Old Nov 24, 2012, 03:13 PM
Airplanekid333 is offline
Find More Posts by Airplanekid333
"Every boy has a dream to fly"
Airplanekid333's Avatar
Fort Collins Colorado
Joined Sep 2009
Does anyone fly this bad boy on 4S? what prop?
4s with 1000kv motor and 50 amp esc. I am thinking like a 9x5?
Airplanekid333 is offline Find More Posts by Airplanekid333
Old Nov 28, 2012, 11:54 AM
Edgaras1 is offline
Find More Posts by Edgaras1
Lithuania, Kaunas Region, Kaunas
Joined Dec 2007
Hi,
this is my first FPV flight with HK 1800 epp plane. After 40second I used plane stabilization (Fy30A). I'm happy this plane, but not too much..
Valenčiūnų kaimas iš aukštai Rchobis.lt (10 min 40 sec)
Edgaras1 is offline Find More Posts by Edgaras1
Old Nov 29, 2012, 06:24 PM
greedyg76 is offline
Find More Posts by greedyg76
Semper Fi
greedyg76's Avatar
United States, CA, Rancho Cucamonga
Joined Mar 2009
Originally Posted by jglover View Post
Almost looks identical to my old lady
Are you still flying the twin boom version you built? I'm thinking of going that way my self but with dual vertical stabs for better yaw stability. This plane slides all over the place in stock form
greedyg76 is offline Find More Posts by greedyg76
Old Nov 30, 2012, 06:14 AM
Chriscool is offline
Find More Posts by Chriscool
Chriscool's Avatar
Suisse, VS, Vouvry
Joined Apr 2009
I tried mine on 4S 35-42 1000KV with APC-E 10x5.
690W and 46A in statics (a little too much for my SK 35-42). It was just a little test, but sure... it pushes much better this big bird in the air.
You're right... 9x5 will be probably better adapted for 4S under 1000kV.
Chriscool is offline Find More Posts by Chriscool
Old Nov 30, 2012, 03:34 PM
MrMuzza is offline
Find More Posts by MrMuzza
Joined Sep 2012
Heya Guys, Only had to wait 4 days and mine arrived last night (that's 30th November) - Hk Epp Fpv, put wings together so far, it's pretty big A few roughly manufactured parts as per rcplanereviews, so theyre still using that stock it would seem. cross spars are still atleast 3mm off, and left wing cut is too tough to bend without servo meltdown. So a few mods will be in order too.
Parts I ordered also came with it are as follows, 3536b 1400kv motor, 70A sbec and a pack of 11x4.7 slow fly blades, still to arrive is my 5000mah battery and a gopro hero3 black edition camera, it should be a beast when it's finished.
MrMuzza is offline Find More Posts by MrMuzza
Old Dec 02, 2012, 02:02 PM
jordan59961 is offline
Find More Posts by jordan59961
Joined Nov 2012
damn this plane flies like cwap i just test flew it and whenever i would bank the tail would hang way down but that might be because i might have the cg messed up i only had 2200 in the front
jordan59961 is offline Find More Posts by jordan59961
Old Dec 02, 2012, 02:36 PM
Lioon is offline
Find More Posts by Lioon
Germany, Berlin
Joined Dec 2012
I'm flying this big bird since April this year. It's quite heavy, but it's flying okay. No hanging tail (if rudder is mixed to the ailerons). I am sure, that my component selection was not the best, but so what: 1450KV motor, 55A ESC and a small 8x5 prop.
No FPV at Tempelhof... (3 min 8 sec)
Allgäu trip (4 min 36 sec)
Lioon is offline Find More Posts by Lioon
Old Dec 02, 2012, 05:05 PM
RUBNorris is offline
Find More Posts by RUBNorris
New Beeeeee
RUBNorris's Avatar
United States, CA, Sacramento
Joined Apr 2011
Still the best damn plane for the price. Mine is a tank. Its sweet!
RUBNorris is offline Find More Posts by RUBNorris
Old Dec 02, 2012, 08:29 PM
Joined Sep 2009
http://youtu.be/lfIti_Kh76M
http://youtu.be/tXxi_uMg86Q
Amazing stuff! I will be getting an EPP-FPV this Christmas with a 1000mw transmitter and a patch antenna, with a 800mw 900mhz fpv video transmitter with Cloverleafs. Gopro hero 2 mounted. I should get up to a mile safely. Seems like half of you like and the other half not so much. I am anxious haha.
I will be running mine on 4s.
Old Dec 02, 2012, 10:15 PM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Id say, no on 4s. It alittle overkill.
Old Dec 03, 2012, 12:12 AM
Joined Sep 2009
what if I down prop it? a smaller prop makes less vibrations and it is better for video, and how about setting a lower max throttle setting on a transmitter so that way I can't go wide open?
Old Dec 03, 2012, 06:57 AM
New Beeeeee
RUBNorris's Avatar
Joined Apr 2011
Really, the plane fly bad with alot of power. If you prop it down then your better off getting a 3s pack. I use 2 x 2650mah 3s. And packs are sooo much cheaper then 4s.
HobbyKing EPP FPV final set up (7 min 42 sec)
Old Dec 03, 2012, 09:11 AM
Joined Sep 2009
okay! thanks for the info!
Old Dec 03, 2012, 06:52 PM
Joined Sep 2009
I am going to prove you guys that I will built one of the best EPP-FPV out there. I am going to make it handle 4S. Also a 6mile FPV trip.
Old Dec 03, 2012, 09:48 PM
gooby is offline
Find More Posts by gooby
hjukhjuk
gooby's Avatar
United States, FL
Joined Feb 2012
You have to mix rudder with ailerons even when you get the cg correct.
Real planes will do the same thing if you don't use rudder.
gooby is offline Find More Posts by gooby
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 06:00 PM
