Old Dec 07, 2010, 06:10 AM
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Originally Posted by porcia83 View Post
So I just got my plane today...really excited. For some reason I thought it would be bigger than it was. Perhaps the size of the model holding the plane threw me off. Looks big and tough and sturdy though. The magnets on the cockpits are a joke though.
I don't fly FPV stuff although I love watching it. I'm just staring to video stuff with the spy cameras and a flip camera I just got. I also have a pretty lightweight camcorder that captures images and video on SD cards, so the camera will fit on here great. I've never seen so much space to fit an ESC...wow! I'll probably cut a strip out of the bottom to install lights for some night flights as well as some windows on the side for either pics (don't ask) or more lights. I'm going to use good metal gear servos. I also plan on installing landing gear and flaps. The ailerons on this thing are the biggest I've seen yet...huge!.
Most importantly, this thing needs a little custom paint job. The graphics leave much to be desired.
So my question is on the motor set up. I typically overpower my stuff and I'd like some suggestions for this plane. Would a power 15 or power 25 work o/k? I'm not looking for speed as much as pulling power, getting out of trouble if needed.
I love finding these threads on the planes I already have or want, so much great info. Sometimes over my head on the tech side, but I can read.
This may be a great plane for me to finally to a build thread on. We'll see.
Hi
If the link provided by Tumtum is the correct motor the Power25| i would say is a 4cell motor on this model, due to limit's on propp size.
this is from Badcock's calc.
http://www.badcock.net/cgi-bin/power...ear=0&D_gear=0
Maybe a little low on power on a 10x7 but the numbers from the 11x5.5 is close to a 10x5x3(3blade) in speed and thrust.
Kai
DrEvil is offline Find More Posts by DrEvil
Old Dec 07, 2010, 06:57 AM
porcia83's Avatar
United States, CT
Joined Jun 2009
Originally Posted by tumtum View Post
I think he means the E-flites
http://www.e-fliterc.com/Products/De...odID=EFLM4025A
looks underpowered
Yup, that was the one, I should have linked to that.
But underpowered? Thats supposed to put out up to 600 watts, and that will be underpowered for this? I guess I'll keep poking around and see what set ups everyone else is using.
porcia83 is offline Find More Posts by porcia83
Latest blog entry: magnum
Old Dec 07, 2010, 07:03 AM
porcia83's Avatar
United States, CT
Joined Jun 2009
Kai[/QUOTE]
Wow...interesting page for sure, thanks. I'm new to tinkering with engines and set-ups, normally fly stock stuff. Some of this stuff is way to technical for me but I guess I have to read up and figure it out. Thanks guys.
Old Dec 07, 2010, 08:26 AM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Kai
Wow...interesting page for sure, thanks. I'm new to tinkering with engines and set-ups, normally fly stock stuff. Some of this stuff is way to technical for me but I guess I have to read up and figure it out. Thanks guys.[/QUOTE]
My statement on "low on power" is compared with some of the other setup's in this tread.
Hobie14 was flying on just 250watt from the start.
I don't know if that was 250w off the batt or on the propp, but close to 400w on the propp is sufficient to fly with autorety and with the 10x5x3blade you would have even more thrust !
I would say if you already have some 4cell lipo 2200-3300mAh you would have a nice setup there.
Kai
Old Dec 07, 2010, 08:40 AM
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
My statement on"low on power" is comared with some of the other setup's in this tread.
But Hobie14 was flying on just 250watt from the start.
I would say if you already have 4cell lipo 2200-3300mAh you would have a nice setup there.
Kai[/QUOTE]
270 watts on the ground with a Watts up meter ..... ok(ish) if your launching off a 1200 ft hill but not much fun taking off with trees at the end of the runway ..... I expect a minimum of 400 watts from a new motor setup soon to be tested .......
hobie14 is offline Find More Posts by hobie14
Old Dec 07, 2010, 09:02 AM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Kai
270 watts on the ground with a Watts up meter ..... ok(ish) if your launching off a 1200 ft hill but not much fun taking off with trees at the end of the runway ..... I expect a minimum of 400 watts from a new motor setup soon to be tested .......[/QUOTE]
Thanks for the update Hobie14, ok so 270w of the batt on that "smallish" motor is in its upper limits, and i would gues is aprox 65-70% effichency
wich is less than 200w on the propp.... thats "braveheart" flying
man
Kai
Old Dec 07, 2010, 11:51 AM
tmsn's Avatar
USA, CA, San Francisco
Joined Dec 2009
Would it be a bad idea to go with a 42-36 750Kv motor on 5 cells with a 10x7 prop?
