Old Nov 03, 2010, 07:05 AM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
help with new motor won't spin just shudders
I am building my first easystar for fpv but i am having trubble with the motor. I am using a common sense rc Model# 28MM-2000 / 2000 KV motor http://www.commonsenserc.com/product...roducts_id=653 and a 60amp eflight pro esc and eflight 3s 2100mah batteries . it arms it self just fine but when i throttle up the prop just "shutters" back and forth but wont spin.
hotdog1 is offline Find More Posts by hotdog1
Old Nov 03, 2010, 07:17 AM
**** 37130 ****
RobC(UK)'s Avatar
Joined Aug 2007
It sounds like you have lost a motor phase.
It could be a bad connection between the ESC and motor. Check the solder joints and plugs. If you have a meter, measure the resistance between each pair of connectors on the motor (3 combinations).
Failing that the ESC could be defective. Try the motor with another ESC.
RobC(UK) is offline Find More Posts by RobC(UK)
Old Nov 03, 2010, 09:40 AM
Air, Ground & Water
freechip's Avatar
Canada, ON, Rockland
Joined Aug 2008
Had my E-Flite 60A Pro Esc fail this summer, one phased failed in flight. On the ground if I tried to spool up the motor slowly it would stutter big time but I could get it to spin eventualy. Then when it was spinning I would disconnect one wire at a time and was able to find out which phase died BUT that did not change anything because there were no signs of any damage on the board and shipping from canada would of ended up cost as much. So I replaced it with CC Phoenix ESC and will only use CC from now on....
freechip is offline Find More Posts by freechip
Old Nov 03, 2010, 01:01 PM
Mar/cotics Anonymous
cryhavoc38's Avatar
United States, WA, Woodinville
Joined Mar 2007
usually an indication of a bad solder joint..usually.
resolder the three motor bullets and the three esc bullets. Usually just reheating the solder to get it to melt and flow will solve the issue.
Unless you've actually lost a phase in the motor or esc, resoldering cures the shudders.
cryhavoc38 is offline Find More Posts by cryhavoc38
Old Nov 03, 2010, 01:19 PM
Air, Ground & Water
freechip's Avatar
Joined Aug 2008
LOL that would be funny for me to have had my esc sitting there thinking about throwing it out if all it was was bad solder.
Come to think about, I haven't seen it lying around lately, I mite of already garbage it. DAMM
Old Nov 03, 2010, 02:30 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
ok i am going to re-solder them after dinner and we will see!
Old Nov 03, 2010, 03:02 PM
Fast and low...
aa78's Avatar
Joined Apr 2009
What about if slowly raising the throttle works ok but suddenly going from stop to full speed (WOT) results in immediate stuttering, high current and fast drop in battery voltage on Wattmeter? ESC timing, battery's current providing capability or something else?
aa78 is offline Find More Posts by aa78
Old Nov 03, 2010, 06:57 PM
"Chuck Yeager"
hotdog1's Avatar
Bradenton FL
Joined Apr 2010
Yep it was the solder of one of the bullet connectors
Thanks everyone
Old Nov 04, 2010, 10:17 AM
cryhavoc38's Avatar
Joined Mar 2007
Thanks everyone
Most welcome.
98% of the time, a shuddering/stuttering motor @ startup is a cold solder joint.
For Sale Need help with sale or trade for heli with my brand new just built gp reactor neweramarketin Aircraft - Fuel - Airplanes (FS/W) 6 Sep 30, 2010 07:26 PM
Help! HELP!! New LBA10 Balancer won't work...what the??? planebldr Batteries and Chargers 43 Sep 09, 2010 09:09 AM
Discussion Motor won't spin on new 3900kv Ringo* Micro Helis 16 Sep 28, 2007 06:08 AM
Help! Help! - CC25 with Hacker A20-20L: Suttering and won't spin ChrisAttebery Power Systems 5 Sep 03, 2007 10:05 AM
Discussion Help With EVO 9! Won't set a channel. Just says "Channel: HFM" Cziltang Brone Radios 0 Jun 02, 2006 10:03 PM
