-Alex |
Latest blog entry: Project Covert Ops: Long range ground...
Joined Nov 2011
start working on my epp fpv , does any one has an idea how likely install the tail wheel from hk http://www.hobbyking.com/hobbyking/s...dProduct=23898 thanks
Australia, VIC, Metung
Joined Oct 2008
As for installing the wheel, you just have to work it out, i.e. drill hole in boom and screw in or just glue in place or both? There is really no right or wrong way as ur probably the only one who will have done it. Trailblazer! |
Joined Oct 2008
Eppfpv
Those of you reading this thread thinking about getting one of these birds for FPV must take the following into consideration.
1. This is not a good first RC aircraft or trainer as it requires mixing and exhibits odd flight characteristics. 2. The build is not as straight forward as it looks and has design flaws. 3. Just because it's made of EPP doesn't make it indestructable, if you go in hard she will break up like any other bird. This EPP creation tolerates hard landings, minor crashes, hangar rash, but not much more. I'm seeing more and more people on these forums watching a few fpv vids on youtube and deciding the next day to buy a whole setup with an EPPFPV as the ship cos it kinda looks simple enough. Sure, you can do it, but it will cost you and it has cost others, already seen it. Don't get me wrong, shes a great bird when set up correctly, but without my 15 or so years experience and past mistakes adding to it, I would've crashed and burned by now for sure. Get an easystar and learn to fly it first without fpv gear and when you can fly it to yourself and catch it every time, you're about ready me thinks! |
It has been a while since I have flown my EPP FPV and read this thread. Good to see its still going. I did fly my EPP FPV yesterday twice. It's a year and a half old with about 50 FPV flights. Still going strong. The comments about it not being a very good trainer are true in my opinion as well. It does fly very goofy even with thrust angle tweaks, mixing, and stabilization from Eagle Tree. I may stiffen the tail up if I can by adding carbon under the motor area into the boom area. It's feels like it may flex a lot in flight. I will also put a camera facing aft on one side so I can see how bad it flexes. I have the G meter as well on my Eagle Tree setup. On a typical FPV flight I only pull about 1.6 G's. When I land (I have landing gear added) only 2.3 G's are experienced. I go easy in the plane and even though it doesn't fly real good, she hauls a ton of stuff. I fly with a full Eagle Tree setup, go pro, separate FPV camera, landing gear, a 6500 mah hard case battery, 800 mah battery, and a video transmitter. All this gear (not the 6500 battery) was hard on my Easy Star.
I have been close to ordering the Sky Surfer 1.5 to replace the EPP FPV. It's hard to put up the EPP FPV though. She has been good to me. Quote:
Joined Nov 2011
okay ,it look kinda big but doesnt weigh that much , i fig it out how to put it ,there is a more or less 30 meter strip in backyard and open field so ..... by the size and wing span i decided to put landing gear and stuff
i agree its not simple to complete the plane ,and i have been flying easystar for a year with gyros and 450 class heli with Flymentor and tricopter i hope i will finish it during my vacation ,as weather is horrible, raining and windy everyday,so keeping myself busy with it
Joined Jul 2012
EPP FPV IMO is a great model for FPV.
Stable and not modifications needed.. You can load and test any equipment you want.Weight is never an issue for that rc plane. I can prove this by my videos. Just a bit of practice and you ready. You don't need any special skills to fly it. Don't forget people rc World it is a game World. In real life with about 10 hours of flight lessons you able to fly solo full size aircraft's.. They are just a flying models. ps 6g is nothing for this model with AUW of 2.5Kg.Loops rolls and inverted flight easily can be executed. This is not the only model i have. I test fly many well known and unknown rc models and my opinion for EPP FPV is if you want a model for almost all the jobs go for it. About wind check this video and how stable it is! http://youtu.be/VtVYxmxdS1Q |
Joined Nov 2011
its a 9 degree incline to left ,if i keep the stabalizer horizontal 0 degree .
question is if i align the wings and stabalizer ,than they are 9 degree off to the body ,,,, is it gona fly okay ??????????????? or its gonna be un fruitful to carry on with the build ???????????????? |
Make sure the left wing panel and the right panel are glued together at the same incidence. Make sure the the stabilizer and the wing are the same incidence. Make sure the stabilizer and the wing are parallel. Make sure the CG is where is should be.......and it will fly very nicely......
Joined Oct 2008
Joined Oct 2008
Well, it is funny cos you say this is a 'wonder plane', it can do anything. Loops, rolls, inverted etc. Why would you buy this plane for aerobatics or anything other than FPV??? I have a Suhkoi for that. 'Just a bit of practice and you ready' Ready for what? and what is 'practice' ? a paper plane? And 'a game world'?? We fly in the REAL world in the same airspace as REAL people with REAL lives that could be compromised with comments like this. These comments risk encouraging inexperienced, but well intentioned people to put a 2+kg RC plane that is essentially a UAV into the air and risk damaging property or into the path of full scale operators. |
| Thread Tools | |
| Help! how to fix this hobby king plane | gazza2003au | Australia | 29 | Mar 15, 2011 11:16 PM |
| Discussion Hobby King New FPV plane | bignose13 | Video Piloting (FPV/RPV) | 141 | Nov 24, 2010 01:04 AM |
| Discussion New EPP FPV plane | catamar | Video Piloting (FPV/RPV) | 9 | Oct 12, 2010 05:29 PM |
| Discussion Hobby King FPV help! Polarity for RX? | Rooster433 | Video Piloting (FPV/RPV) | 6 | Oct 10, 2010 07:24 PM |
| Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC | TopFoam | Micro RTF | 3 | Apr 18, 2010 06:00 PM |
