Old Nov 02, 2010, 08:13 AM
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
Left/Right circular polarized antenna ?
I'm about to buy my first antenna, but is a bit confused about the difference between left/right circular polarized antenna ?
I can see from my search, that a circular polarized antenna works better if you make some hard banks with your plane, but it can't reach as long a linear polarized antenna.
But when using a 500mW Tx and a circular polarized antenna, how long will I be able to fly ?
And whats the difference between left and right circular polarized antenna ?
SpookiePower is offline Find More Posts by SpookiePower
Old Nov 02, 2010, 08:23 AM
trappy's Avatar
Austria
Joined Feb 2007
no difference between left and right circular. for your calculations subtract 3dbi from the antenna to gather the effective range. in other words, 8dbi circular polarized patch will get you as far as a 5dbi linear polarized patch assuming perfect polarization.
trappy is offline Find More Posts by trappy
Old Nov 02, 2010, 08:50 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Trappy is correct, but I should add to this:
With a linear antenna system, a 45 degree bank results in a 3db drop. A 90 degree bank results in a 26 db drop.
Thus a circular polarized antenna will have the same performance as a linear polarized antenna at a 45 degree bank. Beyond that bank, the circular polarized antenna performs better.
So my advice: Unless you plan on doing stunts or flying a serious pattern plane, get a linear antenna. If going for 3D and serious pattern flying, get a circular polarized antenna.
Most of us fly linear polarized antennas, me included.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Nov 02, 2010, 09:50 AM
FPV is my cup of tea
blupp's Avatar
Sweden
Joined Mar 2010
The following is NOT recommended as a first antenna configuration.
But there is another configuration.
Using a CP on the plane, one RHCP and one LHCP on ground station connected to a diversity switch.
Reduces multipath distortion and no -3dB loss.
blupp is offline Find More Posts by blupp
Old Nov 02, 2010, 10:03 AM
Torrance
Joined Feb 2005
Attenuates reflections and no -3dB loss.
what does a RHCP and LHCP look like who sells them?
JustinONE is offline Find More Posts by JustinONE
Old Nov 02, 2010, 10:30 AM
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
L-Com makes L & R CP antennae but where is one to get a small CP omni for the plane?...
Jeff
workshop is offline Find More Posts by workshop
Old Nov 02, 2010, 10:35 AM
Tesla's Workshop
workshop's Avatar
USA, CA, Torrance
Joined Nov 2004
I get much better performance (as measured by overall image strength and clarity) with CP antennae than with VP alone. It works better over terrain and through trees than VP and I do not get image distortion or shifting when maneuvering the plane (video plane - right side up and shallow turns only).
I use a high gain CP and a low gain VP omni on a diversity system for most of my work.
Jeff
Old Nov 02, 2010, 10:40 AM
blupp's Avatar
Sweden
Joined Mar 2010
It's short for Right-Hand and Left-Hand Circular Polarization.
You can make CP antennas yourself.
http://www.ham-radio.com/k6sti/attic.htm
http://sv1bsx.50webs.com/antenna-pol/polarization.html
Old Nov 02, 2010, 03:57 PM
Joined Jun 2009
-Alex
I have not done my first FPV flight yet, but I will be flying my easystar, and it will not be with any 90 degrees turns. My plan is to glide around, learn the feeling of FPV flying while flying slow and stay within about 1-2 km from base the first many flights. But I like to get up high.
So I guess that I should get the linear polarized.
Old Nov 02, 2010, 06:15 PM
cliffkot's Avatar
Joined Jun 2010
CP vs. Linear Polarizatrion
Circular polarization at the receive end is only safe way to fly and is especially important when you are pushing the limits of range. Remember, this is an FM system. The video signal to noise does not degrade much until just before the signal disappears.
So if you are flying to where you start to get appreciable noise, you are within a db or 2 of video loss. A slight bank and you are toast. I've seen this on so many crash movies. If you get an RC glitch, get hit with a gust, or even hiccup and bump the levers, you'll lose the signal.
Also, I might mention that most of what I'm reading suggests that there is a misunderstanding of how a diversity system is to be used. Diversity receive system compensate for path problems, not antenna mis-polarization or mismatched gains and patterns. True diversity systems should be used with identical antennas spaced a few wavelengths apart and pointing in exactly the same direction. Do not use a diversity controller as an antenna switch. That is another prescription for catastrophic failure.
Cliff K.
cliffkot is offline Find More Posts by cliffkot
Old Nov 02, 2010, 06:30 PM
trappy's Avatar
Austria
Joined Feb 2007
cliffk, there's not much truth in your above post - in fact the only correct thing is probably your name. don't really want to get into that discussion, just pointing it out.
Old Nov 02, 2010, 07:50 PM
Praying for better weather
Coyote64's Avatar
Joined Dec 2007
Cliff K.
What a load of rubbish !
First point, CP has 3db less range then linear so wrong.
Second point, your signal slowely degrades giving you plenty of warning so again complete rubbish
Third point, no you are the one who completely misunderstands diversity and the use of it.
Moral of the story, read advice but be carefull who`s you choose to listen too
Coyote64 is online now Find More Posts by Coyote64
Old Nov 03, 2010, 02:50 AM
Joined Jun 2009
But what if I like to go high, about 1 km (3.200ft). When flying level at that altitude, it must be like making a bank, compared to the antenna standing on the ground...I guess.
Is there an antenna for high altitude and one for low ?
Old Nov 03, 2010, 05:18 AM
blupp's Avatar
Sweden
Joined Mar 2010
There is many antennas that would fit for high, low or both.
I would place the antenna on the plane horizontally, if you have a rubber ducky or dipole.
Then use a CP antenna on the ground like this one and place it horizontally.
And if you want to go higher there are many other CP designs, like helical, quadrifilar helicoidal, quadix, cross-yagis, cp-patch, to name some.
There are many interesting CP designs like turnstile, spiral, skew-planar wheel, cycloid collinear, cycloid dipole, lindenblad, and more.
Old Nov 03, 2010, 05:39 AM
Netherlands, NH, Edam
Joined Jul 2004
Guys, c'mon, it is all the more constructive to point out why someone's opinion or educated guess is wrong, preferably by offering some evidence to the contrary.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Discussion 900 mhz circular polarized antenna? g00bd0g Video Piloting (FPV/RPV) 9 Aug 21, 2012 09:54 AM
Poll Is LTUP now left, center, or right? FireryPhoenix Life, The Universe, and Politics 46 Oct 29, 2010 11:25 AM
Cool Available 10mm Left and Right Hand Props boredom.is.me Micro and Sub-Micro Boats 18 Oct 28, 2010 02:24 PM
Question Circular polarized antenna question Sov4life Video Piloting (FPV/RPV) 8 Mar 05, 2010 05:00 PM
Discussion Advantage of a Circular Polarized Patch Ant? Mach61 Video Piloting (FPV/RPV) 2 May 01, 2009 10:53 PM