I have a bunch of big 5000Mah batteries, and it might be a good opportunity to get a small but powerful motor to push this bird and use batteries I already have.
tmsn is offline Find More Posts by tmsn
Old Dec 07, 2010, 02:27 PM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Wount a 5cell 5000mAh batt be on the hevy side ?
In prinsiple a 750kv motor on 5cell would work well.
I would go for a 10x5 instead, as i don't think you would benefit much from a pitch speed of 140kmt
Kai
Old Dec 07, 2010, 02:45 PM
hobie14's Avatar
Joined Jul 2007
man
Kai[/QUOTE]
yes ..... I think your correct there ....
Old Dec 07, 2010, 03:51 PM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Lol :d
Old Dec 07, 2010, 04:50 PM
Palmdale, Ca
Joined Mar 2010
First video is a cruse test on the motor setup from post #170. No sound. OSD is calibrated this time.
http://www.youtube.com/watch?v=UFwiLZ2lhsE
Next video is testing the GoPro mount. Needless to say it failed. Too much vibration. I had it on a pan mount but I think I going for a fixed position. I don't like pan on a GoPro.
There was too much wind noise (going to have to work on that) so I dropped the sound and threw in some music. (Flight = Palmdale, Ca)
I suspect this will be the motor I'm going to use till someone comes up with something better. It seems to do the trick and has plenty of power. Flight time on a 4000 mah/3 cell was 22 1/2 min. at 1000 feet high. I'm going to try two batteries next time. There seems to be plenty of space for it.
Here's the Vid. Watch it on vimeo's site for full HD.
http://vimeo.com/17576534
Arley is offline Find More Posts by Arley
Old Dec 07, 2010, 06:37 PM
Southampton, Ontario CA
Joined Feb 2005
Did you use your gopro as your feed for your vtx? If you did, did you have to mod your Dragon OSD to get good video? The gopro didn't like my Dragon OSD+ V1 and I didn't want to mod it. I have a V2 and am hoping it will play better with the gopro. Great video.
Buffythesaint is offline Find More Posts by Buffythesaint
Old Dec 07, 2010, 08:38 PM
Palmdale, Ca
Joined Mar 2010
Nope, second camera on top of gopro but Im going to separate them and put the gopro on the nose. pan and tilt on the flight camera, stationary on the gopro. That should get rid of a lot of vibration and I think the gopro has a wide enough lens that it doesnt need pan and tilt.
Old Dec 08, 2010, 06:25 AM
Joined Feb 2005
Having all the weight of the gopro on a pan servo would cause vibration. I have mine fixed on my EG and it works out nice. You can use your FPV camera to frame the gopro shot. I'll have to test the gopro with my OSD+ V2 and see if I get clean video. I'd love to be able to use the gopro for recording and live feed out.
Old Dec 08, 2010, 11:44 AM
Aosta, Italy
Joined Feb 2009
All your plane are tail heavy?
mine is nose heavy :|
4000 3s in the nose
1300 3s video tx near the motor
motor 35-36 turnigy tr with 9x6 (48 amp at 11 volt)
http://www.hobbyking.com/hobbyking/s...idProduct=4916
two 9g servo for rudder and elevator put at the end of carbon rod near the tail...
10x zoom camera with pan and tilt with 2 futaba s3003
fy21 + ap117 osd on cg
colibri vtx and 1s behind the camera...
cg measured where are you telling (first carbon rod on the wings)
and nose heavy...
now i'm waiting my new ff9 that is in repairing mode to italian importer (radiosistemi) and when will come back i will maiden....
Ivan IV is offline Find More Posts by Ivan IV
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 Video Piloting (FPV/RPV) 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar Video Piloting (FPV/RPV) 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 Video Piloting (FPV/RPV) 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro RTF 3 Apr 18, 2010 06:00 PM
