Old Nov 03, 2010, 12:07 AM
pow-wow is online now
Find More Posts by pow-wow
United States, TX, Austin
Joined Jul 2009
Idea
vortex generators on Stryker?
I flew my Stryker for the first time, and was wondering, would putting vortex generators on the wings help with it's low speed handling? I would think they would help keep the airflow attached at low speeds and help make it less finicky. I'm especially wondering this because for now, I'm flying mostly in that part of the flight envelope.
pow-wow is online now Find More Posts by pow-wow
Old Nov 03, 2010, 03:55 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Have a look at Post 22 of http://www.rcgroups.com/forums/showt...1314697&page=2
Peter M is offline Find More Posts by Peter M
Old Nov 03, 2010, 10:39 AM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
http://www.rcgroups.com/forums/showt...light=vortilon
nmasters is offline Find More Posts by nmasters
Old Nov 03, 2010, 05:58 PM
Joined Jul 2009
thank you but neither of those are what i'm talking about, here is what I mean: http://www.centennialofflight.gov/es...ngs/TH20G6.htm (ignore the top pic of the stall fence, i mean the things on the MiG and 707)
it's doesn't have to do with the span-wise flow, but it keeps the boundary layer of air from separating near and at stall speeds, the vortilon is close though.
Old Nov 03, 2010, 11:04 PM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
I understood what you meant. The boundary layer is often less than 1 mm thick at the Reynolds numbers models fly at. You could glue little chunks of L angle to your wings but it would be a wast of effort unless scale appearance is more important than the high drag that they would cause. A 1/3rd millimeter thick piece of tape is fine for energizing the boundary layer and wouldn't take nearly as long to apply.
Old Nov 03, 2010, 11:30 PM
Joined Jul 2009
ok, in further reading i noticed the problem of scaling. would fences help also, or same thing there too? If theres something I could do that would help and haven't mentioned, please say so/ direct me, thank you for the help.
Old Nov 04, 2010, 02:10 AM
nmasters is offline
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Fences work the same at low Re. When you get close to stall there's a strong spanwise flow that hits the fence and rolls over into a vortex on the side toward the tip. A vortilon is just a fence cut down to the absolute minimum. There's a short list of stall delaying devices here
--Norm
Old Nov 04, 2010, 01:15 PM
GoatZilla is offline
Find More Posts by GoatZilla
GoatZilla's Avatar
Joined Sep 2005
How much does your Stryker weigh?
GoatZilla is offline Find More Posts by GoatZilla
Old Nov 04, 2010, 05:48 PM
Joined Jul 2009
it's stock, so 21 oz if i saw that correctly mine's an F-27C). coincidentally, when I googled "f-27 stryker weight" your post about making a light one came up first
Discussion stall fences and vortex generators PurpleHaze The Builders Workshop 7 Apr 19, 2010 09:27 AM
Discussion vortex generators? gavrailoff Electric Plane Talk 9 Nov 18, 2008 08:35 AM
Discussion Vortex Generators NX-687 Modeling Science 7 Aug 25, 2007 06:13 PM
