Old Sep 04, 2011, 11:51 PM
Kerbob's Avatar
Knoxville, TN
Joined Apr 2008
Originally Posted by williamjames View Post
Kerbob, what is your setup my friend?
Dragonlink TX/RX
Dragonlink OSD v2.0
Lawmate 1W 1.28Ghz TX (rubber ducky)/RX (patch panel)
GoPro HD 1080p
ReadyMadeRC Pan/Tilt GoPro Mount
The EasyStar feels like a brick now and is no acrobat in the sky with this load. However, it carries it and maneuvers much better than I expected. I have no plane mod's other than putting bi-di tape strips along the top and bottom of each wing and tail for adding strength. I actually have been able to pull off a loop.. I just have to dive a bit first.
Kerbob is offline Find More Posts by Kerbob
Old Sep 04, 2011, 11:52 PM
Tony97's Avatar
Joined May 2004
Why ground and signal wire from OSD to RX? Why not just signal. For example if you run an external BEC, you pull the + & - pins out and just use signal in the EST plug. Why wouldn't this work from OSD to RX?
Originally Posted by Tony97 View Post
Great tips! Thanks so much for sharing. Can you post a pic of your plane? So you spread out the GPS and video transmitter? Pics please.
Tony97 is offline Find More Posts by Tony97
Old Sep 05, 2011, 12:34 AM
Canada, BC, Burnaby
Joined Oct 2010
did a fast low pass with my epp fpv it was fun
go fast with EPP FPV High speed low pass (2 min 25 sec)
Westwood is offline Find More Posts by Westwood
Old Sep 05, 2011, 09:06 AM
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I'm having this pulsing problem with my motor. It was working fine for about five minutes, and then this happened. It should be drawing a steady 26amps at the time, but it keeps dropping down to 21amps and then going up again. Here is the equipment list:
Hobby King EPP FPV
Turning 3536-1400kv motor
Turnigy 55A ESC
The ESC is inside the plane. Could it be overheating? I still had plenty of juice left in the battery.
http://www.youtube.com/watch?v=OmwcW1a8XQw
Tracks is offline Find More Posts by Tracks
Old Sep 05, 2011, 10:56 AM
Canada, BC, Burnaby
Joined Oct 2010
[QUOTE=Tracks;19232329]I'm having this pulsing problem with my motor. It was working fine for about five minutes, and then this happened. It should be drawing a steady 26amps at the time, but it keeps dropping down to 21amps and then going up again. Here is the equipment list:
Hobby King EPP FPV
Turnigy 55A ESC
What battery did you used, esc low voltages soft cut off ??
Old Sep 05, 2011, 11:19 AM
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
The battery is a Turnigy 3S 20-30C 5000mAh. The voltage cutoff is at 3.2V/cell
Old Sep 05, 2011, 11:55 AM
Canada, BC, Burnaby
Joined Oct 2010
Here is my setup esc out side max power 70amp on a 50 amp FMS esc no more over heating That was a leftover esc from my junk box add a heatsink from computer 
EPP FPV setup (1 min 3 sec)
Old Sep 05, 2011, 12:33 PM
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
williamjames,
It was the motor esc set up i had.
NTM 35-36A 1800kv (overkill)
60A ESC (too small)
And it was inside, got hot!
I went to motor and ESC /w stand alone BEC set outside 10x6 prop dosnt get hot
http://www.hobbyking.com/hobbyking/s...dProduct=14733
http://www.hobbyking.com/hobbyking/s...dProduct=18463
ruben
RUBNorris is offline Find More Posts by RUBNorris
Old Sep 06, 2011, 10:32 AM
Joined Nov 2010
This is EXACTLY how I lost my skywalker FPV plane... was flying fine and all of the sudden... death spiral toward the ground. What was the cause for you???
I was only 600m out so it couldn't have been loss of signal.
Hey williamjames
What radio were you using on your skywalker?
Hotglue is offline Find More Posts by Hotglue
Old Sep 06, 2011, 03:06 PM
GLADUS63's Avatar
France, Limousin, Limoges
Joined Jul 2009
I crashed mine on saturday, I was lucky to find it !
EPP FPV CRASH (2 min 45 sec)
GLADUS63 is online now Find More Posts by GLADUS63
Old Sep 06, 2011, 03:38 PM
Fictitious Park Sign Designer
jaskel's Avatar
Penrith, NSW, Australia
Joined Dec 2005
wow so many planes crashing of late! all hardware failures! what servos you using?? perhaps a radio failure, when u upside down the antenna had better coverage perhaps??
Hey when you guys built your planes did you use CA, epoxy or hot glue?? Im debating.
jaskel is offline Find More Posts by jaskel
Old Sep 06, 2011, 03:46 PM
GLADUS63's Avatar
Joined Jul 2009
I use brand new HS81 !
I think it's the EPP around the hardware
I use CA glue / epoxy / special foam
Old Sep 06, 2011, 04:18 PM
United States, MI, Alpena
Joined May 2003
im making mods to my hk epp fpv
some are listed on this sight
im also make mods to the mods listed here
and some not listed here
i will post them in a week or 2 with the pics of the mods when im done doing them
i have tested the plane without the mods its ok but can use some mods
and let me ask what is better 2.4 or 900mhz fpz video system and why u think so
( my 2.4 burnt up and im looking to get a new system )
osprey is offline Find More Posts by osprey
Old Sep 06, 2011, 05:11 PM
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
[QUOTE=osprey;19244638]
and let me ask what is better 2.4 or 900mhz fpz video system and why u think soQUOTE]
900Mhz is technically a better frequency because it should handle obstructions better, but that only helps if you fly low. However, depending on where you fly, you could run into different types of interference for each of these frequencies. 2.4 is nice if you're going to attach a CP antenna, because they are small, while the 900Mhz CP is enormous. Then again, if you're flying at a club, chances are there's going to be a ton of other 2.4 radios which could cause you problems.
Personally, I think I'm going to switch to 1.3 from 900. it's a good in-between frequency.
Old Sep 07, 2011, 05:47 AM
jaskel's Avatar
Joined Dec 2005
ok thanks mate
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 Video Piloting (FPV/RPV) 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar Video Piloting (FPV/RPV) 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 Video Piloting (FPV/RPV) 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro RTF 3 Apr 18, 2010 06:00 PM
