Old Dec 04, 2012, 12:31 AM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Originally Posted by kov16 View Post
You have to mix rudder with ailerons even when you get the cg correct.
Real planes will do the same thing if you don't use rudder.
are you saying you can program mixing ailerons and rudder on your transmitter? or manually do it like as if you were doing a knife edge?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Dec 04, 2012, 01:41 AM
Lioon is offline
Find More Posts by Lioon
Germany, Berlin
Joined Dec 2012
In my case: both
Lioon is offline Find More Posts by Lioon
Old Dec 04, 2012, 07:35 AM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Originally Posted by RUBNorris View Post
Really, the plane fly bad with alot of power. If you prop it down then your better off getting a 3s pack. I use 2 x 2650mah 3s. And packs are sooo much cheaper then 4s.
https://www.youtube.com/watch?v=iSIA...e_gdata_player
I think you win the Ugliest EPP FPV Award!
gooby is offline Find More Posts by gooby
Old Dec 04, 2012, 08:04 AM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Program mixing on the transmitter, but manually works too.
Old Dec 06, 2012, 06:49 PM
Joined Sep 2009
http://www.hobbyking.com/buddy.asp?c...0-B7E9DAD3EF4C
buddy code if anyone want it
Old Dec 06, 2012, 07:20 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Wow, it's only $76! Good to know if I crash my current EPP FPV.
Old Dec 07, 2012, 07:31 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I'm redoing the landing gear set up on my EPP FPV. Now there will be one fiberglassed piece of balsa on the outside and another on the inside. I'm going to attach the metal landing gear with two or three wood screws which will go through both pieces of balsa. It should be a much stronger setup now. I also fiberglassed part of the bottom that was looking rough.
The new 4.5" tires should be good for landing on sandy dirt.
Old Dec 07, 2012, 10:08 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
The landing gear project is finished and it looks good! I don't think I would do it again if I bought another EPP FPV. It's too much work for what should be a relatively simple plane.
Old Dec 08, 2012, 03:39 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
how about pics of the new gear?
greedyg76 is offline Find More Posts by greedyg76
Old Dec 08, 2012, 10:12 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I will take a few photos tomorrow, still haven't flown it though. My 5000mah 3s battery puffed up and the next biggest one is a 2600mah. I might fly it anyway just to test things out. How long should I expect the battery life to be? (Never flown down to zero with 5000). I was thinking maybe 10 minutes.
Old Dec 09, 2012, 01:16 AM
woreoutpilot is offline
Find More Posts by woreoutpilot
woreoutpilot's Avatar
Joined Nov 2008
battery time
When I use a 3 cell 5000 mah battery, I get a flight of 26 minutes
woreoutpilot is offline Find More Posts by woreoutpilot
Old Dec 09, 2012, 03:46 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
Here's my EPP FPV. I didn't feel like putting on the rubber bands for the photo.
Old Dec 09, 2012, 06:20 PM
Semper Fi
greedyg76's Avatar
Joined Mar 2009
looks nice. I suspect your large tail skid will add more vertical surface which will help with yaw stability.
Old Dec 09, 2012, 07:08 PM
Joined Sep 2009
I bet it will!
And damn! that wing looks like 10 grit sand paper!!! what is a good way to smooth it out?
Old Dec 09, 2012, 09:24 PM
gooby is offline
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
I bet it will!
Haha, maybe it has some kind of golf ball effect! Hobbyking should advertise the EPP FPV as having the ability to sand granite.
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 16, 2011 12:16 AM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 02:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 06:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 08:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 07:00 PM
