Old Aug 16, 2011, 09:31 AM
porcia83 is offline
Find More Posts by porcia83
United States, CT, Hartford
Joined Jun 2009
Nice catch!
porcia83 is offline Find More Posts by porcia83
Reply With Quote  (Disabled)
Old Aug 17, 2011, 09:18 AM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
Going to start my build
I just started flying FPV a couple weeks ago. Here is a link to one of my flights:
FPV Flying - Easy Star - Eagle Tree OSD - Fat Shark Dominator Goggles (4 min 21 sec)
Going to move the gear from the Easy Star to the EPP FPV and see how it does. Very happy with the Easy Star but I have a ton of gear on it for that little of a plane. Sort of wonder if will be a wash though. The Easy Star sips power. I can fly 18-20 minutes on a 2200 pack with all the FPV gear and a Go Pro. I can carry more battery power on the EPP FPV but it looks like it will eat a lot of power so wonder if worth it.
I got some good ideas on the buld from this thread. Thanks for all that put their ideas in this thread. Hope to post my progress on this model soon.
Tony97 is offline Find More Posts by Tony97
Old Aug 17, 2011, 09:25 AM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I'm doing the exact same thing. I use the AXN Floater-Jet, and it's overloaded with gear. I fly about 12-15 minutes on a 1600mA battery. I'm also going to use a 4S battery for the FPV EPP instead of 3S. Can anyone tell me what the real difference is in doing this?
Here is a video of the AXN flying:
Cloudy Day - Flown With Dragon Link (3 min 15 sec)
Tracks is offline Find More Posts by Tracks
Old Aug 17, 2011, 01:30 PM
vvV FANG Vvv is offline
Find More Posts by vvV FANG Vvv
Formerly bUd~Fokker
vvV FANG Vvv's Avatar
Australia, NSW, Harden
Joined Aug 2008
Tracks you want to know the difference in using a 4s pack compared to a 3s pack????
I hope i have read your question wrong as that is something that anyone should know?
A 4s has more cells then a 3s and therefore more volts (it's 3.3v per cell or 4.2v fully charged).
A 4s pack i dont think is suited to this plane unless its a low kv motor.
_______________________
It's funny reading about people putting their gear from their easystars into this plane as i have recently done the opposite.
I had a burn out of my OSD in my EPP FPV so i have since switched the gear over to the easystar and have been flying blind without any osd. I mainly went back to the easystar for its agility and climb rate over the EPP FPV but now i have hit 3km out and back with it and thinking 4km might be the limit with my 2650mah pack i might switch back to the EPP FPV and fly the same route to see if is any better for range.
It's an ok plane, it's just not a glider... I think of mine as being like a big old workhorse, it can carry some weight and therefore serves a purpose for me.
The Easystar in comparrison is like a fat greyhound ... and the Skywalker is still an ugly cow even if it can chew the grass well.
vvV FANG Vvv is offline Find More Posts by vvV FANG Vvv
Old Aug 17, 2011, 02:49 PM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I know a 4s has more volts, I'm just unclear on what affect that has on a given motor with regards to current draw, speed, etc.
Old Aug 17, 2011, 06:05 PM
Formerly bUd~Fokker
Joined Aug 2008
Gosh you must be very new to all this! This is the very basics of electric flight, and i just assumed someone getting into fpv would already have that kind of knowledge. Have you been flying long?
Every brushless motor has a KV rating like say 1100kv which means for each volt the motor will do 1100 revolutions per minute (rpm) (roughly ..depends on props ect). So on 3cells (fully charged is 12.6 but lets use 12volts) that motor will spin at 12x1100 or 13,200 rpm. Now that same motor on 4s (16.8 fully charged but lets use 16) would be 1100x16 = 17600 rpm. So basically it will go to spin it faster ... now if the prop on the 3 cell pack was also used on the 4 cell pack the amp draw would be a lot higher. You usually change props when you change packs to make sure you keep the amp draw below the rating set for your motor. With this plane you ideally want to swing a 10 or 11 inch prop so you choose a motor and battery combo to best suit the prop size.
