Old Dec 06, 2010, 08:44 AM
hobie14's Avatar
Western Europe 52.7° N 8.9° W
Joined Jul 2007
Originally Posted by tumtum View Post
You will respect my authority!!! :P
yep ..... specially when there are trees on the take-off track ......
hobie14 is offline Find More Posts by hobie14
Old Dec 06, 2010, 09:51 AM
tumtum's Avatar
Belgium
Joined Jun 2009
Full throttle test with NTM 3536A 1800Kv, TGY 10x4.7SF, Turnigy nano-tech 2200mah 3S 45-90C Lipo and 80a ESC.
EPP FPV Hobbyking full throttle test (1 min 7 sec)
tumtum is offline Find More Posts by tumtum
Old Dec 06, 2010, 11:15 AM
Plane and multirotor's - FPV
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
http://www.youtube.com/watch?v=poNGuys-utw
Hi
Do you have the posibility to mesure amp draw and volt from battery ?
A wattmeter/wattsup tool or OSD with this abilety ?
Kai
DrEvil is offline Find More Posts by DrEvil
Old Dec 06, 2010, 11:22 AM
hobie14's Avatar
Joined Jul 2007
Well done TT .....
Power !!!! ...... and the trees can go to $$$$$$$$$$ .....
Old Dec 06, 2010, 01:58 PM
tumtum's Avatar
Belgium
Joined Jun 2009
Sorry Kai, I have no such equipment, I'm a full out amateur that flies on feeling (when planes start to catch fire, I land...or crash)
Thanks H!
I should come over and fly with you sometime
I can feel the wall that some guys are talking about, after making the nose heavier it got better (400 gr)
I compare this plane to a....truck (good for carrying stuff around)
Old Dec 06, 2010, 02:17 PM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Thanks H!
I'm also an amateur, but if you do El power rc you should absolutley get a wattsup or alike. Easy to use andt takes a few seconds to check if a new propp or a new Esc is within the systems specs... cheaper in the long run
I did a quick run trough the calculator and the numbers was scary
The Slowflyerpropps are Amp eater's and no good exept for propp hanging and SLOOOOVflying.
I got: Watt on propp- 900
Amp - 120
Efficeny - 62%
I would strongly advice you to pay atention to motor, Esc and batt temp. or/and get a reading on your setup while it's still alive
Or just get a new propp, 10x4 with slim blades.
Don't want to be a killjoy, but i want your setup to survive
Kai
Old Dec 06, 2010, 02:36 PM
tumtum's Avatar
Belgium
Joined Jun 2009
Amp - 120
Efficeny - 62%
Kai
Thanks Kai!
I completely understand. I tried several props (like a 10x5 and 9x4) but found the SF prop to be the nicest to fly with. The others needed much more throttle and made "A LOT" more noise.
I normally dont fly full throttle with SF prop, was just a test.
I have some other props lying around, feel free to give more tips!!!
Old Dec 06, 2010, 04:06 PM
hobie14's Avatar
Joined Jul 2007
Thanks Kai!
You could get a watts up meter for around $50.00 from HK if they are not available locally ..... it (or equivalent) really is an essential piece of kit .....
Old Dec 06, 2010, 04:17 PM
tumtum's Avatar
Belgium
Joined Jun 2009
Something like this?
http://www.hobbycity.com/hobbyking/s...dProduct=10348
Old Dec 06, 2010, 04:23 PM
hobie14's Avatar
Joined Jul 2007
this one is what I use ..... http://www.hobbycity.com/hobbyking/s...idProduct=6380
It was just offered it at $40.00 on HK as a special offer ....
Old Dec 06, 2010, 04:41 PM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
No.... like this one :http://www.hobbycity.com/hobbyking/s...dProduct=10080
This is HK copy of the Wattsup.
Or this one :http://www.hobbycity.com/hobbyking/s...dProduct=10786
Regarding noise from some of your other props, this can come from unbalanse in the prop.
Kai
Old Dec 06, 2010, 04:43 PM
tumtum's Avatar
Belgium
Joined Jun 2009
Aha, ok, thanks guys!!!
Old Dec 06, 2010, 09:57 PM
porcia83's Avatar
United States, CT
Joined Jun 2009
So I just got my plane today...really excited. For some reason I thought it would be bigger than it was. Perhaps the size of the model holding the plane threw me off. Looks big and tough and sturdy though. The magnets on the cockpits are a joke though.
I don't fly FPV stuff although I love watching it. I'm just staring to video stuff with the spy cameras and a flip camera I just got. I also have a pretty lightweight camcorder that captures images and video on SD cards, so the camera will fit on here great. I've never seen so much space to fit an ESC...wow! I'll probably cut a strip out of the bottom to install lights for some night flights as well as some windows on the side for either pics (don't ask) or more lights. I'm going to use good metal gear servos. I also plan on installing landing gear and flaps. The ailerons on this thing are the biggest I've seen yet...huge!.
Most importantly, this thing needs a little custom paint job. The graphics leave much to be desired.
So my question is on the motor set up. I typically overpower my stuff and I'd like some suggestions for this plane. Would a power 15 or power 25 work o/k? I'm not looking for speed as much as pulling power, getting out of trouble if needed.
I love finding these threads on the planes I already have or want, so much great info. Sometimes over my head on the tech side, but I can read.
This may be a great plane for me to finally to a build thread on. We'll see.
porcia83 is online now Find More Posts by porcia83
Latest blog entry: magnum
Old Dec 07, 2010, 02:47 AM
DrEvil's Avatar
Moss, Norway
Joined Jun 2007
Hi
Do you have link's for your motor sugestions ?
Kai
Old Dec 07, 2010, 04:36 AM
tumtum's Avatar
Belgium
Joined Jun 2009
I think he means the E-flites
http://www.e-fliterc.com/Products/De...odID=EFLM4025A
looks underpowered
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 Video Piloting (FPV/RPV) 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar Video Piloting (FPV/RPV) 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 Video Piloting (FPV/RPV) 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro RTF 3 Apr 18, 2010 06:00 PM
