United States, FL, Daytona Beach
Joined Feb 2012
ahhh. why didnt you guys tell me there's an inclinometer for the android phones.
https://play.google.com/store/apps/d...inometer&hl=en holding out on me, eh? ![]() Now I can measure the incidence levels. I measured almost precisely the same levels as comparing the wing and tail. i compared both angles - leading edge incidence, and trailing edge incidence (not sure of correct terminology here). so my guess at the number of credit cards to place at the trailing edge seemed to be spot on by some miracle. since i had such a rough time angling down my motor last time, i have gone the other direction, and angled it upwards - prop lower than the rear of the motor. wish me luck this time. the frame cant take much more punishment. i've already needed to reenforce the CF boom as the rear of the plane was wagging like a dog's tail after my last attempt. |
JG,
10x5.. don't see how prop pitch could affect plane pitch but I'm listening. Juice, Sweet app, I have used the level on my Android to set incedence before but it's the grip of the wing that the device needs to give consistent data. I'm inspired to do a a comparison with my laser meter. |
Blackpool,U.K.
Joined May 2005
Heres abit of vid. of our EPP planes.
one FPV and the other with a camera facing rear.. ours fly great..30 min.+ flights on a 5300mah 3 cell bat.
Ok, I'm done. That POS EPP FPV sucks a$$.
I should have cut my losses before I invested all this time into it. I got it in the air again, and was flying ok in the wind. I decided to try full throttle and determine if my genius pitch adjustment did the trick. Well, what I suddenly remembered as the plane was in an unrecoverable death spiral was it wasnt the throttle that caused the downward tilted lawn dart tendency, but instead was simply speed. Increased throttle mearly gave the frame the speed it needed to quash my unbridled enthusiasm once again. The frame is repairable no doubt...but my EPP FPV aspiration are not. So, if anyone local would like a free airframe that needs a little TLC, its yours. I would like to buy a similarly sized plane that i can use the same hardware on. i.e. skywalker. Since FPV is new to me, I'd like a plane that flys VERY easily that I don't have to fight like this POS I've dealt with. Perhaps a large wing ~2m with dihedral, ailerons, elevator, rudder. Can anyone point me in the right direction? |
my EPP FPV has never let me down so it will stay in my fleet .....
Canada, ON, Maynooth
Joined Nov 2011
I don't live in BC, but I will pay for you to ship what is left to Ontario, if it isn't too far gone... Send me a pic or two
I bought the new 1900 Skywalker last night. I liked the similarity to the EPP, but feel the skywalker has won where the EPP failed in terms of the solid tail boom (no wag hopefully), high mount horiz. stab (no ripped of tail on landings), and a more pleasing slick dense foam.
I didn't see a 2M raptor at the time, plus I was hesitant on the composite construction, and more limited cargo area. hope my internet impressions don't fail me. This is my first attempt into FPV, and really need a no-fuss platform to builld my experience. I don't want my investment to come crashing down because of a poorly designed feame. I've had the unused equipment waiting for a few months now, and am anxious to get it up in the air. |
i've had a few inquiries about the frame (no included electronics of course).
i don't mind shipping if i have to...however the wings are glued together, so finding a 2m box maybe a challenge as well as shipping costs. i'll look into it
Joined Nov 2011
Made some more mods to the EPP ... So far I have:
Replaced foam hinges with mylar. Replaced elevator with flat sheet balsa. Replaced Ailerons with balsa, added flaps. Reinforced fuse laterally, adding fuse lenght carbon spars embedded into the fuse on both sides. They also support and stabilize the landing gear, and extend out o join the tail boom, reducing flex at the joint. A center wood spar in embedded the length of the fuse, extending past the mount for the tail boom. Reinforced motor mount with light ply, joining the upper and lower parts of the fuse below the motor mount. Inserted bamboo shoots and Popsicle sticks into the fuse to make shelving for the equipment. light ply on the top of the fuse, at the wing joint, strengthen the fuse horizontally. Why did I do all this you ask???? because flying the EPP in moderate winds, with 2.8Kg AUW is like trying to fly a limp noodle... everything flexes, and dynamic inputs are often met with unpredictable results!!!! |
| Thread Tools | |
| Help! how to fix this hobby king plane | gazza2003au | Australia | 29 | Mar 15, 2011 11:16 PM |
| Discussion Hobby King New FPV plane | bignose13 | Video Piloting (FPV/RPV) | 141 | Nov 24, 2010 01:04 AM |
| Discussion New EPP FPV plane | catamar | Video Piloting (FPV/RPV) | 9 | Oct 12, 2010 05:29 PM |
| Discussion Hobby King FPV help! Polarity for RX? | Rooster433 | Video Piloting (FPV/RPV) | 6 | Oct 10, 2010 07:24 PM |
| Discussion Hobby King Christen Eagle Aerobatic Micro plane EPP Kit w/ Motor & ESC | TopFoam | Micro RTF | 3 | Apr 18, 2010 06:00 PM |
