (FS/W) 1 Sep 12, 2010 11:02 AM
Discussion Stryker F-27C elevator trim question pache11 Flying Wings 1 Aug 26, 2008 03:18 PM
Question Parkzone Stryker F-27C Question? FuntanaS Parkflyers 3 Aug 17, 2006 08:02 PM
