Old Dec 10, 2012, 06:02 PM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I went over mine with some 100/150 grit sandpaper. That seemed to do the job.
Tracks is offline Find More Posts by Tracks
Old Dec 10, 2012, 06:21 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Doesn't sanding EPP make it even more rough?
The sides on my epp fpv are actually quite smooth. Everything else has that textured look. Despite the roughness, I really like the epp foam because I don't have to worry about scratching or breaking it.
gooby is offline Find More Posts by gooby
Old Dec 10, 2012, 07:31 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
well my airframe should be here Wednesday! so i will find out if it is smooth or not and if it can be fixed. also does anyone here have any good knowledge with 900mhz fpv systems? I have a 800watt 900mhz tx and rx for video and i got 900mhz cloverleafs and i walk about 100 yards away and get video drop outs. should i get a low pass filter?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Dec 10, 2012, 08:21 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I wouldn't bother trying to smooth out the foam, it really isn't as sandpapery as it looks. I have one the hobbyking 900mhz systems too and that doesn't sound normal at all. You should be getting more like 3km with that setup.
Old Dec 10, 2012, 08:28 PM
Joined Sep 2009
alright sounds good. and thats what other people are saying. I dont know what is wrong with my system!
Old Dec 10, 2012, 08:31 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
There's a good chance the problem is with the antennas. Try using the stock ones and then compare them to the cloverleaf. I read some thread where a guy was getting horrible range using 5.8ghz, and it turned out his antennas were bad knockoffs of ibcrazy's.
Old Dec 10, 2012, 09:08 PM
Joined Sep 2009
I will keep messing around with it and see what i can figure out. Different channels, different batteries, different location, and i guess perhaps a different aircraft.
Old Dec 11, 2012, 07:53 AM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
+1
IBCrazy or nothing...
greedyg76 is offline Find More Posts by greedyg76
Old Dec 11, 2012, 08:37 AM
Bigster is offline
Find More Posts by Bigster
Well, now that you know ...
Bigster's Avatar
Grafton, Massachusetts, United States
Joined Sep 2004
900MHz cloverleafs? How big are they?
Bigster is offline Find More Posts by Bigster
Old Dec 11, 2012, 08:45 PM
Joined Sep 2009
my 900mhz cloverleafs are dead on centered at 910mhz. I contacted IBcrazy and i was surprised he responded so quickly and told me exactly what was wrong. and he was right! My issue here is I am getting the black screen of death! my monitor is not designed for FPV!!! haha
I just the the airframe in the mail. I am water coating it right now and that will make it stronger for 4s and allow me to spray paint it without having the foam chew away from the spray paint chemicals.
Any modification i should do?? I read some where the tail boom bends in the front frame but I don't know how to get in there without cutting it in half.
Ill take any advice.
Rex
Old Dec 11, 2012, 09:04 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
The epp foam won't melt from any spray paint even without a coating.
Old Dec 11, 2012, 09:06 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Rex
No modifications are necessary. I don't have any problem with the tail boom bending and the vertical stabilizer is fine if you use rudder.
Old Dec 11, 2012, 09:32 PM
Joined Sep 2009
I still had a can of minwax watar base that i need to use up before it goes bad. It might dense it up a little for 4s. UPDATE: made it less bendy and more stiff with a few coats of waterbase paint
which is better? Elevator on the top of the rudder or on the bottom? I have seen people modify it and put it on top.
Old Dec 13, 2012, 01:40 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
Rex
I split it in half, it was easy the glue is not very strong. Added one of those fiberglass rings that come in the kit to increase rigidity to the boom inside the foam. Also made it easier to carve a channel out for my servo wires that run inside the boom, nice and clean.
Old Dec 14, 2012, 08:46 PM
Joined Sep 2009
nice, what do you guys do about the wing? do you put the spars in and glue it together or leave so you can break it down for transport? It seems to me that is a weak spot so i want it to be strong so it doesnt break in half for 4s
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 06:00 PM