Old Aug 17, 2011, 07:17 PM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I see. The batteries were free, so I was hoping to use them. Looks like I should find some 3S instead.
Old Aug 17, 2011, 07:18 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Routing of elevator and rudder servo wires
I liked the idea of how some folks cut the foam and installed the elevator and rudder servos right in the horizontal stab. I want to do the same. Should I exit the foam above the tail boom and drill into the boom or use fish wire and poke through the foam near where the boom starts in the main fuse? I wish I had thought to buy servo wire to put my own leads on.
Any direction here (pictures best) would be great. Thanks guys.
Old Aug 17, 2011, 07:31 PM
Formerly bUd~Fokker
Joined Aug 2008
Hi Tony, i did that to my plane and i went through the foam at the end of the boom. I didnt like the idea of putting a hole in the boom as it might weaken it ... and i didnt want to tape them to the outside of the boom.
I got a bit of coathanger and heated it up in the fire and took several stabs at poking through from the boom hole into the main compartment.
Getting the first hole through wasnt so hard, but getting it big enough to take the two servo plug ends was a bit harder.
I had several goes with the hot bit of coat hanger but there was always a lil chunk stopping me. I then noticed the large threaded rod i had for something else (i think was using it as balast inside an easystar cf wing spar) i heated that in the open fire and it worked like a dream with the thread working like a big foam file!!
A long peice of threaded rod should only be a coupla bucks at your local hardware store.
I used 1m long extension leads and they were spot on for length!
Old Aug 17, 2011, 10:25 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
Thanks so much for the great tips. I will give it a go. I will run to radio shack to see about buying the right wire to build extensions or just put a bunch together. Not sure if I can find them 1 meter long.
How much carbon rod should be extended past the fuse?
Old Aug 18, 2011, 12:11 AM
Formerly bUd~Fokker
Joined Aug 2008
I just pushed and twisted my boom in until i couldn't push it in anymore, but i think i might have read somewhere in the forum here where people had mentioned the boom length ... im not sure if they worked that out by the length of the plane quoted by Hobbyking.... there could of also been some mention of people cutting their boom down by a coupla inches to get it to meet that length ... but since the search function is down i cant find it.
Id say just twist it in as far as it will comfortably go ... mine went in probably 2 inches or so.
Old Aug 18, 2011, 03:46 AM
i3dm is offline
Find More Posts by i3dm
RC pilot by soul
Israel
Joined Apr 2005
http://www.youtube.com/watch?v=s_rWAizyG0w&hd=1
thats actually an impressive video of an AXN! do you have some posts showing your gear on the AXN?
i3dm is offline Find More Posts by i3dm
Old Aug 18, 2011, 12:33 PM
Tony97 is offline
Tony97's Avatar
Joined May 2004
No motor mount or prop adapter
I was starting to get my bench ready for the build and removed all the parts and layed them out. This is when I realized....the motor from Hobby King they recommend on the EPP FPV page DOES NOT come with a mount or prop adapter. Went to the local hobby shop and they don't carry it. HK is out of them and I didn't want to wait 25 days for one to come in anyway.
The more I think about it, the more just getting a different motor may be best. The one I got from HK (the one on the EPP FPV page) is a 1400 KV motor. http://www.hobbyking.com/hobbyking/s...00Kv_550W.html
1400 Kv seems high. I want to run one or two 3s packs. I have a ton of 2,200 packs but was looking to later buy some 3300 packs for this to run parallel.
I read over most of the posts on this thread and there is some info on motors. Anyone recommend a good motor setup for me?
Old Aug 18, 2011, 02:21 PM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
You can see it all on this post:
http://www.rcgroups.com/forums/showp...postcount=1008
Old Aug 18, 2011, 10:01 PM
yzguy is offline
Find More Posts by yzguy
yzguy's Avatar
Florida
Joined Mar 2007
I love that motor on mine with 3S and 10X5 prop. I run, up to 3 2200 3S packs in parallel (I use 2200's for several planes) .
plenty of power (maybe even too much, but I like too much ).
yzguy is offline Find More Posts by yzguy
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 06:00 PM
