Old Aug 01, 2012, 01:54 PM
Firatp is offline
Find More Posts by Firatp
Firatp's Avatar
Turkey, Istanbul
Joined Dec 2010
Originally Posted by carl1864 View Post
Anyone have any good motor recommendations for what I'm trying to accomplish?
Looking to carry a gopro, plus fpv gear, and have the option of using either 2 2200mah 3's in parallel (already own a bunch), or possibly a 5000mah 3's, or occasionally only one 2200mah 3s.
Hoping to use rougly a 10x5 prop since I commonly have those (but would consider others)
Mainly looking for decent flight times around 20 minutes or more, and not to be underpowered.
HK NMT 3536 1400kv is perfect. You can Fly 20min with 3s 5000mah
Firatp is offline Find More Posts by Firatp
Old Aug 06, 2012, 10:56 AM
Andre6553 is offline
Find More Posts by Andre6553
Vulcan skyhook multirotor
Andre6553's Avatar
South Africa, GP, Pretoria
Joined Feb 2011
has anyone put a Ardopilot apm2 fc board on this plane?
Andre6553 is offline Find More Posts by Andre6553
Old Aug 10, 2012, 03:53 AM
ilovefpv is offline
Find More Posts by ilovefpv
Joined Jun 2011
Been thinking about it, but it is pretty expensive for a complete system... I might create my own...
-Steve
FOUNDER, www.ilovefpv.com
ilovefpv is offline Find More Posts by ilovefpv
Old Sep 03, 2012, 09:50 AM
Tony97 is offline
Find More Posts by Tony97
Tony97's Avatar
Joined May 2004
I took my EPP out the other day. Fought the goofy yaw trim issues while flying it on goggles. When I came by for a 40' pass I heard an odd buzzing sound. Took my goggles off and came back by. Same sound. Noticed tail vibrating so bad it buzzed. It did this at about 26 mph airspeed. Landed safe. Tail boom and tail felt same as always but I guess the EPP cells are just shot. I added carbon supports to the vertical fin as that may be an issue and coated the lower aft fuse with epoxy. Have not taken back out yet to test. If it does it again I will retire it. Over 50 FPV flights with her. Zero crashes. She has been a pretty good plane even though the thrust angle has been an issue since new.
Tony97 is offline Find More Posts by Tony97
Old Sep 05, 2012, 02:20 PM
SwissBoy is offline
Find More Posts by SwissBoy
No, you can't fly it.
SwissBoy's Avatar
United States, WI, Menomonie
Joined Nov 2006
Sup guys, interested in this bad boy... how often do they come back in stock on HK?? Or does anyone have a kit for sale?
I have been running and Easy Glider Pro for a while doing some AP with a gopro up top, and I want something with more payload ability and more utilitarian use. This looks like a good fit, probably continue with my GoPro with pan/tilt mount as well.
How does she handle wind?? And what kind of flight times could I go for with say, a 3000mah 3s? (Just what I have on hand)
SwissBoy is offline Find More Posts by SwissBoy
Old Sep 05, 2012, 03:18 PM
Tracks is offline
Find More Posts by Tracks
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
3000mah isn't enough battery. This baby is meant to hold a LOT of weight up front. I use a 5000mah 3S, plus a 1000mah for video, plus a GoPro on the nose. It drives like a school bus. Slow and steady. But it will stay in the air forever, and flies smooth.
Tracks is offline Find More Posts by Tracks
Old Sep 05, 2012, 03:53 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
Haha alright. Well I could run two in parallel or buy new batts.
Has anyone sanded/filled the foam and painted it? First, being so porous it would seem to be really draggy, as well as butt freakin' ugly. I've done other foams with filler primer, or with lightweight wood putty, but never EPP...
Old Sep 05, 2012, 04:34 PM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
Definitely worth sanding down. You can cover the wings with laminate if you want them ultra smooth.
Old Sep 05, 2012, 07:01 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
What kind of laminate? Interested...
Old Sep 06, 2012, 06:39 AM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
I would use a super light 1.5mil laminate. Tis is only for smoothness, not rigidity, so no sense in adding too much weight. Once you sand the wings smooth, the laminate sticks very well just using a hot iron, and the foam is pretty resistant to heat. No glue required.
Old Sep 06, 2012, 08:14 AM
brodjack is offline
Find More Posts by brodjack
usual old know-it-all
Blackpool,U.K.
Joined May 2005
Heres abit of video of the HK EPP plane in the air,great fliers..
watch 1080 and full screen..of course
FPV,Ady & me (4 min 15 sec)
brodjack is offline Find More Posts by brodjack
Old Sep 12, 2012, 09:28 PM
SwissBoy is offline
SwissBoy's Avatar
Joined Nov 2006
Anyone have a prediction when these will be back in stock?? Or do you have a kit for sale?
Old Sep 14, 2012, 11:07 AM
othernick is offline
Find More Posts by othernick
Joined Dec 2011
Mine splited wings during a flight...Anyone knows where to find the carbon fiber square tubes?
othernick is offline Find More Posts by othernick
Old Sep 14, 2012, 12:33 PM
Tracks is offline
Team Basement-RC
Tracks's Avatar
Canada, ON, Toronto
Joined Jan 2011
Available at HobbyKing.
http://www.hobbyking.com/hobbyking/s...idProduct=9012
Old Sep 14, 2012, 07:04 PM
agressiva is offline
Find More Posts by agressiva
Eduardo
Brasil, RS, Porto Alegre
Joined Aug 2008
TAIL Carbon tube
Anyone know where i can find the carbon tail tube for EPP-FPV ?
agressiva is offline Find More Posts by agressiva
Help! how to fix this hobby king plane gazza2003au Australia 29 Mar 15, 2011 11:16 PM
Discussion Hobby King New FPV plane bignose13 FPV Aircraft 141 Nov 24, 2010 01:04 AM
Discussion New EPP FPV plane catamar FPV Aircraft 9 Oct 12, 2010 05:29 PM
Discussion Hobby King FPV help! Polarity for RX? Rooster433 FPV Talk 6 Oct 10, 2010 07:24 PM
Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC TopFoam Micro Ready-to-Fly 3 Apr 18, 2010 06:00 PM
